How does my 1918 German barograph work? (Replogle mechanical drum)
Old October 29th 20, 08:12 PM posted to rec.aviation.soaring
AS
Default How does my 1918 German barograph work? (Replogle mechanical drum)
On Thursday, October 29, 2020 at 3:16:14 PM UTC-4, Charles Gosse wrote:
I have a 1918 German barograph, photos are at the URL below. It appears complete but I do not know how to make it work. Apparently it has to be wound-up. I also have a photo of the underside of the metal tray, if you need to see that.
https://www.aeroconservancy.com/flugzeug
Hello Charles - this is indeed a piece of aviation history! It looks just like an early version of the popular Winter Barographs.
There has to be a clockwork located under the drum. If you could post a link to a picture of the underside of the tray, it most likely will show a hole for a key used to wind up the movement or a bail that folds out to wind it up.
Take a look into the drum. There is most likely a thumb-screw used to removed the drum.
Also, the front plate is labeled 'Umdrehungszeit 2' meaning the drum will turn once every 2 hours. The clockwork may have a lever to change the drum speed to go slower or faster.
Thanks for sharing this link!
Uli
'AS'
FS: 2 E. H. Replogle Barographs [email protected] Soaring 0 April 22nd 14 02:38 AM
Barograph Blues Steve Leonard Soaring 3 May 12th 07 03:57 AM
For Sale- Replogle barograph [email protected] Soaring 5 April 24th 06 02:41 AM
Replogle Barograph For Sale Guy Byars Soaring 0 September 19th 05 10:07 AM
FS Replogle Barograph Al Groth Soaring 0 August 14th 04 11:24 PM
