padding in Cobra trailer
Old April 29th 21, 02:11 PM posted to rec.aviation.soaring
Guy Acheson[_2_]
Default padding in Cobra trailer
I used Goo Gone, waited an hour and used a paint scraper.
Then you have to wash off the Goo Gone.
Was not that big a deal.
Taping off the areas for the new padding and painting on the rubber cement was intoxicating.
Must do that outside or the fumes will become overwhelming.
New glued on outdoor carpet is still holding strong.
Old April 29th 21, 04:41 PM posted to rec.aviation.soaring
jfitch
It is easier to use spray contact adhesive. Use 3M 90, not 3M 77.
Old April 30th 21, 08:50 PM posted to rec.aviation.soaring
Dgtarmichael
Anybody ever use boat carpeting? Rubber padded
backing and holds up to the elements.
-Doug
W24
Old May 5th 21, 11:24 PM posted to rec.aviation.soaring
Darren Braun
The carpet in my Cobra trailer is shedding badly. I would like to replace or cover it. Open to any ideas on how to remove the old carpet or can you just put some new material on top of the old? What material would be best? Soft felt, hard felt, carpet?
The carpet generally comes off surprisingly easy, I found. That's the best property of the original carpet. But it makes a powdery mess as you do so wear mask and probably gloves...
What is left behind is a bit of a sticky that I didn't care to remove. Instead I used loctite spray adhesive and a basic low pile outdoor carpet as the replacement. You will want to save the old pieces to use as a template.
Darren
Old May 6th 21, 03:04 AM posted to rec.aviation.soaring
Mark Mocho
Adhesive carpet tiles. Cut to fit. You also can work with one at a time rather than wrestling with a large piece of carpet. Pick tiles with either no padding or something other than the foam on Cobra carpet, which disintegrates in a dry climate.
https://www.google.com/shopping/prod...Q_dDasQ9pwGCAY
Cobra Trailer VIN MSC Soaring 3 July 1st 18 07:05 PM
New Cobra trailer - - which top? Ben[_6_] Soaring 34 February 19th 15 09:43 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
