Alternative to the Battery wows?
Old March 8th 21, 11:10 PM posted to rec.aviation.soaring
Mark Mocho
Default Alternative to the Battery wows?
On Monday, March 8, 2021 at 1:42:45 PM UTC-7, Eric Greenwell wrote:
Mark Mocho wrote on 3/8/2021 11:34 AM:
And I seem to remember hearing that water vapor is more of a "greenhouse gas" than carbon dioxide.
Not so much when it comes to climate change, because as water vapor increases (primarily due to
global warming), it forms more clouds, which reflect the heat, tending to reduce global warming
- all part of a natural cycle that's be going on since the earth began. CO2 does not condense,
and we are adding it to the atmosphere at a far higher rate than natural carbon sinks can
remove it.
However, using hydrogen as an alternative fuel WILL add to the amount of water vapor in the atmosphere. Note the following statement:
"...water vapor is the largest contributor to the Earth’s greenhouse effect...However, water vapor does not control the Earth’s temperature, but is instead controlled by the temperature...If there had been no increase in the amounts of non-condensable greenhouse gases (like carbon dioxide), the amount of water vapor in the atmosphere would not have changed with all other variables remaining the same." (from the American Chemical Society's ACS Climate Science Toolkit)
The key phrase is the last one: "with all other variables remaining the same." Imagine that instead of seeing "normal" contrails behind a high flying airliner, there is a huge plume of water vapor that results from burning hydrogen. That definitely adds to atmospheric water vapor, independent of the natural evaporation/condensation cycle that forms clouds.
Of course, the "Chemtrails" paranoids will get a corresponding boost in popularity.
Old March 8th 21, 11:50 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mark Mocho wrote on 3/8/2021 3:10 PM:
remove it.
Again, the water vapor will condense, and restore the natural balance; CO2 does not condense,
but remains in the atmosphere for hundreds of years. The CO2 in the atmosphere is measurable,
and has been increasing for many decades wherever it's measured around the world; water vapor
comes and goes with the weather.
Old March 9th 21, 12:20 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
increases (primarily due to global warming), it forms more clouds,
which reflect the heat, tending to reduce global warming - all part of
condense, and we are adding it to the atmosphere at a far higher rate
than natural carbon sinks can remove it.
clouds.
popularity.
If H2 was to replace hydrocarbons as the main fuel type, where would it
come from? Electrolysis of water? Stripping carbon out of hydrocarbons?
ow would the cost compare with other power sources once transport to the
point of use is included in the price?
It appears that the last two are the current favourites in the form of
steam reforming of natural gas, partial oxidation of methane, and coal
gasification, with extraction from carbon compounds providing 96% and are
not particularly green because they all produce a lot of carbon oxides as
a waste product - and we don't have a good way of using them or keeping
them out of the atmosphere.
Bottom line: hydrogen has good energy capacity per kilogram, but this
tends not to look so good once you consider the cost of carrying it
around in compact, multi-kilogram quantities. Pipes should be fine,
provided somebody manages to invent a reasonably light pipe material that
H2 can't leak through, but you can't power road/rail vehicles or aircraft
with piped hydrogen!
Martin | martin at
Gregorie | gregorie dot org
Old March 9th 21, 01:12 AM posted to rec.aviation.soaring
Mark Mocho
"water vapor comes and goes with the weather."
Yes, but now we are talking about combusting H2 with O2, which is an entirely new source of H2O vapor.
And, if you want another little problem to solve with the storage and use of hydrogen, look up "Hydrogen Embrittlement."
I'm not saying it won't be feasible, but it isn't by any means a magic panacea.
In his book, "Skunk Works," Ben Rich talks about Lockheed's experiments with producing and storing liquid hydrogen in the 1950's for possible use as a fuel for high flying, Mach 3+ reconnaissance aircraft. The chapter is titled "Blowing Up Burbank." (That should give you a hint.) Their conclusions were that it was terribly inefficient due to the size of the storage vessel needed for acceptable range, it was very dangerous to transport and store and the infrastructure needed to ensure availability around the world would cost more than the rest of the program, including development of the aircraft and training Air Force personnel to handle it. They went with a new fuel (JP-7) and built the A-12, followed by the SR-71.
Old March 9th 21, 03:37 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mark Mocho wrote on 3/8/2021 5:12 PM:
Yes, a new source, but it doesn't accumulate in the atmosphere, as the additional water vapor
will condense. CO2 does not condense, and lingers for hundreds of years.
Old March 9th 21, 01:35 AM posted to rec.aviation.soaring
Moshe Braner
remove it.
Naaah, to "make" the hydrogen you'd need to separate it from water.
It's a closed loop. There are many hurdles, but this one is not. Of
course you can separate it from methane (natural gas) instead, but if
you burn the gas directly you get the same water vapor.
I find the subject line of this thread appropriate though, there are too
many "wows" out there but the "vaporware" never materializes.
SeeYou Alternative? Papa3[_2_] Soaring 3 June 18th 18 05:07 PM
100LL alternative [email protected] Soaring 2 May 10th 08 04:54 AM
New $100 Hamburger Web Alternative Jay Honeck Piloting 0 November 3rd 06 01:11 AM
Alternative to IPAQ PDA's marc_dg400 Soaring 5 August 11th 06 04:22 PM
Financing Alternative L Owning 8 October 6th 03 06:14 PM
