FCC License?
Old March 7th 21, 07:09 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default FCC License?
I'm circling back on this old 2010 thread as I received a letter from the FCC asking me to renew the radio license specific specific to my N number (aka "Call Sign").
So here is a question that really needs a simple yes/no answer*.
"Do I need an FCC license for my glider (or for that matter for the myriad of GA power pilots flying their airplanes owned or rented) while flying WITHIN THE US so I can transmit across the entire aviation frequency range (118-137 MHz) and I can communicate with other pilots, small/large airports, ATC, etc, etc?"
I believe that the answer is "No". See the reference links below.
https://www.fcc.gov/commercial-radio...icense-program
https://www.aopa.org/travel/internat...r-certificates
https://sportysacademy.com/fcc/
https://cfiacademy.com/how-to-get-fc...rivate-pilots/
Let the conversation begin.
Thanks, John (OHM)
*PS - I'm *NOT* talking about a license for my gliderport, international flying, drug running, insurrection, or (for Bruno's benefit) flying in an air show.
Old March 8th 21, 12:41 AM posted to rec.aviation.soaring
Dan Marotta
No. Used to, not any more unless you cross a border. If you plan any
international flights, check first.
Dan
5J
Thanks, John (OHM)
Old March 9th 21, 04:06 PM posted to rec.aviation.soaring
Peter Hudson
Dan
5J
Thanks, John (OHM)
On a related note: I did a lot of emailing with the FCC a few years back about using aviation radios from aircraft without N numbers (ultralights, paramotors, paragliders etc.) And the end result was that to be legal I needed a restricted radio telephone operators permit. the same as if flying a registered plane out of country. The popular answer is "no one checks, so I do it for safety" but I figured for $60 and no training requirements for a lifetime permit I would just do sign up for it.
Old March 9th 21, 05:32 PM posted to rec.aviation.soaring
I'm unsure if the license is good for your lifetime. I thought all FCC licenses had to be renewed every 10 years. Is a "permit" different than a "license"?
Old March 9th 21, 09:08 PM posted to rec.aviation.soaring
Dan Marotta
I thought the Radio Telephone Operator's license I got back in 1974 (at
no charge, I might add), was a lifetime license. I lost it somewhere
along the way. If I decide to fly the Caribbean or Canada, I'll check
into getting another one.
Dan
5J
Old March 9th 21, 09:11 PM posted to rec.aviation.soaring
Peter Hudson
On Tuesday, March 9, 2021 at 9:32:45 AM UTC-8, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
I have a HAM and GFRS license that does need to be renewed every 10 years but the restricted radio operator's permit is a lifetime thing...I couldn't say why, but at least I can't forget to renew it!
When I go into the ULS FCC database and list my licenses, it's the only one that doesn't show an expiration date.
Old March 9th 21, 06:00 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Dan
5J
Just to compare to Canada, it's much the same up here. From the regulator's website:
" Do I need a licence for the aeronautical radio equipment on board my aircraft?
You will not require a licence if you meet both of the following criteria:
- the aircraft is not operated in the sovereign airspace of a country other than Canada.
- the radio equipment on board the aircraft is only capable of operating on frequencies that are allocated for aeronautical mobile communications or aeronautical radio navigation."
So neither we nor you need a licence unless we cross the border, when each of us then do... Perhaps a mutual exception might be arranged.
We also have a medical declaration for the glider pilot licence, but it's not valid in the U.S.; yours, not valid up here. Pity.
Dan
Getting an A&P license [email protected] Home Built 5 August 26th 06 03:06 PM
Accelerated license course? Deane Soaring 8 June 1st 06 04:14 AM
Got my new license Brien K. Meehan Piloting 3 November 18th 04 02:27 PM
Should the USA have a soaring license, not a glider license? Mark James Boyd Soaring 0 August 6th 04 07:16 PM
Cheap License Brad Mallard Rotorcraft 6 November 17th 03 02:16 PM
