$1 billion BMS Ooops...
Old March 17th 21, 12:59 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default $1 billion BMS Ooops...
2G wrote on 3/16/2021 10:17 PM:
On Tuesday, March 16, 2021 at 3:48:54 PM UTC-7, Eric Greenwell wrote:
2G wrote on 3/16/2021 12:46 PM:
Landing out in eastern Nevada is serious business; some may chose to fly non-motorized gliders there (which, in my mind, the GP15 is) and get away with it.
I forgot to respond to the "non-motorized" portion of your remarks. Perhaps you will be
surprised (or at least interested) to learn the GP15 climb rate from the runway on a typical
flying day at Ely will be nearly double the climb rate of my ASH26E. A major reason is the
electric motor still has the same power at 9000' DA, while the carbureted Wankel has lost about
18%. The better climb on takeoff in high density altitudes was an important factor in my
choice. It's not important at Ely, but it is at Parowan, and a few other places I've flown (or
wanted to fly but decided it was marginal).
Now, I realize you think 90 miles of self-retrieve is the same as zero miles, but that view is
not shared by every "pure" glider pilot out there!
Where do you get 90 miles? GP's website doesn't list it. Their numbers are dry - if you can trust them (nobody's verified them and they may be estimated for all you know). The self-retrieve distance they list for the B battery is 100km (63 miles) with a 800m launch with no ballast. Now add ballast, add an 3,000 ft obstacle and a 20kt headwind (all realistic conditions at Ely) and refigure what the hypothetical retrieve distance is, if any.
Take a look at this page: https://www.gpgliders.com/offer/gp-15-e-se-jeta Here's the pertinent
portion:
Usable battery capacity: 9,23 kWh
Operational battery capacity: 8,36 kWh (10% buffer to preserve battery life)
Weight: 52 kg (115 lb)
Motor glider’s self-launch and climb performance on a single charge, equipped with “B” battery
pack (TOW: 320 kg [705 lb]):
5 x take-off and climb to 800 m (2 625 ft) altitude
or 1 x take-off and climb to 800 m (2 625 ft) altitude + 150 km (93 mi) range
or 1 x take-off and total climb to 4 000 m (13 120 ft)
Max. climb rate: 4,4 m/s (8,55 kts)
Ground-roll take-off distance: 180 m (197 yards)
Because the wing area is 84 ft2, the 705lb TOW = 8.4 lb/ft2, about the same wing loading I have
in the ASH26E, unballasted.
Old March 18th 21, 03:50 PM posted to rec.aviation.soaring
India November[_2_]
portion:
Eric, I'm curious about the wing loadings quoted for the Jeta from 7,58-13,72 lb/ft^2. For the conditions I fly in Ontario where thermals average 2 to 4 kts, I see these heavy wing loadings as a disadvantage even in a flapped ship. I fly my D2 mostly dry at less than 6 lb/ft^2. What am I missing?
Ian IN
Old March 18th 21, 06:30 PM posted to rec.aviation.soaring
Mark Mocho
Decent lift.
Old March 18th 21, 07:48 PM posted to rec.aviation.soaring
Dave Nadler
Ian, newer flapped designs do well in weak conditions even with higher
wing-loadings. The glider I'm flying at the moment has a minimum
wing-loading of 9.5 lbs/ft2 (and I'm a lighter pilot), but I've never
landed it when someone else was able to climb away. Span-loading helps
(18m better than 15m). Not comparable to older unflapped designs.
Old March 18th 21, 11:07 PM posted to rec.aviation.soaring
waremark
When flying the Arcus M with a copilot and no ballast my wing loading is 49 kg/m2 (10 lbs/ft2). In spite of being a 'newer flapped design', in very weak lift pure gliders without ballast simply climb away from me. You may rightly assume that is indicative of my piloting skills, or lack of them! But when a good pilot joined me for a comp, the first time he was flying in very weak lift he quickly admitted that I hadn't been fibbing about not being able to climb in weak lift.
Old March 19th 21, 03:04 AM posted to rec.aviation.soaring
Dave Nadler
I wasn't going to say anything...
ArcusM isn't quite as good in weak lift, but anyway it's minimum loading
is MUCH higher than the Jeta; IIRC for me and usual passengers ArcusM
was around 9.5 also. Also Ian's comparing to a non-flapped glider...
Old March 23rd 21, 12:22 AM posted to rec.aviation.soaring
waremark
It was a different glider in 2020 - when for Covid social distancing reasons I always flew it solo!
Old March 31st 21, 04:41 PM posted to rec.aviation.soaring
Nicholas Kennedy
https://www.msn.com/en-us/news/techn...?ocid=msedgdhp
This is IT! No more pesky recharging problem.
No more limited self retrieve range!
Sign me up!
Nick
T
Old March 18th 21, 09:42 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
India November wrote on 3/18/2021 8:50 AM:
portion:
Ian IN
Are you really sure of that wing loading? The numbers on the Schmepp site suggest a wing
loading for a pilot 165lb pilot with a 15 lb parachute is over 6.5 lb/ft2. But even it's 7
lb/ft2, it is definitely a lighter wing loading than the newer flapped 15m gliders; eg, the new
AS33-15M has a minimum wing loading of 8.5 lb/ft2, and that is without a motor.
As Dave mentions, span loading (weight/span^2) is a better indicator of thermalling ability,
and since the Discus 2A and the Jeta have the same span and about the same minimum weight
(using the weight from the Schmepp site), I'd expect them to thermal the same. It may seem
strange a lighter wing loading doesn't help more, but aspect ratio matters: the Discus has a 22
ratio, while the Jeta has 29.
And, the Jeta has a motor, so even if it did not thermal quite as well as your Discus, you'd
still have fewer landouts in it than the Discus 2. Plus, you'd love the extra speed the higher
wing loading allows during the cruise, at least 15% faster (and with a higher glide ratio, due
in part to the higher aspect ratio).
Old March 19th 21, 02:23 PM posted to rec.aviation.soaring
India November[_2_]
portion:
Ian IN
loading for a pilot 165lb pilot with a 15 lb parachute is over 6.5 lb/ft2.. But even it's 7
Interesting, thanks Eric. And yes, I meant 6.8ppsf min loading in my D2. What was I thinking!
Ian IN
The Navy Obfuscates On Shock Testing The $13 Billion USS Ford - The 13 Billion Dollar 'Berthing Barge' USS Gerald R. Ford, sitting in a shipyard.jpg ... Miloch Aviation Photos 1 October 25th 19 02:36 AM
Wow! Ooops, take #3 Dave Nadler Soaring 21 April 4th 15 09:26 PM
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
