krasw wrote on 12/29/2020 10:36 AM:
On Tuesday, 29 December 2020 at 18:52:35 UTC+2, jfitch wrote: I'd be amazed if you had room for a Victron in your glider. Both Victron and Genasun make generally good stuff. From the data sheets, the Victron efficiency is "98% peak" and the Genasun is "94 - 99.85% typical". These are effectively the same. What do you find appalling? On Tuesday, December 29, 2020 at 8:03:58 AM UTC-8, Soartech wrote: On Tuesday, December 29, 2020 at 10:42:19 AM UTC-5, krasw wrote: Any ideas for Strobl controller replacement? The voltage is not enough for LFP battery. Victron SmartSolar MPPT 75/10 looks good, but according to specs Strobl solar cell voltage is not enough to start the unit (!). Genasun has appalling efficiency. We need more info: how many Volts does your cell put out? What is the battery type and size in Watt-hours? What aircraft is this on? Genasun consumes 150mA, six times more than Victron (25 mA). My solar panel produces 550mA (via Strobl controller). Genasun robs almost third of the panel produced power. The Genasum datasheet say 0.150 ma (150 ua), so much less power consumed than the Victron. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Tuesday, 29 December 2020 at 21:27:37 UTC+2, Eric Greenwell wrote:
krasw wrote on 12/29/2020 10:36 AM: On Tuesday, 29 December 2020 at 18:52:35 UTC+2, jfitch wrote: I'd be amazed if you had room for a Victron in your glider. Both Victron and Genasun make generally good stuff. From the data sheets, the Victron efficiency is "98% peak" and the Genasun is "94 - 99.85% typical". These are effectively the same. What do you find appalling? On Tuesday, December 29, 2020 at 8:03:58 AM UTC-8, Soartech wrote: On Tuesday, December 29, 2020 at 10:42:19 AM UTC-5, krasw wrote: Any ideas for Strobl controller replacement? The voltage is not enough for LFP battery. Victron SmartSolar MPPT 75/10 looks good, but according to specs Strobl solar cell voltage is not enough to start the unit (!). Genasun has appalling efficiency. We need more info: how many Volts does your cell put out? What is the battery type and size in Watt-hours? What aircraft is this on? Genasun consumes 150mA, six times more than Victron (25 mA). My solar panel produces 550mA (via Strobl controller). Genasun robs almost third of the panel produced power. The Genasum datasheet say 0.150 ma (150 ua), so much less power consumed than the Victron. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 Thanks, I should probably learn to read. |
Any interference from the Genasun LFP solar charger controller? | jfitch | Soaring | 2 | May 18th 18 03:41 AM |
Strobl Solar Charge Controller | Doug[_9_] | Soaring | 0 | June 22nd 17 09:55 PM |
Flexible solar panel deal | Soartech | Soaring | 5 | June 15th 16 08:26 PM |
Connecting my 2 Batteries to 1 Solar Panel | Dan G[_2_] | Soaring | 14 | January 5th 13 11:12 PM |
sizing solar panel | Udo Rumpf | Soaring | 18 | February 17th 06 01:36 AM |
