Tales Of The Bloody Triangle
Old February 3rd 21, 09:45 PM posted to rec.aviation.soaring
Default Tales Of The Bloody Triangle
I have been around this game for a bit and have made all kind of flights, straight out flights, out and return flights, and the Bloody Triangle. I must say that the most difficult of them all is the declared triangle with minimum leg distances. Without a doubt the triangle is the most challenging of all.
Yes, you can run up and down the ridge, go straight out or go out and return, all are good flights, but the big triangle is the Bloody prize. What do you think?
Old February 4th 21, 03:33 AM posted to rec.aviation.soaring
Well, the triangle is the strongest geometric shape so it should be tough!
Old February 4th 21, 07:59 AM posted to rec.aviation.soaring
Mads
My contribution to the triangle story :-).
https://www.onlinecontest.org/olc-3....l?dsId=7737834
Best regards Mads
Old February 4th 21, 08:20 AM posted to rec.aviation.soaring
Ramy[_2_]
Best regards Mads
While I agree a declared FAI triangle is the most challenging, the long out and return also deserves special recognition. For a given distance, the O&R requires you to fly the furthest from your final destination possible. Also a 1000km O&R will normally take you to different weather.
It feels insane to be 300 miles from home and still fly in the opposite direction...
Ramy
Old February 4th 21, 11:05 AM posted to rec.aviation.soaring
Ramy
Perhaps even more insane to do a straight out and expect your friends to come and pick you up!
Old February 4th 21, 12:28 PM posted to rec.aviation.soaring
Best regards Mads
Ramy
I would also rate the out and return as second on the list because of distance and weather, the WX component of the triangle also adds to its level of difficulty. Wind is a big factor for both O&R and triangle, a bit more so for the triangle, IMHO. The straight out is the least difficult, kind of like strapping a chimp into a rocket and saying, "Here Ya Go Joe, Enjoy The Ride".
Old February 4th 21, 02:34 PM posted to rec.aviation.soaring
Moshe Braner
Seeing the subject line and your location I thought you were talking
about the Bermuda Triangle...
I've always thought the pre-declared triangle is the best XC challenge.
And to make it even harder, I insisted on making the start/finish
point an apex of the triangle. I.e., no "start on leg".
I did 300km that way a while back, pre-declared to myself. 22 years
later I did it again, even slower, but officially recognized. Not in
the 1000km league Ramy is in, but a good challenge with my 12.6m wings
in the Eastern US. Now I need to do it again, faster - hopefully faster
than my glider's stall speed :-)
With such a triangle you get almost as far away from home as with an
O&R, and having to venture in two different directions you are likely to
enter different weather - and to suffer a headwind on at least one leg.
All this should be considered in the planning of the task before
declaration - another challenge.
Somewhere I've seen an informal club contest scheme, can't remember what
it was called (not the currently discussed "Proving Grounds"), where
this was formalized, in that the same distance got more points if an
O&R, and even more points if an FAI triangle. The current OLC doesn't
quite do that, but does add some points to closed-course flights for the
largest enclosed FAI triangle.
Old February 4th 21, 04:29 PM posted to rec.aviation.soaring
MNLou
In defense of the Downwind Dash -
1) You tend to have to fly over much more unfamiliar terrain.
2) It's a big leap to take off and, even with a goal, have no idea where you are actually going to land. (A big thank you to Tony Condon for encouraging pilots to get over this hump.)
3) A possible multi-day retrieve is a major commitment to the flight.
Lou
Old February 4th 21, 04:32 PM posted to rec.aviation.soaring
Tango Whisky
Nice one !
Le jeudi 4 février 2021 Ã* 08:59:35 UTC+1, Mads a écritÂ*:
Best regards Mads
Old February 4th 21, 04:58 PM posted to rec.aviation.soaring
Tango Eight
Just for Bob, the ASW-20 fan: https://www.onlinecontest.org/olc-3....l?dsId=5130184 (600 km declared).
Stopped a little short of 3rd declared TP (declaration was for 650km) on this one, but got free triangle state record: https://www.onlinecontest.org/olc-3....l?dsId=5911937
T8
Comics, pt 6 - Tales of the Air.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 December 13th 18 01:51 PM
Tales of being distracted by scenery and/or euphoria while soaring son_of_flubber Soaring 12 March 10th 14 11:12 PM
Icing...some cautionary tales Bob Gardner Piloting 0 January 24th 08 10:04 PM
mmmm Total bloody Tossers? [email protected] Aviation Photos 9 July 14th 07 03:46 AM
Bloody Hell! Michael Baldwin, Bruce Products 0 May 28th 07 08:29 AM
