$1 billion BMS Ooops...
Old March 18th 21, 07:48 PM posted to rec.aviation.soaring
Dave Nadler
Default $1 billion BMS Ooops...
On 3/18/2021 11:50 AM, India November wrote:
Eric, I'm curious about the wing loadings quoted for the Jeta from 7,58-13,72 lb/ft^2. For the conditions I fly in Ontario where thermals average 2 to 4 kts, I see these heavy wing loadings as a disadvantage even in a flapped ship. I fly my D2 mostly dry at less than 6 lb/ft^2. What am I missing?
Ian, newer flapped designs do well in weak conditions even with higher
wing-loadings. The glider I'm flying at the moment has a minimum
wing-loading of 9.5 lbs/ft2 (and I'm a lighter pilot), but I've never
landed it when someone else was able to climb away. Span-loading helps
(18m better than 15m). Not comparable to older unflapped designs.
Old March 18th 21, 11:07 PM posted to rec.aviation.soaring
waremark
When flying the Arcus M with a copilot and no ballast my wing loading is 49 kg/m2 (10 lbs/ft2). In spite of being a 'newer flapped design', in very weak lift pure gliders without ballast simply climb away from me. You may rightly assume that is indicative of my piloting skills, or lack of them! But when a good pilot joined me for a comp, the first time he was flying in very weak lift he quickly admitted that I hadn't been fibbing about not being able to climb in weak lift.
Old March 19th 21, 03:04 AM posted to rec.aviation.soaring
Dave Nadler
I wasn't going to say anything...
ArcusM isn't quite as good in weak lift, but anyway it's minimum loading
is MUCH higher than the Jeta; IIRC for me and usual passengers ArcusM
was around 9.5 also. Also Ian's comparing to a non-flapped glider...
Old March 23rd 21, 12:22 AM posted to rec.aviation.soaring
waremark
It was a different glider in 2020 - when for Covid social distancing reasons I always flew it solo!
Old March 31st 21, 04:41 PM posted to rec.aviation.soaring
Nicholas Kennedy
https://www.msn.com/en-us/news/techn...?ocid=msedgdhp
This is IT! No more pesky recharging problem.
No more limited self retrieve range!
Sign me up!
Nick
T
Old March 31st 21, 05:22 PM posted to rec.aviation.soaring
5Z
Debunked:
https://www.youtube.com/watch?v=uzV_uzSTCTM
Old March 31st 21, 08:34 PM posted to rec.aviation.soaring
2G
Sign me up!
Nick
T
It's a day early for APRIL FOOLS!
Old March 31st 21, 11:49 PM posted to rec.aviation.soaring
Sign me up!
Nick
T
Good news, the heat off the "pile" can keep you warm in wave flights!
I'm thinking of "the Martian".......sorta real info although a movie....
Old April 1st 21, 05:48 PM posted to rec.aviation.soaring
Dan Marotta
Well Charlie,
Since you're a fan of "The Martian" (one of my all-time favorites, BTW),
can you explain to me why JPL had him cut a hole in the top of the rover
and place an inflated balloon in it?
Inquiring minds...
Dan
5J
Sign me up!
Nick
T
Old April 1st 21, 05:43 PM posted to rec.aviation.soaring
Dan Marotta
What a neat idea! But all of the stacked cells would make your cell
phone weitg on the order of 37 pounds... And the required lead
shielding would another 213 pounds. So you'd need a new Tesla pickup to
cart the thing around...
Dan
5J
Sign me up!
Nick
T
The Navy Obfuscates On Shock Testing The $13 Billion USS Ford - The 13 Billion Dollar 'Berthing Barge' USS Gerald R. Ford, sitting in a shipyard.jpg ... Miloch Aviation Photos 1 October 25th 19 02:36 AM
Wow! Ooops, take #3 Dave Nadler Soaring 21 April 4th 15 09:26 PM
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
