On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote:
On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks |
On 12/15/20 10:15 AM, wrote:
On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote: On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks If your DG303 is experimental, then get the TN72 GPS and TA50 antenna. Those are what I installed in my gyro and they work perfectly. No need to buy the gigantic TA70 antenna which is a pain to mount and costs a bunch more. I mounted my TA50 antenna on the glare shield of the gyro using the sticky back tape that came with it. It hasn't moved in 150 hours of flying plus ground ops. -- Dan 5J |
On Tuesday, December 15, 2020 at 1:34:24 PM UTC-5, Dan Marotta wrote:
On 12/15/20 10:15 AM, wrote: On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote: On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks If your DG303 is experimental, then get the TN72 GPS and TA50 antenna. Those are what I installed in my gyro and they work perfectly. No need to buy the gigantic TA70 antenna which is a pain to mount and costs a bunch more. I mounted my TA50 antenna on the glare shield of the gyro using the sticky back tape that came with it. It hasn't moved in 150 hours of flying plus ground ops. -- Dan 5J Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so. |
On Tuesday, December 15, 2020 at 7:56:09 PM UTC-6, wrote:
On Tuesday, December 15, 2020 at 1:34:24 PM UTC-5, Dan Marotta wrote: On 12/15/20 10:15 AM, wrote: On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote: On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks If your DG303 is experimental, then get the TN72 GPS and TA50 antenna. Those are what I installed in my gyro and they work perfectly. No need to buy the gigantic TA70 antenna which is a pain to mount and costs a bunch more. I mounted my TA50 antenna on the glare shield of the gyro using the sticky back tape that came with it. It hasn't moved in 150 hours of flying plus ground ops. -- Dan 5J Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so. It was my article and install in Soaring. I have lots more pictures and some great wiring diagrams made by John DeRosa, email me or call with any questions or help needed. Greg Palmer 847-922-1234 |
On Tuesday, December 15, 2020 at 5:56:09 PM UTC-8, wrote:
On Tuesday, December 15, 2020 at 1:34:24 PM UTC-5, Dan Marotta wrote: On 12/15/20 10:15 AM, wrote: On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote: On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks If your DG303 is experimental, then get the TN72 GPS and TA50 antenna. Those are what I installed in my gyro and they work perfectly. No need to buy the gigantic TA70 antenna which is a pain to mount and costs a bunch more. I mounted my TA50 antenna on the glare shield of the gyro using the sticky back tape that came with it. It hasn't moved in 150 hours of flying plus ground ops. -- Dan 5J Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so. I had the ADS-B out option installed on my ASH31Mi using the TT22 and the TN72, and highly recommend it. You will be much more visible to both ATC and airliners with TCAS. A big bonus is the power consumption of this pair is very low. I only wish this was permitted for certificated gliders. Tom |
On Saturday, December 19, 2020 at 5:14:23 PM UTC-5, 2G wrote:
On Tuesday, December 15, 2020 at 5:56:09 PM UTC-8, wrote: On Tuesday, December 15, 2020 at 1:34:24 PM UTC-5, Dan Marotta wrote: On 12/15/20 10:15 AM, wrote: On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote: On 12/15/20 3:02 AM, wrote: A few random notes from my TT22 installation: - From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power." -- A proven hazard demonstrated (luckily) by someone else - Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place.. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on. - If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed. -- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers. Good information about the firmware. I had to send the control head for the TT22 in the Stemme to the avionics shop for upgrade. There was no charge for the service IIRC. -- Dan 5J Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article. Thanks If your DG303 is experimental, then get the TN72 GPS and TA50 antenna.. Those are what I installed in my gyro and they work perfectly. No need to buy the gigantic TA70 antenna which is a pain to mount and costs a bunch more. I mounted my TA50 antenna on the glare shield of the gyro using the sticky back tape that came with it. It hasn't moved in 150 hours of flying plus ground ops. -- Dan 5J Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so. I had the ADS-B out option installed on my ASH31Mi using the TT22 and the TN72, and highly recommend it. You will be much more visible to both ATC and airliners with TCAS. A big bonus is the power consumption of this pair is very low. I only wish this was permitted for certificated gliders. Tom Yes. I'm definitely interested in pursuing this... thanks for all the info and help. Gregg. I'm sure I'll be in touch once the holidays settle down a little bit, this has been put on the backburner during the holidays. I always thought adding a transponder would be a good idea, but after a much more closer than comfortable encounter with another aircraft that I'm sure never saw me, it has become a priority. Adding the ADS-B out unit is in rhe plans as well. |
Should I assume it is not legal in the US to use a TT21 with a TN72 for ADS-B out in an experimental glider? That combination is ok in Europe (I think) with the difference being the US wants 2x the xmit power for ADS-B (TT22 at 250W) vs the 125W output of the TT21. I would like to think that having otherwise compliant, lower power ADS-B out is better (and not illegal) than no ADS-B out in an aircraft that is legal without ADS-B.
Probably not a realistic hope - but it would save me the not trivial expense of upgrading my TT21 to a TT22. JJ |
Get the TT22. Don't consider the TT21. It could save you about $150 on a $2500 USD purchase but does not provide full ADS-B compliance. In the USA this means a TT21 does not allow you to fly in transponder-required airspace. The TT22 provides a full ADS-B out solution and more transmit power, yet its power consumption is identical to the TT21, according to Trig's spec sheets.
For an experimental glider you can use the same GPS receiver and antenna that you would find in a TT21 ADS-B out package (Trig TN72 and Trig TA50), so the only added cost is the $150 to upgrade to the TT22. ...david On Monday, December 21, 2020 at 7:19:22 PM UTC-5, John Johnson wrote: Should I assume it is not legal in the US to use a TT21 with a TN72 for ADS-B out in an experimental glider? That combination is ok in Europe (I think) with the difference being the US wants 2x the xmit power for ADS-B (TT22 at 250W) vs the 125W output of the TT21. I would like to think that having otherwise compliant, lower power ADS-B out is better (and not illegal) than no ADS-B out in an aircraft that is legal without ADS-B. Probably not a realistic hope - but it would save me the not trivial expense of upgrading my TT21 to a TT22. JJ |
On 12/21/20 5:19 PM, John Johnson wrote:
Should I assume it is not legal in the US to use a TT21 with a TN72 for ADS-B out in an experimental glider? That combination is ok in Europe (I think) with the difference being the US wants 2x the xmit power for ADS-B (TT22 at 250W) vs the 125W output of the TT21. I would like to think that having otherwise compliant, lower power ADS-B out is better (and not illegal) than no ADS-B out in an aircraft that is legal without ADS-B. Probably not a realistic hope - but it would save me the not trivial expense of upgrading my TT21 to a TT22. JJ I don't see why you couldn't use the TT21, but the price difference between the TT22 and the TT21 is only $157. Why wouldn't you go for the higher power and legality above 15,000'? Rather than upgrade, why not sell the 21 and buy a 22? -- Dan 5J |
Maxim Magazine soaring article | [email protected] | Soaring | 15 | April 1st 17 05:40 PM |
October Soaring magazine OLC League article | Mark628CA | Soaring | 22 | October 11th 14 05:51 PM |
Need help locating article from Soaring Magazine | Tim Taylor | Soaring | 1 | March 26th 10 10:57 AM |
Need help locating article from Soaring Magazine | Tim Taylor | Soaring | 0 | March 24th 10 01:20 AM |
Subaru magazine soaring article | JS | Soaring | 9 | March 21st 08 03:41 AM |
