Andrzej Kobus wrote on 11/20/2020 5:57 PM:
On Friday, November 20, 2020 at 12:31:44 PM UTC-5, Eric Greenwell wrote: Moshe Braner wrote on 11/19/2020 2:12 PM: On 11/19/2020 1:21 PM, Eric Greenwell wrote: That looks to me like you can buy a license to activate the "B" antenna. Isn't that like I also agree with Dan that having to buy a license to activate the "B" antenna is ridiculous. Yes it's an optional feature, but it shouldn't be. They've already developed this feature and it's built into the device. And it is important for the safety benefit. That's different from some of the other optional features like IGC-certified logging, which are separate from the collision avoidance purpose, and they can make those who want that feature pay extra while keeping the price lower (?) for the rest. The B antenna is not required for safety in my glider. My ASH26E has two antennas in the nose (Flarm and ADSB), producing excellent range in most directions, and sufficient range to the rear for collision avoidance. I tried a B antenna on the belly, and it did improve the range at which I could detect other Flarm units, especially below. Since the unit already had sufficient range in all directions, the B antenna did not improve it's collision avoidance ability, and I removed it after 10 or so flights. I think my experience would apply to almost any Schleicher glider - they all use essentially the same fuselage, starting with the ASW24, which do not have carbon in the nose. That's a lot of gliders. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Eric, you wish what you wrote to be a fact, but in reality you can not have 100% in a glider that uses carbon and has only one antenna. I used to own ASH-26E with Flarm and from experience know there are blind spots. One flight in a competition gaggle would prove it for you. You will not be seen by others all the time and you will not see others all the time on your Flarm if you and they have only 1 antenna. The gaggles I've flown in did not expose those problems, perhaps because they have not been as dense as the worst contest gaggles sometimes are. Did your 26E have the antennas mounted in the nose? Where was the worst blind spot? In general, I would expect the signal strength from nearby gliders (+/- 500'vertically, 1000' horizontally) in a gaggle to overwhelm all but the very worst antenna placement. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On 11/21/2020 8:54 AM, Eric Greenwell wrote:
... In general, I would expect the signal strength from nearby gliders (+/- 500'vertically, 1000' horizontally) in a gaggle to overwhelm all but the very worst antenna placement. Good point. Receivers can be very sensitive. Years ago GPS receivers were finicky, had to put them outdoors for 15 minutes to get a fix, etc. Nowadays those in recent model cellphones work just fine on the passenger seat of a metal-body car. Note that the GPS satellites are generally low on the horizon. And very far away. Presumably the signals come in through windows and bounce around inside the car. No idea if the FLARM receivers are comparably sensitive. Nor whether carbon fiber reflects radio waves as well as sheet metal does. |
On Saturday, November 21, 2020 at 8:54:55 AM UTC-5, Eric Greenwell wrote:
Andrzej Kobus wrote on 11/20/2020 5:57 PM: On Friday, November 20, 2020 at 12:31:44 PM UTC-5, Eric Greenwell wrote: Moshe Braner wrote on 11/19/2020 2:12 PM: On 11/19/2020 1:21 PM, Eric Greenwell wrote: That looks to me like you can buy a license to activate the "B" antenna. Isn't that like I also agree with Dan that having to buy a license to activate the "B" antenna is ridiculous. Yes it's an optional feature, but it shouldn't be. They've already developed this feature and it's built into the device. And it is important for the safety benefit. That's different from some of the other optional features like IGC-certified logging, which are separate from the collision avoidance purpose, and they can make those who want that feature pay extra while keeping the price lower (?) for the rest. The B antenna is not required for safety in my glider. My ASH26E has two antennas in the nose (Flarm and ADSB), producing excellent range in most directions, and sufficient range to the rear for collision avoidance. I tried a B antenna on the belly, and it did improve the range at which I could detect other Flarm units, especially below. Since the unit already had sufficient range in all directions, the B antenna did not improve it's collision avoidance ability, and I removed it after 10 or so flights. I think my experience would apply to almost any Schleicher glider - they all use essentially the same fuselage, starting with the ASW24, which do not have carbon in the nose. That's a lot of gliders. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Eric, you wish what you wrote to be a fact, but in reality you can not have 100% in a glider that uses carbon and has only one antenna. I used to own ASH-26E with Flarm and from experience know there are blind spots. One flight in a competition gaggle would prove it for you. You will not be seen by others all the time and you will not see others all the time on your Flarm if you and they have only 1 antenna. The gaggles I've flown in did not expose those problems, perhaps because they have not been as dense as the worst contest gaggles sometimes are. Did your 26E have the antennas mounted in the nose? Where was the worst blind spot? In general, I would expect the signal strength from nearby gliders (+/- 500'vertically, 1000' horizontally) in a gaggle to overwhelm all but the very worst antenna placement. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 My antenna was mounted in the nose and the worst coverage was to the back, above the glider, very dangerous blind spot. I then moved the antenna to the glare shield, improved the above the glider and worsened below the glider.. Blind spot below the glider was more acceptable to me. |
Andrzej Kobus wrote on 11/21/2020 10:53 AM:
On Saturday, November 21, 2020 at 8:54:55 AM UTC-5, Eric Greenwell wrote: Andrzej Kobus wrote on 11/20/2020 5:57 PM: The B antenna is not required for safety in my glider. My ASH26E has two antennas in the nose (Flarm and ADSB), producing excellent range in most directions, and sufficient range to the rear for collision avoidance. I tried a B antenna on the belly, and it did improve the range at which I could detect other Flarm units, especially below. Since the unit already had sufficient range in all directions, the B antenna did not improve it's collision avoidance ability, and I removed it after 10 or so flights. I think my experience would apply to almost any Schleicher glider - they all use essentially the same fuselage, starting with the ASW24, which do not have carbon in the nose. That's a lot of gliders. Eric, you wish what you wrote to be a fact, but in reality you can not have 100% in a glider that uses carbon and has only one antenna. I used to own ASH-26E with Flarm and from experience know there are blind spots. One flight in a competition gaggle would prove it for you. You will not be seen by others all the time and you will not see others all the time on your Flarm if you and they have only 1 antenna. The gaggles I've flown in did not expose those problems, perhaps because they have not been as dense as the worst contest gaggles sometimes are. Did your 26E have the antennas mounted in the nose? Where was the worst blind spot? In general, I would expect the signal strength from nearby gliders (+/- 500'vertically, 1000' horizontally) in a gaggle to overwhelm all but the very worst antenna placement. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 My antenna was mounted in the nose and the worst coverage was to the back, above the glider, very dangerous blind spot. I then moved the antenna to the glare shield, improved the above the glider and worsened below the glider.. Blind spot below the glider was more acceptable to me. Curious. The behind and above has never been a dead spot for me, meaning "while thermaling gliders above and behind were always detected). No one has ever mentioned a problem seeing me from that position, either. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On 11/21/20 11:53 AM, Andrzej Kobus wrote:
On Saturday, November 21, 2020 at 8:54:55 AM UTC-5, Eric Greenwell wrote: Andrzej Kobus wrote on 11/20/2020 5:57 PM: On Friday, November 20, 2020 at 12:31:44 PM UTC-5, Eric Greenwell wrote: Moshe Braner wrote on 11/19/2020 2:12 PM: On 11/19/2020 1:21 PM, Eric Greenwell wrote: That looks to me like you can buy a license to activate the "B" antenna. Isn't that like I also agree with Dan that having to buy a license to activate the "B" antenna is ridiculous. Yes it's an optional feature, but it shouldn't be. They've already developed this feature and it's built into the device. And it is important for the safety benefit. That's different from some of the other optional features like IGC-certified logging, which are separate from the collision avoidance purpose, and they can make those who want that feature pay extra while keeping the price lower (?) for the rest. The B antenna is not required for safety in my glider. My ASH26E has two antennas in the nose (Flarm and ADSB), producing excellent range in most directions, and sufficient range to the rear for collision avoidance. I tried a B antenna on the belly, and it did improve the range at which I could detect other Flarm units, especially below. Since the unit already had sufficient range in all directions, the B antenna did not improve it's collision avoidance ability, and I removed it after 10 or so flights. I think my experience would apply to almost any Schleicher glider - they all use essentially the same fuselage, starting with the ASW24, which do not have carbon in the nose. That's a lot of gliders. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Eric, you wish what you wrote to be a fact, but in reality you can not have 100% in a glider that uses carbon and has only one antenna. I used to own ASH-26E with Flarm and from experience know there are blind spots. One flight in a competition gaggle would prove it for you. You will not be seen by others all the time and you will not see others all the time on your Flarm if you and they have only 1 antenna. The gaggles I've flown in did not expose those problems, perhaps because they have not been as dense as the worst contest gaggles sometimes are. Did your 26E have the antennas mounted in the nose? Where was the worst blind spot? In general, I would expect the signal strength from nearby gliders (+/- 500'vertically, 1000' horizontally) in a gaggle to overwhelm all but the very worst antenna placement. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 My antenna was mounted in the nose and the worst coverage was to the back, above the glider, very dangerous blind spot. I then moved the antenna to the glare shield, improved the above the glider and worsened below the glider. Blind spot below the glider was more acceptable to me. I have the A antenna on the glare shield and an external blade B antenna under the nose bowl of the Stemme. Below is much improved since moving the B antenna to the bottom but, due to the curvature of the lower fuselage, the aft view is not as good as it could be if the antenna was aft of the landing gear. -- Dan 5J |
I just heard from Flarm about the Fusion. It transmits and receives on both A and B!
Yes. There are no FCC regulations against transmitting on both radios. This is how Fusion was FCC certified. Richard www.craggyaero.com |
Good to hear. Does that mean the Core 1.1 is also allowed to transmit (and doing so) on both antennas in the US and Canada?
On Sunday, November 22, 2020 at 3:44:51 PM UTC-8, wrote:
Good to hear. Does that mean the Core 1.1 is also allowed to transmit (and doing so) on both antennas in the US and Canada? Not for the PowerFlarm Core as it was not FCC Certified with that configuration. Richard www.craggyaero.com |
$1526 For this new Flarm unit is a good deal.
If you don't have Flarm in your plane, nows the time. It Works and works great. Nick T |
Xian JH-7 pics 2 [5/7] - JH-7B is an advanced version of JH-7A. It has stealthier features compared to JH-7A..jpg (1/1) | Miloch | Aviation Photos | 0 | August 16th 18 02:41 PM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM protocol version 6 | kirk.stant | Soaring | 17 | September 8th 12 10:03 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
Any news on the "brick" version of PowerFlarm from the SSA convention? | Andrzej Kobus | Soaring | 7 | February 8th 12 04:29 PM |
