Service Ceiling L23 - Litigation
Old December 18th 20, 04:03 AM posted to rec.aviation.soaring
Default Service Ceiling L23 - Litigation
Thank you for the responses.
I could not find anything to support counsel's mendacious claim that the aicraft was towed or flown above any restriction either by the manufacturer or by the FAA. The evidence seems to support your opinion, Tom, that she got into sink and did not correct accordingly. Why was she so far out of trim? 45 degrees in the front seat isn't something you wouldn't notice from the back.
Old December 18th 20, 03:48 PM posted to rec.aviation.soaring
Stuart Venters
There is a mention of 12-5 in the accident report interviews.
https://data.ntsb.gov/Docket/Documen...%20-Master.PDF
Page 104 line 3 regarding the length or glider flights.
3 A. It would be to be 2 hours. But that being said, even if it
4 is, we're never above 12-5 for more than 30 minutes due to the
5 oxygen requirements. So we have that kind of ceiling.
Old December 19th 20, 10:08 PM posted to rec.aviation.soaring
2G
By "trim" I assume that you mean rudder coordination and not nose-down trim.. I assume that there is a yaw string for the back seat as the front yaw string would not be visible to the pilot. She was both allowing airspeed to bleed off to dangerously slow levels and not monitoring control coordination.. It is puzzling why, after twice saying "This is not good" that she didn't turn back to the airport.
The lawyer is probably not a pilot and may have interpreted the O2 altitude limitation to be an airframe limitation. He has plenty of malfeasances to hold Teton Aviation's feet to the fire, however.
Tom
Old December 19th 20, 11:01 PM posted to rec.aviation.soaring
Tango Eight
By "trim" I assume that you mean rudder coordination and not nose-down trim. I assume that there is a yaw string for the back seat as the front yaw string would not be visible to the pilot. She was both allowing airspeed to bleed off to dangerously slow levels and not monitoring control coordination. It is puzzling why, after twice saying "This is not good" that she didn't turn back to the airport.
Tom
Look through the photos in item 30 on the docket linked earlier in the thread (still frames from video the passenger was recording in the moments before the crash), it's very strange. Ridge on the left, very close aboard (less than 100 feet is my guess), left bank about 30 degrees, yaw string indicating what appears to be full right rudder. The full video would probably provide additional insight. The last two frames, 9 seconds apart, don't show evidence of a rapid descent... comparing the two views with the ridge line and considering the severe uncoordinated flight condition, I would guess the glider is flying in lift.
More questions than answers.
T8
Old December 20th 20, 06:43 AM posted to rec.aviation.soaring
Grand Teton is 13,776 ft. Icefloe Lake is 10,652 ft. If the first frame began at release altitude then they were slightly below and to the south of the summit of Grand Teton. In 3:09 they lost 3100 feet give or take.
https://www.youtube.com/watch?v=lvWNkP-NzAQ
Old December 20th 20, 01:56 PM posted to rec.aviation.soaring
Tango Eight
The saddle of the ridgeline level with the glider Figure 7, time stamp 3:06, is 11,500. It doesn't look like there was any altitude loss to speak of, and perhaps a small gain between 2:57 and 3:06.
If a spin event happened shortly after 3:06, it may not have happened like in the linked video. When stalled in a full rudder over slipping turn of 30 degrees bank, the L-23 spins into the low wing, -against- the rudder. The entry looks similar to Figure 7 (but desirably without rocks). In that case, expect an excursion to 60 degrees nose low pitch, about 180 degrees of (slow) auto rotation before recovery and a few hundred feet of altitude lost. I have done many times with students as a part of a lesson on slips and slipping turns.
T8
Old December 20th 20, 05:02 PM posted to rec.aviation.soaring
jp
T8
That is very helpful information Tango. I'll have to try that. I've thought that in an uncoordinated stall the aircraft will roll "to the rudder", not against the rudder. So, in the example you describe I would have thought that the "outside" wing, in this case the high wing, would be in the wind shadow of the fuselage and so would stall first thereby having the aircraft roll to that wing - sometimes called "over the top". On the other hand I have not flown an L-23. Also, maybe the 30 degree bank makes a difference.. I have been wrong in a very important circumstance.
Old December 20th 20, 06:56 PM posted to rec.aviation.soaring
2G
T8
If you look at the photos of the accident site it is apparent that there was not that much altitude loss between spin entry and impact, perhaps 500 - 1000 feet. Yes, the full video would be very helpful in analyzing the sequence of events. Certainly, the lawyers have access to it, which no doubt will be presented at trial (assuming it goes to trial).
Tom
Max Service ceiling for commercial airplanes [email protected] Piloting 64 January 31st 08 09:03 AM
Camera Litigation in UK [email protected] Soaring 12 January 28th 06 07:16 PM
A Service ceiling question (Piper 235) falcon Owning 0 December 6th 04 10:28 PM
A Service ceiling question (Piper 235) falcon Piloting 0 December 6th 04 10:28 PM
service ceiling of F-22 zxcv Military Aviation 7 March 14th 04 10:31 PM
