What is involved regulation wise adding an electric motor to a glider?
Old February 3rd 21, 11:10 PM posted to rec.aviation.soaring
Mark Mocho
Default What is involved regulation wise adding an electric motor to a glider?
Not to hijack the thread, but in response to the reliability issue of two-stroke engines, the primary culprit seems to be the different altitudes at which the engine is supposed to start and operate. The fuel/oil/air mixture has to be within certain parameters for decent running and starting reliability. An increase in altitude (or high density altitude conditions) reduces the amount of available oxygen, which contributes to fouling the spark plugs. I used to ride the Yamaha RD-350 and TZ-250 motorcycles from Albuquerque (elevation ~5,500 ft. MSL) up to Sandia Crest (10,678 ft. MSL) and used to have to stop and adjust the needles in the carburetors four times on the way up and four times on the way down or risk plug fouling or overheating and possibly seizing the engine. About a 1,000 ft. change in altitude was all it took to affect the performance and reliability. Newer two-stroke engines with more sophisticated fuel injection systems seem to be much more reliable in motorgliders.
Old February 4th 21, 04:36 AM posted to rec.aviation.soaring
Wallace Berry[_2_]
Oh, that brings back memories. I too rode an RD-350 (voted as the "Bike most likely to lose you your driver's license"). Even tried production class road racing on it a couple times (scary). Had the same experience as you with riding in the mountains. Used to stop on the way up to Deal's Gap and drop the carb needles a notch. Put 38,000 miles on the bike. Never failed to start and run. Stopped being scooter trash and became glider trash, but still have that bike (mothballed since 1981).
Old February 4th 21, 04:51 PM posted to rec.aviation.soaring
Dan Marotta
Default What is involved regulation wise adding an electric motor to aglider?
Talk about hijacking...
I've had my Harley Davidson Wide Glide for almost 17 years and 137,000
miles and don't ride it too much any more though I did get it out a
couple of days ago when the temperature got up to 60 deg. Just
wondering what you did to mothball it. I've never done more than to put
on a battery charger now and then.
Dan
5J
Old February 6th 21, 01:31 AM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, February 3, 2021 at 3:10:11 PM UTC-8, Mark Mocho wrote:
...I used to ride the Yamaha RD-350 and TZ-250 motorcycles...
I raced RD-250 in 250 Modified Production and TA-125 in GP classes during my mis-spent youth. Fun stuff, but there is no way I'd trust my life to the continued operation of a tightly-wound two-stroke motor. I didn't think I'd mess around with motorgliders at all until brushless motors and Lithium batteries came along. Now I think that electric motorgliders are poised to become the core of our sport, with pure sailplanes becoming more of a fringe activity.
Old February 7th 21, 06:18 PM posted to rec.aviation.soaring
kinsell
if you're trusting your life to the operation of any motorglider engine,
you're screwing up bigtime. Electrics can and do fail, right along with
the others.
Old February 3rd 21, 11:52 PM posted to rec.aviation.soaring
Hank Nixon
On Wednesday, February 3, 2021 at 5:31:51 PM UTC-5, David Scott wrote:
On Wednesday, February 3, 2021 at 11:35:51 AM UTC-8, Bob Kuykendall wrote:
On Tuesday, February 2, 2021 at 1:26:10 PM UTC-8, David Scott wrote:
Others have pointed out that this is easier for an Experimental glider. It is easiest for an experimental, amateur-built glider. For E-AB, depending on the operating limitations, you might have to notify the FAA and repeat Phase I testing. But nobody wants to see your engineering validation, and only the person signing off the annual condition inspection needs to review your workmanship. The FAA or DAR only wants to see that the paperwork is correct and that placards and operating limitations are correctly spelled out. A good DAR will look the airplane over to make sure it doesn't look particularly dangerous, but they aren't required to.
We have FES going into one of our glider kits right now, and are preparing for the installation of electric self-launch systems in future models.
--Bob K.
Since I am new here what kit do you produce? Are you preparing for FES or retractable pylon?
Any idea how much thrust an FES produces? My search came up empty.
Look up https://hpaircraftblog.wordpress.com
Lots of interesting info there- especially the old school stuff showing all the work it takes to get set up to produce a kit sailplane.
UH
Old February 4th 21, 12:08 AM posted to rec.aviation.soaring
David Scott
We have FES going into one of our glider kits right now, and are preparing for the installation of electric self-launch systems in future models..
--Bob K.
UH
I was wondering if that is what he was talking about. I followed that blog for a few years so am somewhat familiar with it.
Old February 3rd 21, 08:53 PM posted to rec.aviation.soaring
Ackerson Eyecare
I really would love to do this to my DG-800S with a fixed mounted 400N Swiwin or PBS ​Turbine. Fixed mounted for simplicity and less cost accepting the few points in loss performance. If I could do it for $20K, that would be cool. When you push the price to $40-$50K, then it's just better to buy a sailplane with a motor. Remaking the AW certificate seems daunting. Maybe if I found a DG800C with a bad motor I could do a engine swap from two stroke to turbine without a major modification affecting the AW. 17gallons per hour is still a lot of gas compared with the solo 2-stroke motors. I wish electric duct fan's were more efficient. The best 120mm commercial RC product only produces around 10kg of thrust on 150 amps. I can't wait for future tech to catch up to our propulsion needs considering the future loss of tow planes. Two stroke motors seem so problematic/finicky and antique considering all our modern inventions. The sound considerations comparing a turbine to a two stroke motor are not even close in the cool factor. Bring on the warp drive please that runs off my cell phone battery.
Walter Mitty
N800XX
Old February 3rd 21, 09:47 PM posted to rec.aviation.soaring
David Scott
Walter Mitty
N800XX
I rode 2 stroke dirt bikes for years and found their reliability to be stellar so I don't understand why they are considered finicky or unreliable. Granted the idea of not having a throttle and running them at 1/2 throttle only is nuts. I did ONE cold seizure early on and that taught me to do a proper warmup.
Old February 3rd 21, 10:10 PM posted to rec.aviation.soaring
"Condition Inspection" requires only an A&P.
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) Miloch Aviation Photos 0 May 15th 19 03:46 AM
Pilotless Electric Motor Glider Generates Clean Power Mike Mike Ground Soaring 0 November 27th 11 06:27 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
