In article , Ralph Savelsberg
wrote: And more in general stands for Active Electronically Scanned Array, which is the name for the type of antenna/emitter group. Instead of a mechanically swivelling antenna (with complicated waveguides and a heavy hydraulic system to move it around) this has a flat, fixed array Instead it has a liquid cooling system. Still, a lot more reliable than hydraulics. To keep this in the naval vein, it needs to be mentioned that the APG-65 and APG-73 antennas use electric motors to drive the antenna, not hydraulics. But of course, the response time of any mechanical system is much slower than electronic steeting. consisting of multiple emitter/receiver modules. The beam is controlled electronically and at least in theory such a radar can use multiple modes simultaneously. In the F/A-18F (with the ACS) this could mean that for instance the pilot would have an air-to-air mode selected, while the NFO in the back could be using a ground-mapping mode at the same time. A small number of USAF F-15Cs (from the 3rd FW in Alaska if I'm not mistaken) already fly with a radar with such an antenna: a modified version of the regular APG-63(V)1 (unsurprisingly) called the APG-63(V)2 . The APG-79 is a newer generation. USAF is looking into a fleet-wide retrofit of F-15C's and E's with AESA based on the extremely positive results of the (V)2. This would also be newer generation. APG-63(V)2 is the world's first production AESA radar. The first F/A-18F fitted with the APG-79 has already undertaken its first flight. -- Harry Andreas Engineering raconteur |
New aviation history interview: Fokker/Curtiss/Messerschmitt ace Mauno Fräntilä | Jukka O. Kauppinen | Military Aviation | 0 | September 22nd 04 11:18 PM |
MILITARY HISTORY BOOKS | Robert Hansen | Military Aviation | 0 | February 19th 04 02:10 AM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
F-14 on the History Channel's "Modern Marvels" | Brian J. McCann | Military Aviation | 15 | October 12th 03 02:12 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
