https://www.becker-avionics.com/
They were great when I had trouble with mine. DC On Friday, December 4, 2020 at 8:32:08 AM UTC-5, wrote: Been around aviation a long time but a newbie to the soaring community Helping a friend sort out some issues in a motor glider The Becker 3200 com radio suddenly failed. Was working fine and on the next flight nothing after starting up the engine. Will not power up. I verified that it is getting power to the radio. The tach also mysteriously died and the fuse on the vario blew. I suspect an over voltage problem but have not finished diagnostics. Any recommendations on a shop to send the Becker radio to? Bill |
Becker USA - but I am not certain they can still repair the old 32 series radios!
+1 (954) 450-3137 10376 USA Today Way Miramar, Fl 33025, USA |
The Becker radios have an internal fuse which can easily blow from the surge if you start or stop the engine with the radio turned on. Make sure the radio is off before doing so. When the internal fuse blows, the only option is to send it to Becker at the above listed address. They will replace the fuse and send it back to you pretty fast.
On 12/4/2020 8:25 PM, Jim Lee wrote:
The Becker radios have an internal fuse which can easily blow from the surge if you start or stop the engine with the radio turned on. Make sure the radio is off before doing so. When the internal fuse blows, the only option is to send it to Becker at the above listed address. They will replace the fuse and send it back to you pretty fast. I am puzzled by that. Why would an overvoltage surge, even if it is up to, say, 20 volts, blow a fuse? Especially if the radio is not transmitting at the time. Voltage only causes current if something accepts it. (Unless that radio has protection circuitry that does that on purpose.) The OP said "The tach also mysteriously died and the fuse on the vario blew". That, together with the radio problem, suggests that something much worse than an overvoltage surge happened. Or is one supposed to disconnect the tach too before starting the engine? "Was working fine and on the next flight nothing after starting up the engine." - Was it working on the same flight before starting the engine? If not, I wonder what happened between flights. Battery briefly connected in reverse polarity? Once that other issue is (or has been) cleared, then indeed the radio may need service. |
On 05/12/2020 14:19, Moshe Braner wrote:
On 12/4/2020 8:25 PM, Jim Lee wrote: The Becker radios have an internal fuse which can easily blow from the surge if you start or stop the engine with the radio turned on.Â* Make sure the radio is off before doing so.Â* When the internal fuse blows, the only option is to send it to Becker at the above listed address. They will replace the fuse and send it back to you pretty fast. I am puzzled by that.Â* Why would an overvoltage surge, even if it is up to, say, 20 volts, blow a fuse?Â* Especially if the radio is not transmitting at the time.Â* Voltage only causes current if something accepts it.Â* (Unless that radio has protection circuitry that does that on purpose.) The OP said "The tach also mysteriously died and the fuse on the vario blew".Â* That, together with the radio problem, suggests that something much worse than an overvoltage surge happened.Â* Or is one supposed to disconnect the tach too before starting the engine? "Was working fine and on the next flight nothing after starting up the engine."Â* - Was it working on the same flight before starting the engine?Â* If not, I wonder what happened between flights.Â* Battery briefly connected in reverse polarity? Once that other issue is (or has been) cleared, then indeed the radio may need service. There may be over-voltage protection in the form of a Crowbar circuit which shorts out the input if a set voltage is exceeded. |
I list all the US repair shops that I know of for transceiver/transponder manufacturers in my troubleshooting presentation found at http://aviation.derosaweb.net/presen...s/#transceiver. If you know of any others, please let me know. Thanks.
The Becker repair shops in the US are; Gulf Coast Avionics Corp. • http://www.GulfCoastAvionics.com • 3650 Drane Field Road, Lakeland, FL 33811 • Phone: 863-709-9714 • Email: Mid Continent Instruments and Avionics • http://www.mcico.com • 9400 East 34th Street North, Wichita KS 67226 • Phone: 800-821-1212, 316-630-0101 • Email: Enjoy, John OHM |
On Sunday, December 6, 2020 at 6:18:30 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
I list all the US repair shops that I know of for transceiver/transponder manufacturers in my troubleshooting presentation found at http://aviation.derosaweb.net/presen...s/#transceiver. If you know of any others, please let me know. Thanks. The Becker repair shops in the US are; Gulf Coast Avionics Corp. • http://www.GulfCoastAvionics.com • 3650 Drane Field Road, Lakeland, FL 33811 • Phone: 863-709-9714 • Email: Mid Continent Instruments and Avionics • http://www.mcico.com • 9400 East 34th Street North, Wichita KS 67226 • Phone: 800-821-1212, 316-630-0101 • Email: Enjoy, John OHM Contact Becker in ft. Lauderdale, speak with Alex, these guys are the factor repair station. |
| Thread Tools | |
| Display Modes | |
| FS: 4 Becker 4201 Radio | Ross[_3_] | Soaring | 3 | May 24th 17 10:19 PM |
| Shop/ Installer recommendation please? | andy | Piloting | 4 | April 29th 06 12:23 AM |
| Becker 3201 Radio | [email protected] | Soaring | 8 | December 8th 05 04:08 PM |
| Becker radio AD | Tom Serkowski | Soaring | 3 | November 2nd 04 02:43 AM |
| Recommendation for Radio, transponder and Altimeter | Ron Natalie | Home Built | 0 | July 8th 03 04:40 PM |
