First glider Nimbus 2 ?
Old January 11th 21, 09:53 PM posted to rec.aviation.soaring
Piotr Mis
Default First glider Nimbus 2 ?
poniedziaÅ‚ek, 11 stycznia 2021 oÂ*10:31:05 UTC+1 napisaÅ‚(a):
Ultimately, it's still your own decision what you buy, and depending on your skill, your club or CFI might allow it.
At our club, we have some pretty high demands. In order to fly solo on our Duo Discus, you need 75 hours solo, LS4 is 40 hours. If you were to buy something like Std Cirrus, Libelle or LS4, you need to have flown over 40 hours and at least 5 flights with the clubs LS4's. If you were to buy a flapped glider like Mosquito, PIK20, Mini Nimbus, you need to be solo on our Duo Discus (so 75 hours solo flight total) and flown at least 5 flights with a flapped glider in double with an instructor. Since we don't have a flapped glider owned by the club, there is a private Arcus owned by an instructor who you can pay to train.
Hi
thanks for making an interesting point. I had already tried to figure this out and I spoke with the head of the gliding section of our flying club to make sure I won't get in trouble (I had mentioned to him I was going to buy my own glider but at that time wasn't planning to get Nimbus). He told me that as long as glider would be formally proven to be airworty, would have all valid papers etc, the choice of is solely up to the owner and no restrictions are imposed by the club. He told me that Nimbus may not be the best choice, but neither did he tell me that I was completely crazy....
Purchase is not yet made because COVID restrictions keep me in my country. I am also considering 15m gliders but for the budget I have, I don't see anything worth attention at the moment. No matter what the outcome of all that will be, getting all those comments/advice from more experienced pilots is a great value in itself....
Old January 11th 21, 11:50 PM posted to rec.aviation.soaring
John Foster
Hi
Purchase is not yet made because COVID restrictions keep me in my country.. I am also considering 15m gliders but for the budget I have, I don't see anything worth attention at the moment. No matter what the outcome of all that will be, getting all those comments/advice from more experienced pilots is a great value in itself....
I may be WAY off-base here, but one thing you may consider, is to get Condor 2 and play around with some of the gliders, particularly the longer wing-span ones like the JS1 and EB29, so you can see how long-winged gliders handle on the ground. I know these are nothing like the Nimbus 2, and in fact, I think the only one that remotely comes close would be the Standard Cirrus with its all-flying tail. Just something to consider. But again, I may be way off here.
Old January 12th 21, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
Default Condor Question
Regarding advice given on buying a Nimbus 2 as a first glider: It's
been over 40 years, but I seem to recall a series of partial
differential equations which describe the flight characteristics of an
aircraft.
I wonder, do the developers of Condor have access to these equations for
each aircraft that they model and, if so, how did they get them? Or are
they simply making a guess as to how a particular glider actually performs?
Dan
5J
Old January 12th 21, 01:05 AM posted to rec.aviation.soaring
Frank Whiteley
Hi
I was under the impression that Poland was full of Jantars. at least at one time. I had a share of a Jantar Std 2 and it had pretty honest performance and was very comfortable though the reach to the panel was a stretch. It seems to fit long pilots and has a tall undercarriage which is good for out landings. Certainly capable of XC flying and usually good performance for the price.
Frank Whiteley
Old January 12th 21, 05:34 AM posted to rec.aviation.soaring
BG[_4_]
I can share an experience in my club that points to the need to control private pilots with low time flying aircraft they are not ready for. This person bought a ASW 20 right after their solo endorsement and nearly killed himself on the flight while we watched in horror. He did a very low energy skidding turn to final and entered a spin about one wingspan from the ground. The plane impacted the ground going sideways. Had he been higher, it would have likely be a fatal accident. He was banned from the club and never got another tow from us. Who a club tows is in their control.
Another issue is the risk you are imposing on the tow pilot. Most of these older ships have CG hooks that provide little help in directional control. Kiting is also a killer. My club lost a towpilot this last year due to kiting.
BG
Old January 12th 21, 11:33 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Does your club own any benign single seat gliders, e.g. a 1-26, Ka-8 or
Junior that new solo pilots can transition to?
If not, what guidance or rules does your club have to protect early solo
pilots (and tuggies) from the sort of incident you describe? If nobody
pointed out why buying an ASW-20 was a really bad idea for a new solo,
then banning him sounds rather harsh.
Martin | martin at
Gregorie | gregorie dot org
Old January 12th 21, 07:02 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
BG wrote on 1/11/2021 9:34 PM:
My ASW20C came with only a CG hook. After several years, I retrofitted it with a nose hook. The
improvement on takeoff was significant, and it was also better in the air. A very worthwhile
change, I thought, and I had about a 1000 hours at the time.
Old January 12th 21, 07:39 PM posted to rec.aviation.soaring
Dan Marotta
Another issue is the risk you are imposing on the tow pilot.Â* Most of
directional control.Â*Â* Kiting is also a killer.Â* My club lost a
it with a nose hook. The improvement on takeoff was significant, and it
was also better in the air. A very worthwhile change, I thought, and I
Curious - How does fitting a nose hook make a '20 "better in the air"?
Is it because of a larger opening in the nose? I thought the '20 got
its ventilation via NACA scoops under the wings. Am I missing something?
Dan
5J
Old January 12th 21, 07:44 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote on 1/12/2021 11:39 AM:
Another issue is the risk you are imposing on the tow pilot.* Most of these older ships have
CG hooks that provide little help in directional control.** Kiting is also a killer.* My
The improvement on takeoff was significant, and it was also better in the air. A very
worthwhile change, I thought, and I had about a 1000 hours at the time.
Curious - How does fitting a nose hook make a '20 "better in the air"? Is it because of a
larger opening in the nose?* I thought the '20 got its ventilation via NACA scoops under the
wings.* Am I missing something?
"Better in the air" referred to being on tow, off the ground. Once the rope is gone - no change.
Old January 12th 21, 10:45 PM posted to rec.aviation.soaring
Dan Marotta
retrofitted it with a nose hook. The improvement on takeoff was
Is it because of a larger opening in the nose?Â* I thought the '20 got
its ventilation via NACA scoops under the wings.Â* Am I missing something?
Got it, thanks!
Dan
5J
FS: Nimbus 3-25.5 JS Soaring 0 February 19th 08 07:49 PM
FS Nimbus 3 Roy Bourgeois Soaring 0 December 26th 07 07:47 PM
Nimbus down? [email protected] Soaring 2 November 21st 06 02:10 PM
Nimbus 4 Ray Gimmey Soaring 0 May 17th 04 06:46 PM
F.S. Nimbus 3DM Tom Stowers Soaring 0 October 18th 03 07:06 PM
