I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device"). Does that apply to both LXNAV and LX Navigation (separate companies?)
(Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007? And can one use Tophat to extract the IGC file from the LX7007 after landing? I do both of those with Tophat connected to a PowerFLARM. |
I use a Soartronic bluetooth module with my PowerFlarm Core (new Fusion version has bt build in). My Android pda is a Nokia 8 running LK8000 and this solution works well. Installation of the Soartronic (search on Facebook or go to www.soartronic.net) device with the PowerFlarm is very simple and already has the compatible RJ45 connector. These comments should also apply for XCSoar and TopHat if your Android device has bluetooth. The LXNAV S100 (which I have) can also drive your Android pda with it's built in bluetooth. Getting bi-directional exchange of data that is complete... was really challenging for the LK8000 developer in mid 2020. I worked intensely with him using my S100 and Android phone Nokia 8 with bluetooth. It now works very well using the Nano3 driver.
On 1/21/2021 4:45 PM, WaltWX wrote:
I use a Soartronic bluetooth module with my PowerFlarm Core (new Fusion version has bt build in). My Android pda is a Nokia 8 running LK8000 and this solution works well. Installation of the Soartronic (search on Facebook or go to www.soartronic.net) device with the PowerFlarm is very simple and already has the compatible RJ45 connector. These comments should also apply for XCSoar and TopHat if your Android device has bluetooth. The LXNAV S100 (which I have) can also drive your Android pda with it's built in bluetooth. Getting bi-directional exchange of data that is complete... was really challenging for the LK8000 developer in mid 2020. I worked intensely with him using my S100 and Android phone Nokia 8 with bluetooth. It now works very well using the Nano3 driver. Walt: what do you mean by "Getting bi-directional exchange of data"? What functionality? What I am looking for is: * copy task from Tophat to LX7007, and * copy IGC flight log (after landing) from LX7007 to Tophat. I can do both of those currently with Tophat connected to PowerFLARM. I had no problem getting a cable connection between the two (rather than BT), once I added a serial port to the Nook e-reader that is running Tophat. https://www.tapatalk.com/groups/toph...s50.html#p2353 With that alone, the only thing I could expect Tophat to do is interpret the standard NMEA sentences sent from the FLARM to be used as the GPS location data source. But the functionality I mentioned above is then also possible thanks to Tophat knowing about the FLARM communications protocol to do those transfers. (Moreover, Tophat also knows how to interpret the FLARM traffic data and shows those "targets" on the moving map.) In the case of the LX7007, the question then is, does the "LXNAV" (or other?) communication protocol choice within Tophat work with the LX7007, and offer those functions? Note that everything I said about Tophat also applies to XCsoar, they share the same source code for those (and most other) functions. |
On 1/21/2021 5:45 PM, Moshe Braner wrote:
On 1/21/2021 4:45 PM, WaltWX wrote: I use a Soartronic bluetooth module with my PowerFlarm Core (new Fusion version has bt build in). My Android pda is a Nokia 8 running LK8000 and this solution works well. Installation of the Soartronic (search on Facebook or go to www.soartronic.net) device with the PowerFlarm is very simple and already has the compatible RJ45 connector. These comments should also apply for XCSoar and TopHat if your Android device has bluetooth. The LXNAV S100 (which I have) can also drive your Android pda with it's built in bluetooth. Getting bi-directional exchange of data that is complete... was really challenging for the LK8000 developer in mid 2020. I worked intensely with him using my S100 and Android phone Nokia 8 with bluetooth. It now works very well using the Nano3 driver. Walt: what do you mean by "Getting bi-directional exchange of data"? What functionality?Â* What I am looking for is: * copy task from Tophat to LX7007, and * copy IGC flight log (after landing) from LX7007 to Tophat. I can do both of those currently with Tophat connected to PowerFLARM.Â* I had no problem getting a cable connection between the two (rather than BT), once I added a serial port to the Nook e-reader that is running Tophat. https://www.tapatalk.com/groups/toph...s50.html#p2353 With that alone, the only thing I could expect Tophat to do is interpret the standard NMEA sentences sent from the FLARM to be used as the GPS location data source.Â* But the functionality I mentioned above is then also possible thanks to Tophat knowing about the FLARM communications protocol to do those transfers.Â* (Moreover, Tophat also knows how to interpret the FLARM traffic data and shows those "targets" on the moving map.) In the case of the LX7007, the question then is, does the "LXNAV" (or other?) communication protocol choice within Tophat work with the LX7007, and offer those functions? Note that everything I said about Tophat also applies to XCsoar, they share the same source code for those (and most other) functions. Another question about the LX7007 (and similar): Besides the 6-pin telephone type "IGC" port, it also has a "PDA" port which is a 9-pin D-sub connector. Both have serial data in/out pins. Are they equivalent in protocol and functionality on those? The PDA port also has a 5V wire for powering the PDA. How much current can that supply? I wonder if it would power the Nook running Tophat, that needs about 400 mA AFAIK. (Yup, much more than the power consumption when the e-reader is used for e-reading - the constant updating of the moving map is a different ballgame.) |
On 1/21/21 1:43 PM, Moshe Braner wrote:
I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device"). Does that apply to both LXNAV and LX Navigation (separate companies?) (Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007? And can one use Tophat to extract the IGC file from the LX7007 after landing? I do both of those with Tophat connected to a PowerFLARM. You can extract the igc file directly from tophat, I think. It's been a long time... -- Dan 5J |
On 1/21/2021 9:02 PM, Dan Marotta wrote:
On 1/21/21 1:43 PM, Moshe Braner wrote: I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device").Â* Does that apply to both LXNAV and LX Navigation (separate companies?) (Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007?Â* And can one use Tophat to extract the IGC file from the LX7007 after landing?Â* I do both of those with Tophat connected to a PowerFLARM. You can extract the igc file directly from tophat, I think.Â* It's been a long time... Yes Tophat makes an IGC file too. But it's not IGC-security-certified. So if you want a "green V" on OLC, or, more importantly, if you want to claim a soaring badge or record, you need the flight log from your IGC-certified flight recorder, e.g., LX7007, or FLARM, etc. Tophat can copy it from the FLARM (for example) that it is attached to, then the file sits in the memory of the Android device alongside the file created directly by Tophat. After flying, I leave the FLARM in the glider, but take the Nook home, with those IGC files in its memory. (I can then transfer them to a PC via SD card, USB cable, or wifi. I normally do the latter, no need to plug the Nook into anything at home - it gets charged while flying!) |
On 1/21/21 7:16 PM, Moshe Braner wrote:
On 1/21/2021 9:02 PM, Dan Marotta wrote: On 1/21/21 1:43 PM, Moshe Braner wrote: I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device").Â* Does that apply to both LXNAV and LX Navigation (separate companies?) (Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007?Â* And can one use Tophat to extract the IGC file from the LX7007 after landing?Â* I do both of those with Tophat connected to a PowerFLARM. You can extract the igc file directly from tophat, I think.Â* It's been a long time... Yes Tophat makes an IGC file too.Â* But it's not IGC-security-certified. Â*So if you want a "green V" on OLC, or, more importantly, if you want to claim a soaring badge or record, you need the flight log from your IGC-certified flight recorder, e.g., LX7007, or FLARM, etc.Â* Tophat can copy it from the FLARM (for example) that it is attached to, then the file sits in the memory of the Android device alongside the file created directly by Tophat.Â* After flying, I leave the FLARM in the glider, but take the Nook home, with those IGC files in its memory.Â* (I can then transfer them to a PC via SD card, USB cable, or wifi.Â* I normally do the latter, no need to plug the Nook into anything at home - it gets charged while flying!) Can't you download directly from the Flarm? Downloading from XCSoar was never an issue for me because I only use OLC to add a few points to my club's statistics. Don't need no (more) steenkin' badges... -- Dan 5J |
On 1/21/2021 3:43 PM, Moshe Braner wrote:
I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device"). Does that apply to both LXNAV and LX Navigation (separate companies?) (Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007? And can one use Tophat to extract the IGC file from the LX7007 after landing? I do both of those with Tophat connected to a PowerFLARM. To answer my own question: I finally got the LX7007 connected to Tophat on a Nook via a serial cable. The good news: LX7007 sends GPS data to Tophat. The bad news: other functionality lacking, cannot send task from Tophat to LX, cannot retrieve LX flight logs from inside Tophat. This may improve in the future if a newer version of Tophat incorporates newer versions of XCsoar, since XCsoar release notes for recent versions specifically mention these issues. |
On Sunday, February 7, 2021 at 8:38:42 AM UTC+10, Moshe Braner wrote:
On 1/21/2021 3:43 PM, Moshe Braner wrote: I see that Tophat (based on XCsoar) has "LXNAV" as one of the available communication protocols (when defining the "device"). Does that apply to both LXNAV and LX Navigation (separate companies?) (Reminds me of the Monty Python movie where the splinter groups "Judea Liberation Front" are enemies of the "Front for Liberation of Judea", or such.) If Tophat (or XCsoar) is connected to an LX7007 via a bi-directional cable, can one define the task in Tophat and then send it to the LX7007? And can one use Tophat to extract the IGC file from the LX7007 after landing? I do both of those with Tophat connected to a PowerFLARM. To answer my own question: I finally got the LX7007 connected to Tophat on a Nook via a serial cable. The good news: LX7007 sends GPS data to Tophat. The bad news: other functionality lacking, cannot send task from Tophat to LX, cannot retrieve LX flight logs from inside Tophat. This may improve in the future if a newer version of Tophat incorporates newer versions of XCsoar, since XCsoar release notes for recent versions specifically mention these issues. TopHat hasn't had any development for 4 years now... |
XCSoar / TopHat maps airspace etc. | [email protected] | Soaring | 6 | April 11th 18 12:43 AM |
LX7007 Pro IGC | David Cleveland | Soaring | 3 | June 2nd 16 01:51 PM |
LX7007 Pro IGC | Charlie Papa[_2_] | Soaring | 4 | June 1st 16 07:59 PM |
PowerFLARM, LX7007 Pro IGC and a PDA ... how to ... | 2NO | Soaring | 7 | March 22nd 14 03:57 PM |
Want to buy used LX7007 | [email protected] | Soaring | 3 | July 26th 13 08:27 PM |
