On Monday, April 26, 2021 at 6:14:06 PM UTC-7, 6PK wrote:
On Monday, April 26, 2021 at 4:18:17 PM UTC-7, Guy Acheson wrote: This is a great question that all Cobra owners will have to face. I have two trailers and replaced the original carpet about five years ago with indoor/outdoor carpet that I put in place with rubber cement. The hardest part is removing the crumbly foam rubber backing on the original padding. Aweful product. My second trailer has the padding starting to fall off. So...JJ...is there a heavy felt product or carpet that has self adhesive backing appropriate for this use? The foam back carpet was a terrible idea, left over relic from the seventies, it was used as "kitchen carpet" in the US, I'm surprised Cobra was and I guess still using it. They are most likely not even available in the US any longer. The easiest way to replace this crap is with regular commercial grade "tufted" carpets, readily available at your neighborhood flooring stores . Than once again the problem is the weight with these goods which makes it harder to install once all the previous crap has been removed as I think JJ described it well previously. The best results can be obtained from automobile carpets (without the foam back) , these are light weight and go around compound curves much more easily. They can be purchased at the neighborhood auto upholstery shops. Even if more expensive remember you don't need a large quantity, so it won't brake the bank. And since on this subject, please use a good quality contact cement BUT NOT THE GREEN KIND as you may end up with the carpet as headwear- they just don't hold. Unfortunately the old fashioned contact cements are only available in small cans any longer which makes them more expensive. I could be wrong here as I only tried the local hardware stores and not online. We removed some old padding and replaced it with carpet from Wings &Wheels. Thinner because it didn’t have a foam back. Used the old contact cement.........the new green contact is pure crap! Read the label on the old contact cement which says, in part...........stir before using........ then apply to both surfaces........then let dry for :15 minutes! Worked for us and customer was happy! JJ |
On Monday, April 26, 2021 at 8:04:39 PM UTC-7, wrote:
On Monday, April 26, 2021 at 6:14:06 PM UTC-7, 6PK wrote: On Monday, April 26, 2021 at 4:18:17 PM UTC-7, Guy Acheson wrote: This is a great question that all Cobra owners will have to face. I have two trailers and replaced the original carpet about five years ago with indoor/outdoor carpet that I put in place with rubber cement. The hardest part is removing the crumbly foam rubber backing on the original padding. Aweful product. My second trailer has the padding starting to fall off. So...JJ...is there a heavy felt product or carpet that has self adhesive backing appropriate for this use? The foam back carpet was a terrible idea, left over relic from the seventies, it was used as "kitchen carpet" in the US, I'm surprised Cobra was and I guess still using it. They are most likely not even available in the US any longer. The easiest way to replace this crap is with regular commercial grade "tufted" carpets, readily available at your neighborhood flooring stores . Than once again the problem is the weight with these goods which makes it harder to install once all the previous crap has been removed as I think JJ described it well previously. The best results can be obtained from automobile carpets (without the foam back) , these are light weight and go around compound curves much more easily. They can be purchased at the neighborhood auto upholstery shops. Even if more expensive remember you don't need a large quantity, so it won't brake the bank. And since on this subject, please use a good quality contact cement BUT NOT THE GREEN KIND as you may end up with the carpet as headwear- they just don't hold. Unfortunately the old fashioned contact cements are only available in small cans any longer which makes them more expensive. I could be wrong here as I only tried the local hardware stores and not online. We removed some old padding and replaced it with carpet from Wings &Wheels. Thinner because it didn’t have a foam back. Used the old contact cement.........the new green contact is pure crap! Read the label on the old contact cement which says, in part...........stir before using........ then apply to both surfaces........then let dry for :15 minutes! Worked for us and customer was happy! JJ I have used a paint scraper such as this that I attached to a longer handle for this kind of work: https://www.homedepot.com/p/QEP-4-in...2920/311182302 Tom |
I used Goo Gone, waited an hour and used a paint scraper.
Then you have to wash off the Goo Gone. Was not that big a deal. Taping off the areas for the new padding and painting on the rubber cement was intoxicating. Must do that outside or the fumes will become overwhelming. New glued on outdoor carpet is still holding strong. |
It is easier to use spray contact adhesive. Use 3M 90, not 3M 77.
On Thursday, April 29, 2021 at 6:11:12 AM UTC-7, Guy Acheson wrote: I used Goo Gone, waited an hour and used a paint scraper. Then you have to wash off the Goo Gone. Was not that big a deal. Taping off the areas for the new padding and painting on the rubber cement was intoxicating. Must do that outside or the fumes will become overwhelming. New glued on outdoor carpet is still holding strong. |
On Thursday, April 29, 2021 at 10:41:20 AM UTC-5, jfitch wrote:
It is easier to use spray contact adhesive. Use 3M 90, not 3M 77. On Thursday, April 29, 2021 at 6:11:12 AM UTC-7, Guy Acheson wrote: I used Goo Gone, waited an hour and used a paint scraper. Then you have to wash off the Goo Gone. Was not that big a deal. Taping off the areas for the new padding and painting on the rubber cement was intoxicating. Must do that outside or the fumes will become overwhelming. New glued on outdoor carpet is still holding strong. Anybody ever use boat carpeting? Rubber padded backing and holds up to the elements. -Doug W24 |
| Thread Tools | |
| Display Modes | |
| Cobra Trailer VIN | MSC | Soaring | 3 | July 1st 18 08:05 PM |
| New Cobra trailer - - which top? | Ben[_6_] | Soaring | 34 | February 19th 15 10:43 PM |
| 2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 03:42 PM |
| Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 03:11 AM |
| Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
