![]() "Ron Wanttaja" wrote in message ... On Fri, 19 Dec 2003 18:05:53 -0500, "Larry Smith" wrote: "EDR" wrote in message ... I have seen Warp Drive props on friends Ezes. The coning scares me! What's "coning"? The prop blades bending forward...the prop disk defines a shallow cone (open end frontward, of course) under load. Ron Wanttaja Thanks. As usual the big R comes through. I've seen the phenomenon but it's not bothersome to someone knowing the great strength and elasticity modulus of carbon fiber. Where is testimony that a blade has failed? There is gossip about an Ivoprop but is it true? |
On Sat, 20 Dec 2003 10:06:12 -0500, "Larry Smith"
wrote: "Ron Wanttaja" wrote in message .. . On Fri, 19 Dec 2003 18:05:53 -0500, "Larry Smith" Thanks. As usual the big R comes through. I've seen the phenomenon but it's not bothersome to someone knowing the great strength and elasticity modulus of carbon fiber. Where is testimony that a blade has failed? There is gossip about an Ivoprop but is it true? I have a warp drive 70" 3 blade prop on my murphy rebel with an 0-290 engine. I'm very satisfied with the prop and have had no problems with mine. It's fairly easy to change the pitch takes about an hour including retourquing and safety wiring everything. You need to check the torque on the clamp bolts every 25 hrs. There have been some reports of cracked blades on high compression engines. It's suspected that the negative power pulses at idle speed is what causes the cracking. Drew Dalgleish Centralia Ont. |
it's not bothersome to someone knowing the great strength and elasticity modulus of carbon fiber. Where is testimony that a blade has failed? There is gossip about an Ivoprop but is it true? A friend of mine has a 4 blade on his 180hp Lyc Rebel on floats. He flies all year including a annual trip to the Arctic (he's located about 100miles north of the US border so this isn't a quick trip) He had to land once on a lake with about 3-4 foot rollers when heavy (2K+) and he had spray coming over the windshield etc. Either the prop dipped into the water or something as afterwards he found one blade cracked along the root holder. He maintains his machine like a certified so he grounded the airplane and was on to warp about it pdq. They said he could fly with it as is ie it was still servicable and it wouldn't hurt anything. I think he said he only flew it a few minutes before getting too paranoid about it. He called warp and they replaced the blade for free. They said at that time his was the first damaged blade they had seen and that was in 2000. He still swears by it even though I think he's thinking about a hoffman or the like so he can nudge closer to mach 1 on floats... Even under owner maintained you won't be able to swap a warp for a certified blade. The ministry will tend to frown on such things. You could get a stc and hope they will let you spec a warp but as its not certified you are going to have to be reaaal lucky to get it through. The fee is $900 loonies plus engineering fees which means it will probably be cheaper to buy a new plane by the end f it all ;-] Q |
On Sun, 21 Dec 2003 20:01:57 GMT, " quipbid
wrote: Snip nice rebel story Even under owner maintained you won't be able to swap a warp for a certified blade. The ministry will tend to frown on such things. You could get a stc and hope they will let you spec a warp but as its not certified you are going to have to be reaaal lucky to get it through. The fee is $900 loonies plus engineering fees which means it will probably be cheaper to buy a new plane by the end f it all ;-] Q I haven't heard of aircraft registered in the owner maintenance class requiring an STC for anything before. Where did you get this information from? I was under the impression that pretty much anything goes. That's how we end up with corvette powered sea-bees Drew Dalgleish |
