On Wed, 18 Nov 2020 17:00:53 -0800, Eric Greenwell wrote:
I also expect to see other Flarms while preflighting the glider before flying, and before takeoff - no Flarms seen means I likely have a problem and should determine what it is. Is that a difference between FLARM and PowerFlarm? I've never used Power FLARM, but I don't recall any FLARM showing traffic when stationary: even waiting on the second winch queue I don't recall the glider on the other cable showing as it launched nor a tow taking off on the far side of the field. Or, for that matter, landing gliders triggering it when I'm in the launch queue, so in front of and 100-200m to one side of the landing glider. Then again, none of these should trigger an alarm since a collision is not possible in any of these cases is a collision possible. OTOH, even a taxiing tug 2-300m away can trigger an alarm while I'm rolling up to the launch point after landing: very disconcerting it is too when it happens! But really: do it at the annual; do it when you are getting the glider ready for the 1st flight of the season. It's not that hard - write yourself notes if you can't remember. Couldn't agree more. I always used to do that and now its a mandatory item on the BGA-approved Annuals check-list. I also like to run an early flight from a new season through the FLARM trace analyser to check the range in all directions and make sure its working correctly and the antenna didn't get displaced during the last Annual. -- -- Martin | martin at Gregorie | gregorie dot org |
Martin Gregorie wrote on 11/18/2020 5:48 PM:
On Wed, 18 Nov 2020 17:00:53 -0800, Eric Greenwell wrote: I also expect to see other Flarms while preflighting the glider before flying, and before takeoff - no Flarms seen means I likely have a problem and should determine what it is. Is that a difference between FLARM and PowerFlarm? I've never used Power FLARM, but I don't recall any FLARM showing traffic when stationary: even waiting on the second winch queue I don't recall the glider on the other cable showing as it launched nor a tow taking off on the far side of the field. Or, for that matter, landing gliders triggering it when I'm in the launch queue, so in front of and 100-200m to one side of the landing glider. Then again, none of these should trigger an alarm since a collision is not possible in any of these cases is a collision possible. OTOH, even a taxiing tug 2-300m away can trigger an alarm while I'm rolling up to the launch point after landing: very disconcerting it is too when it happens! But really: do it at the annual; do it when you are getting the glider ready for the 1st flight of the season. It's not that hard - write yourself notes if you can't remember. Couldn't agree more. I always used to do that and now its a mandatory item on the BGA-approved Annuals check-list. I also like to run an early flight from a new season through the FLARM trace analyser to check the range in all directions and make sure its working correctly and the antenna didn't get displaced during the last Annual. I tend to use Flarm interchangeably with PowerFlarm, but as a US pilot, PowerFlarm is what I have, and it does show the position of any PowerFlarm equipped glider within range, even if both gliders are stationary on the ground. It doesn't generate collision alarms it that situation. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Wed, 18 Nov 2020 18:44:11 -0800, Eric Greenwell wrote:
Martin Gregorie wrote on 11/18/2020 5:48 PM: On Wed, 18 Nov 2020 17:00:53 -0800, Eric Greenwell wrote: I also expect to see other Flarms while preflighting the glider before flying, and before takeoff - no Flarms seen means I likely have a problem and should determine what it is. Is that a difference between FLARM and PowerFlarm? I've never used Power FLARM, but I don't recall any FLARM showing traffic when stationary: even waiting on the second winch queue I don't recall the glider on the other cable showing as it launched nor a tow taking off on the far side of the field. Or, for that matter, landing gliders triggering it when I'm in the launch queue, so in front of and 100-200m to one side of the landing glider. Then again, none of these should trigger an alarm since a collision is not possible in any of these cases is a collision possible. OTOH, even a taxiing tug 2-300m away can trigger an alarm while I'm rolling up to the launch point after landing: very disconcerting it is too when it happens! But really: do it at the annual; do it when you are getting the glider ready for the 1st flight of the season. It's not that hard - write yourself notes if you can't remember. Couldn't agree more. I always used to do that and now its a mandatory item on the BGA-approved Annuals check-list. I also like to run an early flight from a new season through the FLARM trace analyser to check the range in all directions and make sure its working correctly and the antenna didn't get displaced during the last Annual. I tend to use Flarm interchangeably with PowerFlarm, but as a US pilot, PowerFlarm is what I have, and it does show the position of any PowerFlarm equipped glider within range, even if both gliders are stationary on the ground. It doesn't generate collision alarms it that situation. I should have added that I'm not surprised: to a first approximation on a gliding club field nothing with FLARM fitted moves unless its taking off, landing or is a tug taxiing, so there's little or no benefit in a stationery glider flagging up moving aircraft for its pilot. OTOH I can see that it would be useful for a Power Flarm to do so, especially one with ADS-B in since, on a field that is also used by powered aircraft, it would be able to flag up most? all? aircraft movements, especially those on approach while you're waiting at the hold point. -- -- Martin | martin at Gregorie | gregorie dot org |
It's a function of the display, rather than what type of Flarm, Martin.
If you have a display that only shows alarms, you won't see anything on the ground when you're on the ground. On the other hand, if you have a traffic display, you'll see it all. Both Flarm and PowerFlarm send out both alarms and traffic data. Some displays just show the alarms. Paul On Thursday, November 19, 2020 at 3:23:55 AM UTC, Martin Gregorie wrote: On Wed, 18 Nov 2020 18:44:11 -0800, Eric Greenwell wrote: Martin Gregorie wrote on 11/18/2020 5:48 PM: On Wed, 18 Nov 2020 17:00:53 -0800, Eric Greenwell wrote: I also expect to see other Flarms while preflighting the glider before flying, and before takeoff - no Flarms seen means I likely have a problem and should determine what it is. Is that a difference between FLARM and PowerFlarm? I've never used Power FLARM, but I don't recall any FLARM showing traffic when stationary: even waiting on the second winch queue I don't recall the glider on the other cable showing as it launched nor a tow taking off on the far side of the field. Or, for that matter, landing gliders triggering it when I'm in the launch queue, so in front of and 100-200m to one side of the landing glider. Then again, none of these should trigger an alarm since a collision is not possible in any of these cases is a collision possible. OTOH, even a taxiing tug 2-300m away can trigger an alarm while I'm rolling up to the launch point after landing: very disconcerting it is too when it happens! But really: do it at the annual; do it when you are getting the glider ready for the 1st flight of the season. It's not that hard - write yourself notes if you can't remember. Couldn't agree more. I always used to do that and now its a mandatory item on the BGA-approved Annuals check-list. I also like to run an early flight from a new season through the FLARM trace analyser to check the range in all directions and make sure its working correctly and the antenna didn't get displaced during the last Annual. I tend to use Flarm interchangeably with PowerFlarm, but as a US pilot, PowerFlarm is what I have, and it does show the position of any PowerFlarm equipped glider within range, even if both gliders are stationary on the ground. It doesn't generate collision alarms it that situation. I should have added that I'm not surprised: to a first approximation on a gliding club field nothing with FLARM fitted moves unless its taking off, landing or is a tug taxiing, so there's little or no benefit in a stationery glider flagging up moving aircraft for its pilot. OTOH I can see that it would be useful for a Power Flarm to do so, especially one with ADS-B in since, on a field that is also used by powered aircraft, it would be able to flag up most? all? aircraft movements, especially those on approach while you're waiting at the hold point. -- -- Martin | martin at Gregorie | gregorie dot org |
On Thu, 19 Nov 2020 01:58:03 -0800, Paul Ruskin wrote:
It's a function of the display, rather than what type of Flarm, Martin. If you have a display that only shows alarms, you won't see anything on the ground when you're on the ground. On the other hand, if you have a traffic display, you'll see it all. Both Flarm and PowerFlarm send out both alarms and traffic data. Some displays just show the alarms. Thanks, Paul. That makes sense. -- -- Martin | martin at Gregorie | gregorie dot org |
Hi
Regarding annual maintenance: We have recently published a manual for that: https://www.flarm.com/ica. We hope that this clarifies some important questions and streamlines the process. Appendices A and B contain checklists that you can run through during installation or maintenance. This is a new initiative and I'm sure the document can still be improved. Feedback is thus highly appreciated. Regarding the reports on false/nuisance warnings: There are (of course) limits to what a FLARM can do, but unless you have a large gaggle of gliders, the alarming behavior should be very reasonable. If you think something is not working (or should be improved), please do send log files of the incident (https://flarm.com/about-us/contact/). We're happy to have a look. Best Regards - Urban On Thursday, November 19, 2020 at 10:58:06 AM UTC+1, Paul Ruskin wrote: It's a function of the display, rather than what type of Flarm, Martin. If you have a display that only shows alarms, you won't see anything on the ground when you're on the ground. On the other hand, if you have a traffic display, you'll see it all. Both Flarm and PowerFlarm send out both alarms and traffic data. Some displays just show the alarms. Paul On Thursday, November 19, 2020 at 3:23:55 AM UTC, Martin Gregorie wrote: On Wed, 18 Nov 2020 18:44:11 -0800, Eric Greenwell wrote: Martin Gregorie wrote on 11/18/2020 5:48 PM: On Wed, 18 Nov 2020 17:00:53 -0800, Eric Greenwell wrote: I also expect to see other Flarms while preflighting the glider before flying, and before takeoff - no Flarms seen means I likely have a problem and should determine what it is. Is that a difference between FLARM and PowerFlarm? I've never used Power FLARM, but I don't recall any FLARM showing traffic when stationary: even waiting on the second winch queue I don't recall the glider on the other cable showing as it launched nor a tow taking off on the far side of the field. Or, for that matter, landing gliders triggering it when I'm in the launch queue, so in front of and 100-200m to one side of the landing glider. Then again, none of these should trigger an alarm since a collision is not possible in any of these cases is a collision possible. OTOH, even a taxiing tug 2-300m away can trigger an alarm while I'm rolling up to the launch point after landing: very disconcerting it is too when it happens! But really: do it at the annual; do it when you are getting the glider ready for the 1st flight of the season. It's not that hard - write yourself notes if you can't remember. Couldn't agree more. I always used to do that and now its a mandatory item on the BGA-approved Annuals check-list. I also like to run an early flight from a new season through the FLARM trace analyser to check the range in all directions and make sure its working correctly and the antenna didn't get displaced during the last Annual. I tend to use Flarm interchangeably with PowerFlarm, but as a US pilot, PowerFlarm is what I have, and it does show the position of any PowerFlarm equipped glider within range, even if both gliders are stationary on the ground. It doesn't generate collision alarms it that situation. I should have added that I'm not surprised: to a first approximation on a gliding club field nothing with FLARM fitted moves unless its taking off, landing or is a tug taxiing, so there's little or no benefit in a stationery glider flagging up moving aircraft for its pilot. OTOH I can see that it would be useful for a Power Flarm to do so, especially one with ADS-B in since, on a field that is also used by powered aircraft, it would be able to flag up most? all? aircraft movements, especially those on approach while you're waiting at the hold point. -- -- Martin | martin at Gregorie | gregorie dot org |
Not to state the obvious, but please remember that the PIC is responsible for the proper working of all instruments in the aircraft. IF the PowerFLARM is not operative because of a pilot neglecting their duty to update the software per the manufacturer mandate, point the responsibility finger at the pilot.
91.213 Inoperative instruments and equipment. (d) Except for operations conducted in accordance with paragraph (a) or (c) of this section, a person may takeoff an aircraft in operations conducted under this part with inoperative instruments and equipment without an approved Minimum Equipment List provided - (3) The inoperative instruments and equipment are - (i) Removed from the aircraft, the cockpit control placarded, and the maintenance recorded in accordance with § 43.9 of this chapter; or (ii) Deactivated and placarded “Inoperative.” If deactivation of the inoperative instrument or equipment involves maintenance, it must be accomplished and recorded in accordance with part 43 of this chapter; and (4) A determination is made by a pilot, who is certificated and appropriately rated under part 61 of this chapter, or by a person, who is certificated and appropriately rated to perform maintenance on the aircraft, that the inoperative instrument or equipment does not constitute a hazard to the aircraft. |
At Area 51, Plenty of Invaders, No Aliens - area 51.jpg | Miloch | Aviation Photos | 0 | September 21st 19 07:16 PM |
Viral Area 51 raid amasses 1 million recruits, gets Air Force warning - area 51.png (1/3) | The 'Brightness' control still doesn't help | Aviation Photos | 0 | July 16th 19 10:57 AM |
Right seat NY area to Boca Raton area | doylflier | Piloting | 0 | May 30th 07 01:06 PM |
Another midair! | tango4 | Soaring | 3 | April 27th 04 06:14 PM |
Pix of two midair F-18s | Pechs1 | Naval Aviation | 9 | January 8th 04 02:40 PM |
