On Wednesday, 5 May 2021 at 01:35:20 UTC+3, Aldo Cernezzi wrote:
When flying in the mountains, instant wind vector display is an absolute advantage. In the flatland, an averaged calculation may be satisfactory. I used to be a big Zander fan (magnetic compass interface, almost completely free from the unsolvable problems created by flux-gate compasses). Now I'm happy to see a new generation of promising devices. Aldo Cernezzi www.voloavela.it The vector math of calculating instant wind from TAS/GS difference with corresponding flight track is pretty simple. What I don't understand is how to do this unless you have consecutive wind vectors from different directions.. Thus Hawk cannot update wind reading unless glider is in circling flight. Yes there is no problems with compass, but there is no way of determining wind by flying to one direction. |
On 5/5/2021 1:38 PM, krasw wrote:
On Wednesday, 5 May 2021 at 01:35:20 UTC+3, Aldo Cernezzi wrote: When flying in the mountains, instant wind vector display is an absolute advantage. In the flatland, an averaged calculation may be satisfactory. I used to be a big Zander fan (magnetic compass interface, almost completely free from the unsolvable problems created by flux-gate compasses). Now I'm happy to see a new generation of promising devices. Aldo Cernezzi www.voloavela.it The vector math of calculating instant wind from TAS/GS difference with corresponding flight track is pretty simple. What I don't understand is how to do this unless you have consecutive wind vectors from different directions. Thus Hawk cannot update wind reading unless glider is in circling flight. Yes there is no problems with compass, but there is no way of determining wind by flying to one direction. Have you read their paper? They are certain they can determine wind without circling or a compass. I don't pretend to understand the paper, but this portion from the paper describes how it might be possible: "The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Thursday, 6 May 2021 at 00:15:44 UTC+3, Eric Greenwell wrote:
"The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 For wind vector you need two TAS-GS difference/track vectors. If they are identical (same direction of flight), you have no wind solution (as stated in paper). Optimum would be two vectors with 90 degrees difference, and measured in extremely short duration (this is how Oudie "live wind" tries to do it, though I haven't got it working). This would give an ok solution in circling flight, but at the same time the angular speed while circling is not very high, so sensing wind vector at different parts of thermal is rather slow (on steep turn with AIR Glide S gives you basically 20-25 separate wind measurements with 1 sec average). In straight flight Hawk is relying on miniscule differences in flight track. Instead of two wind vector components with 90 degree difference in direction they have vectors that have only few degrees difference on average. I would love to see someone comparing wind indications of Hawk and Glide S someday. |
On Thursday, 6 May 2021 at 06:48:03 UTC+1, krasw wrote:
On Thursday, 6 May 2021 at 00:15:44 UTC+3, Eric Greenwell wrote: "The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 For wind vector you need two TAS-GS difference/track vectors. If they are identical (same direction of flight), you have no wind solution (as stated in paper). Optimum would be two vectors with 90 degrees difference, and measured in extremely short duration (this is how Oudie "live wind" tries to do it, though I haven't got it working). This would give an ok solution in circling flight, but at the same time the angular speed while circling is not very high, so sensing wind vector at different parts of thermal is rather slow (on steep turn with AIR Glide S gives you basically 20-25 separate wind measurements with 1 sec average). In straight flight Hawk is relying on miniscule differences in flight track. Instead of two wind vector components with 90 degree difference in direction they have vectors that have only few degrees difference on average. I would love to see someone comparing wind indications of Hawk and Glide S someday. Krasw, if you study the paper you will see that your end point is the author's start question i.e. how can you possibly estimate 3D "wind" at high frequency without heading data input from a magnetometer? |
The paper is fairly circumspect on the details of what they are doing. Their claim that this hasn't been done before seems disingenuous, given that the Air Vario had been out for a number of years producing (or claiming to produce) a similar result. Air's efforts are described in a university published paper from some years ago. Their methods appear to be similar. But I am glad that someone has taken up the challenge that Air Avionics has now dropped. Whether it is better or worse will require installing both in the panel and flying for awhile. The advantages they expound of knowing the true wind in real time are already well known to anyone with an Air Display S who has paid attention to it.
On Thursday, May 6, 2021 at 1:27:24 AM UTC-7, wrote: On Thursday, 6 May 2021 at 06:48:03 UTC+1, krasw wrote: On Thursday, 6 May 2021 at 00:15:44 UTC+3, Eric Greenwell wrote: "The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 For wind vector you need two TAS-GS difference/track vectors. If they are identical (same direction of flight), you have no wind solution (as stated in paper). Optimum would be two vectors with 90 degrees difference, and measured in extremely short duration (this is how Oudie "live wind" tries to do it, though I haven't got it working). This would give an ok solution in circling flight, but at the same time the angular speed while circling is not very high, so sensing wind vector at different parts of thermal is rather slow (on steep turn with AIR Glide S gives you basically 20-25 separate wind measurements with 1 sec average). In straight flight Hawk is relying on miniscule differences in flight track. Instead of two wind vector components with 90 degree difference in direction they have vectors that have only few degrees difference on average. I would love to see someone comparing wind indications of Hawk and Glide S someday. Krasw, if you study the paper you will see that your end point is the author's start question i.e. how can you possibly estimate 3D "wind" at high frequency without heading data input from a magnetometer? |
On Thursday, 6 May 2021 at 16:54:14 UTC+1, jfitch wrote:
The paper is fairly circumspect on the details of what they are doing. Their claim that this hasn't been done before seems disingenuous, given that the Air Vario had been out for a number of years producing (or claiming to produce) a similar result. Air's efforts are described in a university published paper from some years ago. Their methods appear to be similar. But I am glad that someone has taken up the challenge that Air Avionics has now dropped. Whether it is better or worse will require installing both in the panel and flying for awhile. The advantages they expound of knowing the true wind in real time are already well known to anyone with an Air Display S who has paid attention to it. On Thursday, May 6, 2021 at 1:27:24 AM UTC-7, wrote: On Thursday, 6 May 2021 at 06:48:03 UTC+1, krasw wrote: On Thursday, 6 May 2021 at 00:15:44 UTC+3, Eric Greenwell wrote: "The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 For wind vector you need two TAS-GS difference/track vectors. If they are identical (same direction of flight), you have no wind solution (as stated in paper). Optimum would be two vectors with 90 degrees difference, and measured in extremely short duration (this is how Oudie "live wind" tries to do it, though I haven't got it working). This would give an ok solution in circling flight, but at the same time the angular speed while circling is not very high, so sensing wind vector at different parts of thermal is rather slow (on steep turn with AIR Glide S gives you basically 20-25 separate wind measurements with 1 sec average). In straight flight Hawk is relying on miniscule differences in flight track. Instead of two wind vector components with 90 degree difference in direction they have vectors that have only few degrees difference on average. I would love to see someone comparing wind indications of Hawk and Glide S someday. Krasw, if you study the paper you will see that your end point is the author's start question i.e. how can you possibly estimate 3D "wind" at high frequency without heading data input from a magnetometer? The Air Avionics wind and blue ball netto calculations are dependent on data from an accurately reading magnetometer - and installing one of those free from EM fields is its Achilles' heel, and also the reason I never got one when they were still on sale So, to my mind the Hawk method is definitely new - although I am more interesting in finding out whether it works rather than who did what first. I thought the paper contained a lot detail on the concept and implementation including the statement: "Mathematical system theory also answers the question under which conditions wind estimation is possible. In the limiting case of an exactly straight-line flight motion and perfectly calm air, this is not possible. All triangles are identical. However, we could show (Huang und Meyr) that the random changes in the airmass movement are sufficient to make the system "observable"." From this, if true, one might infer that what would be to the pilot "miniscule differences in flight track" would actually yield plenty data for the system to calculate wind. |
Air Avionics have been equally circumspect on exactly what they do, and how much each of the 9 axis MEMs sensors contribute to that. Using the magnetometer has some advantages, as the limiting case of straight line flight in steady flow can still produce a wind calculation, also it makes inherent an AHRS which is not possible without it. I'd agree that the result is the most important, I'd pop one in the panel and find out but they are a bit pricey as an impulse purchase - costing somewhat more than an Air Avionics did when they were still sold.
On Thursday, May 6, 2021 at 10:04:42 AM UTC-7, wrote: On Thursday, 6 May 2021 at 16:54:14 UTC+1, jfitch wrote: The paper is fairly circumspect on the details of what they are doing. Their claim that this hasn't been done before seems disingenuous, given that the Air Vario had been out for a number of years producing (or claiming to produce) a similar result. Air's efforts are described in a university published paper from some years ago. Their methods appear to be similar. But I am glad that someone has taken up the challenge that Air Avionics has now dropped. Whether it is better or worse will require installing both in the panel and flying for awhile. The advantages they expound of knowing the true wind in real time are already well known to anyone with an Air Display S who has paid attention to it. On Thursday, May 6, 2021 at 1:27:24 AM UTC-7, wrote: On Thursday, 6 May 2021 at 06:48:03 UTC+1, krasw wrote: On Thursday, 6 May 2021 at 00:15:44 UTC+3, Eric Greenwell wrote: "The mathematical system theory also answers the question under what conditions a wind estimation is possible. In the case of a borderline case of an exact straight flight movement and completely calm air, this is not possible. All triangles are identical. We (Huang and Meyr) could show, however, that the random changes in the air movement are sufficient to make the system "observable.” " -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 For wind vector you need two TAS-GS difference/track vectors. If they are identical (same direction of flight), you have no wind solution (as stated in paper). Optimum would be two vectors with 90 degrees difference, and measured in extremely short duration (this is how Oudie "live wind" tries to do it, though I haven't got it working). This would give an ok solution in circling flight, but at the same time the angular speed while circling is not very high, so sensing wind vector at different parts of thermal is rather slow (on steep turn with AIR Glide S gives you basically 20-25 separate wind measurements with 1 sec average). In straight flight Hawk is relying on miniscule differences in flight track. Instead of two wind vector components with 90 degree difference in direction they have vectors that have only few degrees difference on average. I would love to see someone comparing wind indications of Hawk and Glide S someday. Krasw, if you study the paper you will see that your end point is the author's start question i.e. how can you possibly estimate 3D "wind" at high frequency without heading data input from a magnetometer? The Air Avionics wind and blue ball netto calculations are dependent on data from an accurately reading magnetometer - and installing one of those free from EM fields is its Achilles' heel, and also the reason I never got one when they were still on sale So, to my mind the Hawk method is definitely new - although I am more interesting in finding out whether it works rather than who did what first. I thought the paper contained a lot detail on the concept and implementation including the statement: "Mathematical system theory also answers the question under which conditions wind estimation is possible. In the limiting case of an exactly straight-line flight motion and perfectly calm air, this is not possible. All triangles are identical. However, we could show (Huang und Meyr) that the random changes in the airmass movement are sufficient to make the system "observable"." From this, if true, one might infer that what would be to the pilot "miniscule differences in flight track" would actually yield plenty data for the system to calculate wind. |
On Thursday, 6 May 2021 at 18:54:14 UTC+3, jfitch wrote:
The paper is fairly circumspect on the details of what they are doing. Their claim that this hasn't been done before seems disingenuous, given that the Air Vario had been out for a number of years producing (or claiming to produce) a similar result. Air's efforts are described in a university published paper from some years ago. Yes, they are ignoring basically everything that has been done with variometer tech during last 25 years. |
On 5/7/2021 3:33 AM, krasw wrote:
On Thursday, 6 May 2021 at 18:54:14 UTC+3, jfitch wrote: The paper is fairly circumspect on the details of what they are doing. Their claim that this hasn't been done before seems disingenuous, given that the Air Vario had been out for a number of years producing (or claiming to produce) a similar result. Air's efforts are described in a university published paper from some years ago. Yes, they are ignoring basically everything that has been done with variometer tech during last 25 years. Not ignoring, but purposely avoiding pressure variometry and it's inherent problems. LXNav has chosen to add Hawk to their varios, so the commercial implementation of Hawk (currently in the S100) does not ignore conventional pressure variometer tech. What Jon is wondering, as I am, is how different is Hawk from the techniques used to drive the Air Vario's "Blue Ball". -- Eric Greenwell - USA - "A Guide to Self-launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Wednesday, May 5, 2021 at 4:38:38 PM UTC-4, krasw wrote:
On Wednesday, 5 May 2021 at 01:35:20 UTC+3, Aldo Cernezzi wrote: When flying in the mountains, instant wind vector display is an absolute advantage. In the flatland, an averaged calculation may be satisfactory. I used to be a big Zander fan (magnetic compass interface, almost completely free from the unsolvable problems created by flux-gate compasses). Now I'm happy to see a new generation of promising devices. Aldo Cernezzi www.voloavela.it The vector math of calculating instant wind from TAS/GS difference with corresponding flight track is pretty simple. What I don't understand is how to do this unless you have consecutive wind vectors from different directions. Thus Hawk cannot update wind reading unless glider is in circling flight. Yes there is no problems with compass, but there is no way of determining wind by flying to one direction. Have you heard of "Growth mindset"? I think the appropriate thing to say would have been that you would love to learn how that was achieved, just in case you might be wrong, especially if some very smart people said that they had done it. |
Boeing T-7 Red Hawk pics [1/5] - Cockpit-do-T-7A-Red-Hawk-produzido-pela-Elbit-Systems-US.jpg (1/1) | Miloch | Aviation Photos | 0 | October 9th 19 02:30 PM |
Vector Wind, Relative Wind calculation C 302/303 | [email protected] | Soaring | 2 | December 9th 08 07:23 PM |
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) | JR[_2_] | Aviation Photos | 0 | August 13th 08 09:36 PM |
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) | JR[_2_] | Aviation Photos | 0 | August 13th 08 09:35 PM |
It Was 103 Years Ago This Week - First flight of first motor machine, Dec. 17, 1903, near Kill Devil Hills, Kitty Hawk, N.C. Against a wind of 24 miles an hour.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 18th 06 02:24 PM |
