Truck vs Car as a tow vehicle
Old October 29th 20, 05:30 AM posted to rec.aviation.soaring
2G
Default Truck vs Car as a tow vehicle
On Tuesday, October 27, 2020 at 6:43:15 PM UTC-7, wrote:
On Sunday, October 25, 2020 at 11:23:41 AM UTC-7, Chris Behm wrote:
I am wondering how often a truck for towing a glider trailer might be an advantage? I have yet to buy my first glider, but of course and thinking that the next vehicle I purchase should be a good one to tow with (Incidentally, thinking of the GMC/Chevy Canyon/Colorado, with the 2.8L inline 4 diesel).
But I am wondering how often that a truck is a better choice, all things considered.
Thanks.
Regards,
"Target"
I tow with a 1997 F150 and a Lexus RX300 SUV which is AWD and has a tow package. They both do a pretty good job towing my single seat glider in a Komet trailer. I prefer the Lexus as it drives nicer and you can haul the guys to dinner when out on an encampment. There’s plenty of room in the back with the seats folded down for equipment.
I would recommend 4WD/AWD pickup or mid size SUV. Make sure it comes with a tow package in either case.
AWD is significantly different from 4WD - AWD delivers power only to the rear wheels until traction is lost, then it transfers power to the other wheels. 4WD delivers power to all wheels, regardless of whether or not they have traction. In the time period that AWD senses traction loss and transfers power, you can lose control.
Tom
Old October 29th 20, 08:09 AM posted to rec.aviation.soaring
I'm sure that's true for some AWD vehicles, but it is not true for either Subarus or Audis - both of which I have owned. Both tend to bias power to the front in slightly different ratios, but have some power going to all wheels by default.
Old October 29th 20, 11:28 AM posted to rec.aviation.soaring
Actually, it is true of no vehicles. Those that don’t have permanent AWD systems (such as Quattro, Symmetrical, or Halda) use viscous couplers to transfer drive to the REAR wheels when the fronts lose grip, not the other way around.
Old October 29th 20, 11:41 AM posted to rec.aviation.soaring
Thanks.
Regards,
"Target"
Tom
I was thinking about when you need to get in that muddy pasture or farmers field. I typically drive my F150 in 2WD. No control issues at all.
Old October 29th 20, 03:36 PM posted to rec.aviation.soaring
2G
Thanks.
Regards,
"Target"
Tom
The time will come when you realize that you need 4WD because you will be stuck. I needed 4WD just to get into my backyard. It came in particularly handy when I did a long retrieve in Nevada and was in 4WD for 50-60 miles of back roads, some of which were flooded. Remember, you only need one bad point to get stuck.
Tom
Old October 29th 20, 04:31 PM posted to rec.aviation.soaring
Dan Marotta
Remember also two truisms about 4WD: 4WD gets you further in before you
get stuck, and ALL vehicles (these days) have 4 wheel brakes (that's for
all the 4WD guys that jam the throttle on icy roads).
Dan
5J
Thanks.
Regards,
"Target"
Tom
Tom
Old November 2nd 20, 02:20 AM posted to rec.aviation.soaring
2G
Dan
5J
Thanks.
Regards,
"Target"
Tom
Tom
Sounds more like urban myths to me. I have heard similar things said about open class gliders. I have used my 4WD vehicles MANY times to avoid getting stuck and spinning out, especially when I was skiing. With 2WD once you have lost traction on either driven wheel you ARE stuck or are spinning out because of how the differential works. 4WD, however, is not a substitute for common sense.
Tom
Old November 2nd 20, 02:27 PM posted to rec.aviation.soaring
Dave Nadler
Incorrect for modern vehicles equipped with limited-slip differentials...
Old November 2nd 20, 03:59 PM posted to rec.aviation.soaring
Craig Reinholt
I've towed many years and many miles with both a Toyota Tacoma and Acura MDX. Both towed my gliders very well. Choose a vehicle that best suits your off gliding needs that is also robust enough to tow. FWIW.
Craig
Old November 2nd 20, 04:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote on 11/2/2020 6:27 AM:
And with various styles of "electronic stability control", which use methods like braking the
spinning wheel to allow the differential to send power to the wheel with traction.
Apollo 13 pix last batch includes .par2s - "Apollo 13 space vehicle leaving Vehicle Assembly Building ap13-69-H-1906HR.jpg" yEnc (3/3) [960K] hielan' laddie Aviation Photos 0 September 12th 08 03:19 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 space vehicle leaving Vehicle Assembly Building ap13-69-H-1906HR.jpg" yEnc (2/3) [960K] hielan' laddie Aviation Photos 0 September 12th 08 03:19 PM
Apollo 13 pix last batch includes .par2s - "Apollo 13 space vehicle leaving Vehicle Assembly Building ap13-69-H-1906HR.jpg" yEnc (1/3) [960K] hielan' laddie Aviation Photos 0 September 12th 08 03:19 PM
747 versus truck gatt[_2_] Piloting 3 March 5th 08 02:20 AM
Saturn V Vehicle for the Apollo 4 Mission in the Vehicle Assembly Building 6754387.jpg [email protected] Aviation Photos 0 April 12th 07 01:38 AM
