#11
"Morgans" jisumorgan@charterdotjunkdotnet wrote in message
... So you think the leaf blower idea would be about as effective at increasing HP, as farting into the carb for the methane content? You may have a point. Anyone have some pressure gauge that could measure the small amounts of boost at the business end of a leaf blower? I would be curious to see what good one would do. Actually, two things came to mind. 1. Using the leaf blower to: a. burn gasoline to b. turn a fan to c. blow air into another engine to: d. burn gasoline to e. turn a fan to f. produce thrust Seems somewhat inefficient. If the leaf blower simply uses its horsepower to add the thrust, it cuts out steps c, d, & e. 2. The leaf blower would be suffering the same anoxia as the main powerplant. Perhaps one could use a Cox .049 to increase its manifold pressure? ;o) "Great fleas have little fleas upon their backs to bite 'em. And little fleas have lesser fleas, and so ad infinitum." Rich S. |
On Sat, 5 Jul 2003 11:45:50 -0700, "Rich S."
wrote: The weedeater Barracuda is rated at 370 cfm. It will produce boost up to just below that point. "Morgans" jisumorgan@charterdotjunkdotnet wrote in message ... So you think the leaf blower idea would be about as effective at increasing HP, as farting into the carb for the methane content? You may have a point. Anyone have some pressure gauge that could measure the small amounts of boost at the business end of a leaf blower? I would be curious to see what good one would do. Actually, two things came to mind. 1. Using the leaf blower to: a. burn gasoline to b. turn a fan to c. blow air into another engine to: d. burn gasoline to e. turn a fan to f. produce thrust Seems somewhat inefficient. If the leaf blower simply uses its horsepower to add the thrust, it cuts out steps c, d, & e. 2. The leaf blower would be suffering the same anoxia as the main powerplant. Perhaps one could use a Cox .049 to increase its manifold pressure? ;o) "Great fleas have little fleas upon their backs to bite 'em. And little fleas have lesser fleas, and so ad infinitum." Rich S. |
![]() clare @ snyder.on .ca wrote in message ... On Sat, 5 Jul 2003 11:45:50 -0700, "Rich S." wrote: The weedeater Barracuda is rated at 370 cfm. It will produce boost up to just below that point. How much boost? -- Jim in NC |
On Sat, 5 Jul 2003 01:06:22 -0700, "Paul Millner"
wrote: NOS needs a rather healthy mixture to begin with (As I recall it helps with cooling)... NOS adds a bunch of heat to the engine, so no, it doesn't help with cooling. Ummmm..no, that;'s not what I said. I said it requires a rather healthy mixture which helps with the cooling (need created by the NOS) Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Basically, it's a safer way to add oxygen to the incoming air than injecting oxygen directly... so since the incoming air is now much more oxygen rich, you need a bunch more fuel, or your mixture will go very lean. In that sense, it's an alternative to turbocharging... but the NOS bottle will last a minute or so, OK for one takeoff... then what? :-) Paul, turbo Cardinal mode |
On Sat, 5 Jul 2003 07:05:04 -0400, "Morgans"
jisumorgan@charterdotjunkdotnet wrote: "Rich S." wrote in message ... "Morgans" wrote in message ... It might work more better to have it blowing into the engine for this poster's intent. :-) -- Jim in NC Ah.... but would it? Rich "Best use of horsepower?" S. So you think the leaf blower idea would be about as effective at increasing HP, as farting into the carb for the methane content? I need to measure the pressure, but I'd guess the one I have with the 200 mph exhaust is about 15 inches or more. However were it deadheaded, I don't know what it could do. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) You may have a point. Anyone have some pressure gauge that could measure the small amounts of boost at the business end of a leaf blower? I would be curious to see what good one would do. Didn't a guy use a two cycle engine setup to boost his engine for a race lately? What kind of deal did he use? |
"Morgans" wrote...
snip Didn't a guy use a two cycle engine setup to boost his engine for a race lately? What kind of deal did he use? A Rotax powered the blower that fed the main engine. Reason being was to offset the race altitude, where it was held... |
Johnboy wrote:
I doubt that a leaf blower with a 200 mph exhaust will actually produce that much. I would guess about 1/2 a PSI. The turbo on my supra costs $2600, turns at 90,000 rpm, is attached to a 275HP engine, and only puts out 8 PSI. Do you really think a $40.00 leaf blower will compare? First, how much you paid for it has absolutely nothing to do with how much pressure it will produce. Second, where are you finding $40 gas powered leaf blowers. I need one. -- ----Because I can---- http://www.ernest.isa-geek.org/ ------------------------ |
If your blower has an exhaust velocity of 200 MPH the maximum pressure
recovery in a diffuser would be about .7 pounds/in2, realistically about .5 lbs/in2. RJ "Roger Halstead" wrote in message ... On Sat, 5 Jul 2003 07:05:04 -0400, "Morgans" jisumorgan@charterdotjunkdotnet wrote: "Rich S." wrote in message ... "Morgans" wrote in message ... It might work more better to have it blowing into the engine for this poster's intent. :-) -- Jim in NC Ah.... but would it? Rich "Best use of horsepower?" S. So you think the leaf blower idea would be about as effective at increasing HP, as farting into the carb for the methane content? I need to measure the pressure, but I'd guess the one I have with the 200 mph exhaust is about 15 inches or more. However were it deadheaded, I don't know what it could do. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) You may have a point. Anyone have some pressure gauge that could measure the small amounts of boost at the business end of a leaf blower? I would be curious to see what good one would do. Didn't a guy use a two cycle engine setup to boost his engine for a race lately? What kind of deal did he use? |
![]() "RJ Cook" wrote in message .. . If your blower has an exhaust velocity of 200 MPH the maximum pressure recovery in a diffuser would be about .7 pounds/in2, realistically about ..5 lbs/in2. RJ Sounds like a good swag. How does lbs/sq.-in relate to inches of mercury (as in manifold pressure)? -- Jim in NC |
In article , "Morgans"
jisumorgan@charterdotjunkdotnet writes: If your blower has an exhaust velocity of 200 MPH the maximum pressure recovery in a diffuser would be about .7 pounds/in2, realistically about .5 lbs/in2. RJ Sounds like a good swag. How does lbs/sq.-in relate to inches of mercury (as in manifold pressure)? -- Jim in NC With all this talk of using a gas powered blower would someone please explain how that blower is going to overcome the effects of altitude and maintain the same velocity of air. It is going to drop off in power just as the engine will and at altitude its effect will be nil. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
