Identifying a Canopy Blank's Glider Model
Old December 2nd 20, 06:15 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Identifying a Canopy Blank's Glider Model
JJ,
The RV-3 is exclusively a single seater with a rear canopy (two piece version) that could be what I have. There are also several other RV models that have a "centerline" seating arrangement and two piece canopies. See https://www.vansaircraft.com/which-rv-is-right-for-me/.
In the next few days I will have more/better pictures and more/better measurements. I will then ask for help with this identification conundrum from RV groups.
Maybe I will get really, really, lucky I'll find out its a P-51 canopy. Cha-ching!
Thanks, John (OHM)
Old December 2nd 20, 10:17 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
John,
I am betting on Diamant. I have an RV-3 canopy in my garage, and it looks nothing like that. RV-3 canopy is blown bubble, with sort of a teardrop shape when viewed from above. Side view of the RV canopy, rises rapidly at one end, long, slow taper off to the pointier end. This looks to go up from the rounded end, then go closer to flat.
If the window cutout is level with the bottom, it is a Diamant canopy. If it is at a noticeable angle, it is likely an ASW-12 canopy.
P-51 canopy would be MUCH thicker, and would have flats with near 90 degree corners at the "open" end.
Steve Leonard
Old December 7th 20, 03:28 PM posted to rec.aviation.soaring
I took some additional pictures. See https://link.shutterfly.com/qI0hDPifPbb.
Some additional clues;
- I was wrong. The window does in fact have additional holes for the rails of a sliding Mecaplex-type window.
- The bottom of the canopy is not flat tip to tail.Â* Towards the "aft" (I think) end of the canopy the bottom edge tilts upward.Â* However the bottom edge of this portion is flat and does not have the curve of a leading edge. See two of the new pictures for reference.
Well, its not for a Diamant based on some Google image searching. This sailplane's canopy bottom is perfectly flat and has distinct large radius rounded transition to the vertical aft end. See https://en.wikipedia.org/wiki/FFA_Di...amant_16.5.jpg.
It seems to definitely not be of the DG lineage due to the angle of the aft end. DG's are almost vertical.
It is possible that it is for an ASW-12 (single piece canopy type) as it has the correct general shape. This model has a "DG" look to it with a pedestal type instrument pod. See https://www.alexander-schleicher.de/...leben-erweckt/.
Any more glider models that use a looooong tip-to-toe canopy?Â* I would sure hate to throw this nice "NOS" canopy out.
Thanks, John OHM
Old December 7th 20, 05:26 PM posted to rec.aviation.soaring
Mark Grubb
Give it to Mr. Leonard!
If he does not own a glider that it fits, it will give him an excuse to purchase a new model. As if he needed an excuse. . And he owns AS-W12's.
Old December 9th 20, 03:15 AM posted to rec.aviation.soaring
Steve Leonard identified this canopy as for an ASW12. It turns out that the two piece canopy of an ASW12 begins life as one long canopy.
Thanks to all that helped with this mystery.
glider canopy Morris Carter Soaring 7 February 13th 20 11:13 PM
Escaping glider on the ground with stuck canopy? Steve Koerner Soaring 27 May 21st 19 04:06 AM
Std Libelle Low profile canopy blank [email protected] Soaring 0 November 7th 15 09:35 PM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 01:16 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
