Flarm Target direction
Old June 3rd 21, 06:24 PM posted to rec.aviation.soaring
Roy B.
Default Flarm Target direction
Ramy:
I don't profess expertise in this area, but note that in addition to the carbon underbelly there is a lot of hardware under the glare shield mounted Flarm antenna that can block downward/forward transmission: canopy hinge mechanisms, rudder pedals & adjuster, instruments, flasks, computers, and even the metal Flarm Core box itself.
Again, I not knocking Flarm - it's a useful tool. But I don't depend on it to avoid you guys . . .
ROY
Old June 3rd 21, 09:30 PM posted to rec.aviation.soaring
George Haeh
I mount two long antennas on opposite sides of my canopy. Use a block with Velcro to keep the antenna tips clear of the canopy. Having transmit on both antennas as with Fusion is even better.
Unfortunately Flarm advertised dual transmit with the Core 1.1, but omitted to obtain approvals for North America.
For a new glider I'd spec Flarm and transponder antennas in the fin, perhaps with an access panel, and the secondary Flarm Antenna on a canopy side to cover the blind spot overhead the tailplane.
Boulton Paul Defiant pics 2 [3/7] - Defiant TT Mk III target tug, number N1697; RAF Desford, May 1944. The wind-driven generator provided power for the target winch.jpg (1/1) Miloch Aviation Photos 0 September 10th 18 03:25 PM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
