Rumor has it that while both gliders were Flarm equipped, one was not functioning that day. Anybody know more?
On Monday, November 9, 2020 at 12:46:32 PM UTC-8, Ramy wrote: Around 5500 feet, 3500 AGL or so. They were not flying together per se, but were part of 8 gliders or so who flew from Byron that day in the same area on a great soaring day. That’s pretty much all I know so far. The bail out was captured by a photographer. You will need to zoom on the photos. http://claycord.com/2020/11/07/repor...oygdc08p925lqs Ramy |
I can only confirm that one flarm was working since I could see him earlier.. He also had ADSB. I know the other glider was equipped with flarm but I don’t know if it was operative.
One of the gliders was my old ASW27. Ramy |
Flarm Antenna placement is critical on ASW-27s because of carbon fiber structure. A single antenna by the glareshield leaves a big blind spot below. After a close encounter with an ASW-28 below, I mounted antennas on both sides of the canopy. Unfortunately FCC does not allow transmit on both antennas.
I wonder if they were at least talking to each other? Ramy, were you hearing anything on the radio? Anyone else?
Boggs |
On Tuesday, November 10, 2020 at 8:39:41 AM UTC-8, Waveguru wrote:
I wonder if they were at least talking to each other? Ramy, were you hearing anything on the radio? Anyone else? Boggs They were not talking to each other and not aware of each other. They didn’t see each other until a split second before impact. One of the flarms was inop due to expired firmware. They were both cruising under a cloud street and collided head on at 5300 ft MSL (3500 AGL) with their left wings significantly damaging the wings. Both gliders entered vertical or negative dive which helped them bailing out quickly as they fell of the gliders as soon as they released the seat belts. One pilot was mostly unscratched, the other was hospitalized due to hard landing on a slope and is recovering from back injury. I urge everyone to make sure to fly with operative powerflarm and upgrade the powerflarm firmware every year during the annual. Ramy |
Indeed, during the annual. The perfect time to do it and then you'll not be later questioning, did I or didn't I? A PSA is probably worth doing through RAS with a little how-to in spring for those of us in Northern Hemisphere. I always found those helpful. |
Yikes! This is the THIRD collision I've heard of in the last year and a half between PowerFLARM equipped aircraft where one of the PowerFLARMs is not working. In the first two cases the towplane PowerFLARM was not operating, one because of undisclosed issues, the other because the towpilot was taxiing back to the hangar without turning on the PowerFLARM when a glider at the end of its landing run pulled in front.
3 Missed Opportunities 5 Write Offs 2 Fatalities 1 Hospitalisation How much has/will your insurance go(ne) up ? |
On Monday, November 16, 2020 at 7:10:11 PM UTC-6, Ramy wrote:
On Tuesday, November 10, 2020 at 8:39:41 AM UTC-8, Waveguru wrote: I wonder if they were at least talking to each other? Ramy, were you hearing anything on the radio? Anyone else? Boggs They were not talking to each other and not aware of each other. They didn’t see each other until a split second before impact. One of the flarms was inop due to expired firmware. They were both cruising under a cloud street and collided head on at 5300 ft MSL (3500 AGL) with their left wings significantly damaging the wings. Both gliders entered vertical or negative dive which helped them bailing out quickly as they fell of the gliders as soon as they released the seat belts. One pilot was mostly unscratched, the other was hospitalized due to hard landing on a slope and is recovering from back injury. I urge everyone to make sure to fly with operative powerflarm and upgrade the powerflarm firmware every year during the annual. Ramy I hope FLARM realizes how lucky they are that the pilot did not die. They intentionally program a piece of safety equipment to brick itself once a year which then directly leads to the loss of life? I can see the crying widow in the courtroom now. Not pretty. |
Do you realize how irrational that comment is? It is entirely up to the pilot to update, they have a year to do it (firmware works for 2 years with a year overlap). If the pilot chooses, he can not have his parachute repacked, or not bother with the wing pins too. This should have the parachute and glider manufacturer quaking in their boots. In addition, it suggests flight is not possible without Flarm, which of course it used to be and often still is. I'm pretty sure every Flarm display will signal quite loudly that the firmware is inop. The alternative is to have a static system.
This is not to cast aspersions on the pilot, whom I know to be conscientious, plenty of people have and will again fly without or with inop Flarm. But to blame the manufacturer for this accident is ludicrous. If neither pilot had Flarm (legal and common) the outcome would be the same. On Monday, November 16, 2020 at 5:36:13 PM UTC-8, Tony wrote: On Monday, November 16, 2020 at 7:10:11 PM UTC-6, Ramy wrote: On Tuesday, November 10, 2020 at 8:39:41 AM UTC-8, Waveguru wrote: I wonder if they were at least talking to each other? Ramy, were you hearing anything on the radio? Anyone else? Boggs They were not talking to each other and not aware of each other. They didn’t see each other until a split second before impact. One of the flarms was inop due to expired firmware. They were both cruising under a cloud street and collided head on at 5300 ft MSL (3500 AGL) with their left wings significantly damaging the wings. Both gliders entered vertical or negative dive which helped them bailing out quickly as they fell of the gliders as soon as they released the seat belts. One pilot was mostly unscratched, the other was hospitalized due to hard landing on a slope and is recovering from back injury. I urge everyone to make sure to fly with operative powerflarm and upgrade the powerflarm firmware every year during the annual. Ramy I hope FLARM realizes how lucky they are that the pilot did not die. They intentionally program a piece of safety equipment to brick itself once a year which then directly leads to the loss of life? I can see the crying widow in the courtroom now. Not pretty. |
On 11/16/20 6:10 PM, Ramy wrote:
One of the flarms was inop due to expired firmware. I wonder how many personal injury attorneys saw that statement... -- Dan 5J |
At Area 51, Plenty of Invaders, No Aliens - area 51.jpg | Miloch | Aviation Photos | 0 | September 21st 19 07:16 PM |
Viral Area 51 ‘raid’ amasses 1 million recruits, gets Air Force warning - area 51.png (1/3) | The 'Brightness' control still doesn't help | Aviation Photos | 0 | July 16th 19 10:57 AM |
Right seat NY area to Boca Raton area | doylflier | Piloting | 0 | May 30th 07 01:06 PM |
Another midair! | tango4 | Soaring | 3 | April 27th 04 06:14 PM |
Pix of two midair F-18s | Pechs1 | Naval Aviation | 9 | January 8th 04 02:40 PM |
