Two Seat Cobra Trailer Tire Replacement
Old May 16th 21, 06:14 PM posted to rec.aviation.soaring
2G
Default Two Seat Cobra Trailer Tire Replacement
On Monday, May 10, 2021 at 8:23:04 AM UTC-7, AS wrote:
Trailers are designed with tandem axles because one axle can't carry the load of the trailer, not to provide greater stability. When turning while pulling a tandem the axles are not aligned with the center of rotation - they can't be because the axles are parallel. The tires want to go in a different direction than the rotation of the turn and must, to some degree, scrub to make the turn. This is why maneuvering them by hand is so difficult. The same thing is happening when being towed but the power of the tow vehicle forces the tires in the direction of the turn. This scrubbing action deteriorates stability, not enhances it.
Tom
I call 'hog-wash' on this one! There are a few trailers by the same manufacturer with the same glider inside in the exactly the same configuration but they have a single axle with larger wheels. The load bearing capability is the the same in both cases. Going to a tandem axle enhances stability (tracking) and allows the whole trailer to sit lower since the wheels on the tandem axle are typically smaller. Lower CoG = more stability.
I completely agree with your point of them being a pain in the butt to man-handle them.
Uli
'AS'
The tire scrubbing that does occur during turning (no one seems to dispute that as it is obviously true) cannot "enhance" stability; the trailer is literally fighting being turned by the tow vehicle. If this were the case then adding even more axles would make the trailer even more stable. Trailers, or vehicles, with many axles (transporters) articulate the wheels for this reason.
Tom
Old May 16th 21, 09:52 PM posted to rec.aviation.soaring
Bob W.
Snipperoo...
stability.
typically smaller. Lower CoG = more stability. I completely agree
them.
Uli 'AS'
Well, hey - since this thread began with discussing a glider-trailer
towing topic, better into the thread-drift weeds than verge weeds, I
suppose...
I am not a professional trailer designer nor have I played one on
TV...but I've delivered manufacturing-componentry-parts to a dozen (or
so) of 'em in my engineering retirement. I'll bet my retirement slush
fund that multiple reasons exist for quantity-of-axles choices for a
given trailer design, trailer/axle carrying capacities *generally* being
near the top of the list.
As for trailer stability, it'd be difficult to get a more stable trailer
than one with infinite rolling-resistance drag. Or any other kind of
drag, for that matter. I am, of course, assuming that keeping the CG of
any towed trailer behind the towing vehicle while said vehicle is moving
forward, is desirable...
I'll further bet some of my retirement slush fund winnings from above,
that the somewhat-implicit assertion of the final sentence of the above
snippet, is "debatable" (as in, the sweeping claim made, is far from "an
absolute, given, fact") - with the desire for increased stability (or
its lack) *not* being at the top of a designer's list of rationales for
incorporating steerable trailer tires.
YMMV.
Bob W.
Old May 16th 21, 11:08 PM posted to rec.aviation.soaring
George Haeh
We just need an extra crew or autopilot to steer the trailer:
https://youtu.be/xa2ihMkzX3g
Old May 17th 21, 08:53 AM posted to rec.aviation.soaring
Tango Whisky
I think you've got the base wrong.
Stability is defined as a the resistance of a system to the influence of a disturbance.
If you are driving along with your trailer, a lateral wind gust will push the trailer to the side nd causing it to sway.
Having two axles, the scrubbing of the tires will damp the push to the side - that's the definition of increased stability.
Le dimanche 16 mai 2021 Ã* 19:14:22 UTC+2, 2G a écritÂ*:
Trailers are designed with tandem axles because one axle can't carry the load of the trailer, not to provide greater stability. When turning while pulling a tandem the axles are not aligned with the center of rotation - they can't be because the axles are parallel. The tires want to go in a different direction than the rotation of the turn and must, to some degree, scrub to make the turn. This is why maneuvering them by hand is so difficult.. The same thing is happening when being towed but the power of the tow vehicle forces the tires in the direction of the turn. This scrubbing action deteriorates stability, not enhances it.
Tom
Uli
'AS'
Tom
Old May 22nd 21, 04:24 AM posted to rec.aviation.soaring
2G
Tom
Uli
'AS'
Tom
Two tires does double the sidewall resistance to rolling. The surface area of a glider trailer (30' x 3') exposed to a side gust, however, is pretty small compared to my travel trailer (33' x 8'). I can tow my glider as fast as the speed limit allows (80 mph in places) w/o roll or yaw stability problems (single axle), but I will slow down to 55 or 60 if it gets gusty while towing the travel trailer. I do tow with large vehicles (F-250 Super Duty), not baby SUVs, which makes a difference.
Tom
Cobra Trailer Spare Tire mount failure Barny Soaring 29 July 23rd 15 12:52 AM
Cobra trailer tire size? Tuno Soaring 15 June 8th 10 06:39 AM
Cobra trailer weatherstrip replacement Larry Goddard Soaring 0 November 25th 09 05:26 AM
Cobra Trailer Replacement Wheel Chip Bearden Soaring 5 September 29th 09 08:35 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
