On 11/17/20 11:54 AM, Davis Chappins wrote:
Christophe, I looked into the EU version of Stratux but 978 isn't used over there so it disabled that radio. The main branch of Stratux has both 978 and 1090 and is more appropriate for the US. Dan, Glad you were able to figure it out and it worked for you. Did you fly with it at all? I'll create a github later with the files so that anyone can install it. No, I didn't fly with it. Getting three aircraft hits, plus getting their ICAO numbers and other information on each, plus getting a collision warning convinced me that your script works. Since I don't use Stratux in the Stemme (Trig 22 and TN 70), the gyro (Trig 22 and TN 72), or the C-180 (Garmin GTX-345 and FlyQ), I have no need. -- Dan 5J |
Hi Dan,
Did you ever try this with your Dell Streak 5? Regards KN At 20:34 17 November 2020, Dan Marotta wrote: On 11/17/20 11:54 AM, Davis Chappins wrote: Christophe, I looked into the EU version of Stratux but 978 isn't used over there so it disabled that radio. The main branch of Stratux has both 978 and 1090 and is more appropriate for the US. Dan, Glad you were able to figure it out and it worked for you. Did you fly with it at all? I'll create a github later with the files so that anyone can install it. No, I didn't fly with it. Getting three aircraft hits, plus getting their ICAO numbers and other information on each, plus getting a collision warning convinced me that your script works. Since I don't use Stratux in the Stemme (Trig 22 and TN 70), the gyro (Trig 22 and TN 72), or the C-180 (Garmin GTX-345 and FlyQ), I have no need. -- Dan 5J |
Hi Kevin,
No, I did not try it with a Streak, but I don't see why it wouldn't work unless the program which converts the protocols would not work on the older Android version on the Streak, 3.2 or thereabouts, my phone runs version 10, I think. Dan On 11/21/20 9:52 AM, Kevin Neave wrote: Hi Dan, Did you ever try this with your Dell Streak 5? Regards KN At 20:34 17 November 2020, Dan Marotta wrote: On 11/17/20 11:54 AM, Davis Chappins wrote: Christophe, I looked into the EU version of Stratux but 978 isn't used over there so it disabled that radio. The main branch of Stratux has both 978 and 1090 and is more appropriate for the US. Dan, Glad you were able to figure it out and it worked for you. Did you fly with it at all? I'll create a github later with the files so that anyone can install it. No, I didn't fly with it. Getting three aircraft hits, plus getting their ICAO numbers and other information on each, plus getting a collision warning convinced me that your script works. Since I don't use Stratux in the Stemme (Trig 22 and TN 70), the gyro (Trig 22 and TN 72), or the C-180 (Garmin GTX-345 and FlyQ), I have no need. -- Dan 5J -- Dan 5J |
![]() I don't think QPython works with my ancient Dell Streak (Android 2.2) Might try upgrading Android, or use this as an excuse to change my phone! Kevin At 17:46 21 November 2020, Dan Marotta wrote: Hi Kevin, No, I did not try it with a Streak, but I don't see why it wouldn't work unless the program which converts the protocols would not work on the older Android version on the Streak, 3.2 or thereabouts, my phone runs version 10, I think. Dan |
On 11/22/20 8:35 AM, Kevin Neave wrote:
I don't think QPython works with my ancient Dell Streak (Android 2.2) Might try upgrading Android, or use this as an excuse to change my phone! Kevin At 17:46 21 November 2020, Dan Marotta wrote: Hi Kevin, No, I did not try it with a Streak, but I don't see why it wouldn't work unless the program which converts the protocols would not work on the older Android version on the Streak, 3.2 or thereabouts, my phone runs version 10, I think. Dan My Streak(s) run Cyanogen Mod 7, which is an Android 3.x.7 version. It won't run Avare without the external I/O app. -- Dan 5J |
XCSoar and V7 | [email protected] | Soaring | 8 | January 17th 14 09:19 PM |
CAI-302 and XCSoar | Dan Marotta | Soaring | 7 | March 29th 12 09:55 PM |
XCSoar in the UK | Martin Gregorie[_5_] | Soaring | 0 | August 10th 09 10:46 PM |
XCSOAR | Travis Beach[_2_] | Soaring | 3 | May 24th 08 03:36 PM |
XCSoar | jorgie | Soaring | 2 | November 2nd 04 12:05 AM |
