On 9/4/03 4:24 AM, in article , "Errol Cavit"
wrote: "Doug "Woody" and Erin Beal" wrote in message ... SNIP As I understand it, the US Navy ocasionally transits through Sunda Strait (Sumatera/Java) and Lambok Strait (Bali/Lombok), claiming they are 'International Straits'. Both transits require going within 12nm of Indonesian land. I doubt that flying operations stop for the few dozen miles that they are reasonably close to land. Three points: 1. It's been so long since I've done a WESTPAC, I don't remember all the strait transits. The last two passages I remember were Malacha and Hormuz. I don't remember Sunda or Lambak per se. May be showing my geographic ignorance here--either that or we didn't go there. 2. Interestingly enough, international law makes an exception for straights. In other words, if the strait is less than 12 miles wide, it may still be international waters/airspace. I had never considered this possibility until some lawyer briefed me up on it. There's a fancy name to it too. Lawyers (or sea lawyers) feel free to jump in. 3. Flight ops usually do stop if the waters are restrictive depending on winds and airspace constraints. The CV sprints through the restrictive waters and flies again when they open up. In any case, when a carrier does operate near land, Only when it must. every attempt is made to respect commercial airways in both laterally and in altitude. Otherwise aircraft operate in "due regard..." That is essentially, "we'll all share the same piece of sky and try to stay out of each other's way even though there are no formal procedures to keep that from happening." These incidents do happen occasionally. They're not a big deal... Unless the media trump them up as such. It's a situation with a lot of possibilities for tension. |
