OLC scoring errors
Old May 9th 21, 04:06 PM posted to rec.aviation.soaring
Mark Mocho
Default OLC scoring errors
Over the years, I have had occasionally thought that the OLC had not scored my flights correctly. Upon extensive analysis using tools like SeeYou, I have never been able to pick points on the flight trace that have increased my score. As far as the triangle distance being much less than what I expected, in every case I had failed to "close" my triangle by recrossing my flight path or coming within the 1 km that is required. Therefore, my "supposed" triangle was not counted and the largest FAI triangle that was actually achieved was counted instead. I have analyzed other pilots' flights where the score is questionable with the same results. The only tool that I have used to change my score was entering a different Start or Finish time, and the resulting difference wasn't enough to squawk about. Maybe others have had different experiences, but in my case, the OLC has been pretty reliable at giving me the best score for a particular flight.
OLC Posting Errors Rodger R[_2_] Soaring 1 July 9th 12 03:12 AM
Dallas-Fort Worth TRACON Management Routinely Misclassified Operational Errors and Deviations as Pilot Errors Larry Dighera Piloting 56 May 6th 08 01:17 AM
DFW ATC identifying Operational Errors As Pilot Errors? Larry Dighera Piloting 8 July 18th 07 10:49 PM
OLC errors ! Mal[_3_] Soaring 0 April 17th 07 12:33 PM
TE errors f.blair Soaring 7 March 9th 05 08:51 AM
