SiO2 (Ceramic wax) on sailplanes ?
Old January 8th 21, 04:53 PM posted to rec.aviation.soaring
Default SiO2 (Ceramic wax) on sailplanes ?
On Thursday, 7 January 2021 at 23:19:11 UTC, MMOORE wrote:
The new SiO2 spray on/buff off waxes for cars are amazing. Anyone use this on glass sailplanes ?
It is a silica
SiO2 is silica, the main ingredient of sand and also of quartz.
"Silicones" names a class of substances containing the element Silicon (amongst others), which are commonly used as polishes. They are sometimes a component of "Ceramic Wax".
I am no expert on composite repairs, but the conjunction of "fibreglass" or "gel-coat" with "silicone" rings alarm bells for me!
J.
Old January 8th 21, 05:20 PM posted to rec.aviation.soaring
Dennis Cavagnaro
It is a silica
J.
I used a meguiars wax spray Ceramic and am very happy with the results. Works differently then silicones.
DC
Old January 8th 21, 06:26 PM posted to rec.aviation.soaring
Nobody is questioning the efficacy, either on cars or on gliders.
My warning was about difficulties with subsequent repairs on fibreglass or gelcoat (as in gliders).
But I could be wrong. You may feel it's worth the risk. Or you could take the advice of your local friendly glider repairer!
J.
Old January 12th 21, 01:20 PM posted to rec.aviation.soaring
Chris Runeckles
J.
There is a difference between Silica ( Silicon) and Silicone do not confuse the two.
I have been Using 3M Cleaner and Wax a marine product to protect my gliders for many years it works well and seems to protect the surface, I own a Ventus2 CXa that is now 10 years old and is showing no signs of the Dreaded Gellcoat failure.
3M also make a restorer and wax is which is similar but a bit more cutting compound for rejuvenation of flat gell coat.
Chris Runeckles
Western Australian Sailplane products
Ceramic Sealants Dennis Cavagnaro Soaring 2 July 2nd 20 07:49 AM
Ads-b and sailplanes Andrew Ainslie Soaring 110 May 9th 15 05:03 AM
LS-1 sailplanes in the USA Burt Compton - Marfa Soaring 2 November 2nd 10 12:08 AM
Please ID 3 sailplanes Every time Soaring 4 August 20th 08 09:34 PM
50+:1 15m sailplanes Paul T Soaring 92 January 19th 04 01:59 AM
