F-14 on the History Channel's "Modern Marvels"
Old November 5th 03, 04:18 PM
José Herculano
AESA?
Someone needs to write a FAQ for this group, if there isn't one
already...:-(
That's the bells&whistles version of the APG-79 radar, that does everything
from air-to-air to air-to-ground to jamming. Needs the ACS (advanced crew
stations) to be effective.
_____________
José Herculano
Old November 5th 03, 04:41 PM
Ralph Savelsberg
José Herculano wrote:
AESA?
already...:-(
_____________
José Herculano
And more in general stands for Active Electronically Scanned Array,
which is the name for the type of antenna/emitter group. Instead of a
mechanically swivelling antenna (with complicated waveguides and a heavy
hydraulic system to move it around) this has a flat, fixed array
consisting of multiple emitter/receiver modules. The beam is controlled
electronically and at least in theory such a radar can use multiple
modes simultaneously. In the F/A-18F (with the ACS) this could mean that
for instance the pilot would have an air-to-air mode selected, while the
NFO in the back could be using a ground-mapping mode at the same time.
A small number of USAF F-15Cs (from the 3rd FW in Alaska if I'm not
mistaken) already fly with a radar with such an antenna: a modified
version of the regular APG-63(V)1 (unsurprisingly) called the APG-63(V)2 .
The first F/A-18F fitted with the APG-79 has already undertaken its
first flight.
Regards,
Ralph Savelsberg
Old November 5th 03, 10:31 PM
Harry Andreas
In article , Ralph Savelsberg
Instead it has a liquid cooling system. Still, a lot more reliable than
hydraulics. To keep this in the naval vein, it needs to be mentioned
that the APG-65 and APG-73 antennas use electric motors to drive
the antenna, not hydraulics. But of course, the response time of any
mechanical system is much slower than electronic steeting.
The APG-79 is a newer generation.
USAF is looking into a fleet-wide retrofit of F-15C's and E's with AESA
based on the extremely positive results of the (V)2. This would also be
newer generation.
APG-63(V)2 is the world's first production AESA radar.
first flight.
Harry Andreas
Engineering raconteur
Old November 6th 03, 03:52 AM
Mu
On Wed, 05 Nov 2003 17:41:54 +0100, Ralph Savelsberg
Regards,
Ralph Savelsberg
Ave Ralph
Is this the phased array radar?
And if not,wthat's the difference?
Greetz Mu
Old November 6th 03, 06:18 PM
Ralph Savelsberg
Regards,
Ralph Savelsberg
Ave Ralph
Greetz Mu
Technically the AESA is an active phased array radar whilst older phased
array radars (like the `Flash Dance' in the MiG-31 or the APQ-164 fitted
to the B-1B) are so-called passive phased array radars.
The latter (passive) has a single transmitter/receiver and somehow
applies a phase shift to the signals sent to various parts of the
antenna, depending on the location on the antenna, whilst the former
actually uses a large number of transmitter/receiver units that each
operate at a different phase and possibly in a different mode.
In both cases the `beam' is sent in a certain direction through
adjusting the phase across the antenna, enabling a far higher scan rate,
but the actively scanned array can actually generate multiple beams as
well.
I don't know the intricacies. Harry Andreas will probably be able to
give a much more detailed answer than I can.
Regards,
Ralph Savelsberg
Old November 5th 03, 10:20 PM
Harry Andreas
In article , "José Herculano"
AESA?
already...:-(
José,
the APG-79 radar IS the AESA radar. Same thing, not a version.
Harry Andreas
Old November 6th 03, 03:16 AM
Doug \Woody\ and Erin Beal
On 11/5/03 10:18 AM, in article ,
"José Herculano" wrote:
AESA?
already...:-(
_____________
José Herculano
José's right. Active Electronically Scanned Array. The jets off the line
right now (Lot 23, I think) already have ACS, they just haven't split the
cockpit functionality yet.
--Woody
New aviation history interview: Fokker/Curtiss/Messerschmitt ace Mauno Fräntilä Jukka O. Kauppinen Military Aviation 0 September 22nd 04 11:18 PM
MILITARY HISTORY BOOKS Robert Hansen Military Aviation 0 February 19th 04 02:10 AM
Enola Gay: Burnt flesh and other magnificent technological achievements me Military Aviation 146 January 15th 04 10:13 PM
F-14 on the History Channel's "Modern Marvels" Brian J. McCann Military Aviation 15 October 12th 03 02:12 PM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
