On Tuesday, December 15, 2020 at 6:51:42 AM UTC-5, wrote:
After installation and testing are complete, take a flight and the check your FAA performance report he https://adsbperformance.faa.gov/PAPRRequest.aspx Mine flunked the first time. I had one of the configuration settings wrong, but it was easily sorted out with information provided by Prof. Pfiffner: http://www.craggyaero.com/tt22_tn72_settings.htm Cheers, ...david On Tuesday, December 15, 2020 at 5:02:52 AM UTC-5, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. I am thinking of installing a TRIG xponder for next season, maybe with ADS-B, but this would mean installing multiple GPS antennas (FLARM, C302, Xponder) and I'm running out of room under the glareshield. Questions for the experts out the need there be a minimum spacing between GPS antennas (i.e. do they interact); and is there a way to connect one GPS antenna to feed one or more boxes? Thanks! Ian IN |
On Tuesday, December 15, 2020 at 7:53:22 AM UTC-5, India November wrote:
On Tuesday, December 15, 2020 at 6:51:42 AM UTC-5, wrote: After installation and testing are complete, take a flight and the check your FAA performance report he https://adsbperformance.faa.gov/PAPRRequest.aspx Mine flunked the first time. I had one of the configuration settings wrong, but it was easily sorted out with information provided by Prof. Pfiffner: http://www.craggyaero.com/tt22_tn72_settings.htm Cheers, ...david On Tuesday, December 15, 2020 at 5:02:52 AM UTC-5, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. I am thinking of installing a TRIG xponder for next season, maybe with ADS-B, but this would mean installing multiple GPS antennas (FLARM, C302, Xponder) and I'm running out of room under the glareshield. Questions for the experts out the need there be a minimum spacing between GPS antennas (i.e. do they interact); and is there a way to connect one GPS antenna to feed one or more boxes? Thanks! Ian IN Relative to multiple GPS antennas under the glare shield, I'm afraid nothing is simple in this world. I have a standard category install (TRIG TN 70, big TA 70 GPS antenna), plus two other GPS antennas (FLARM, LX9000) about 6 inches away. No ill effects noted on anything after a good season of flying. I originally was leaning towards a splitter, but decided to try separate antennas first after considering the following. You can get splitters/combiners/hybrids, but necessarily will lose ~4dB per 'split'. The GPS antennas are active, so each receiver will put a few volts DC on the coaxial antenna cable to power the amplifier integrated into the antenna. With multiple receivers you need a DC coupled branch on the splitter for only one receiver, and DC blocks on the other branches. Once you have this figured out, you need to look at the receiver specifications, since some interpret an open DC circuit as an antenna fault. Simple, huh? Cheers, Brian MM |
Maxim Magazine soaring article | [email protected] | Soaring | 15 | April 1st 17 05:40 PM |
October Soaring magazine OLC League article | Mark628CA | Soaring | 22 | October 11th 14 05:51 PM |
Need help locating article from Soaring Magazine | Tim Taylor | Soaring | 1 | March 26th 10 10:57 AM |
Need help locating article from Soaring Magazine | Tim Taylor | Soaring | 0 | March 24th 10 01:20 AM |
Subaru magazine soaring article | JS | Soaring | 9 | March 21st 08 03:41 AM |
