That's one of the points, you can tell the mfg. Doh!
"Thomas Schoene" wrote in message ink.net... Nice Again wrote: F fighter 8 eighth model F Grumman This has always seemed harder to me than the Air Force/unified system F Fighter 16 16th type since 1962 Under the Navy designation system, the Hornet would have changed designations from F5D to F3B (I think) when Boeing bought out McDonnell Douglas. You'd have had nearly identical aircraft with two different designations, probably in the same squadrons. Seems rather nonsensical. (The same system had wartime Corsairs as either F4Us or FGs depending on who built them.) "Steven P. McNicoll" wrote in message ink.net... "Nice Again" wrote in message ... And the 'easy' way of identification was lost forever! Eh? -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
Nice Again wrote:
That's one of the points, you can tell the mfg. Doh! It was was pointed out in another forum that you can tell the manufacturer of an AF craft if the complete designator is used. Such as: P-38J-25-LO P-47D-25-RE P-51H-5-NA B-17F-1-DL (Built by Douglas) B-17F-1-BO (Boeing) The Navy simply made it a more integral part of the designation. I do not know if this holds true still in the standardised designation system. -- Lynn in StLou REMOVE anti-spam measure to reply |
Nice Again wrote:
That's one of the points, you can tell the mfg. Doh! I'd call it a bug, not a feature. If it told you the designer, it might be of some value, but manufacturer names are often too fluid to be helpful. As is, the system is potentially quite confusing, as the examples given before can show (F4U, FG and F3B are the same plane!?!) It makes little sense to use a system that requires different designations for the same aircraft just because it was built by different companies or the factory changed ownership. Moreover, from an amateur's perspective, the Navy system makes it difficult to instantly recognize which aircraft came first in production, or tell which are contemporaries of each other. The F4U and F4D aren't even remotely of the same era, for example, but you can't tell that from their designations. OTOH, you can tell that the F-14, -15, and -16 came in that order and probably realize that they are rough contemporaries. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
![]() "Thomas Schoene" wrote in message link.net... I'd call it a bug, not a feature. If it told you the designer, it might be of some value, but manufacturer names are often too fluid to be helpful. As is, the system is potentially quite confusing, as the examples given before can show (F4U, FG and F3B are the same plane!?!) Ah, but they're not the same plane! The F4U was, of course, the Vought Corsair, and the FG was a Corsair built by Goodyear. But the F3B was a Boeing biplane fighter of the late twenties. The Brewster-built Corsair was the F3A. |
Steven P. McNicoll wrote:
"Thomas Schoene" wrote in message link.net... I'd call it a bug, not a feature. If it told you the designer, it might be of some value, but manufacturer names are often too fluid to be helpful. As is, the system is potentially quite confusing, as the examples given before can show (F4U, FG and F3B are the same plane!?!) Ah, but they're not the same plane! The F4U was, of course, the Vought Corsair, and the FG was a Corsair built by Goodyear. But the F3B was a Boeing biplane fighter of the late twenties. The Brewster-built Corsair was the F3A. Hmm, I think we just proved our collective point. :-) -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
You're obviously not a Navy aviator.
"Thomas Schoene" wrote in message link.net... Nice Again wrote: That's one of the points, you can tell the mfg. Doh! I'd call it a bug, not a feature. If it told you the designer, it might be of some value, but manufacturer names are often too fluid to be helpful. As is, the system is potentially quite confusing, as the examples given before can show (F4U, FG and F3B are the same plane!?!) It makes little sense to use a system that requires different designations for the same aircraft just because it was built by different companies or the factory changed ownership. Moreover, from an amateur's perspective, the Navy system makes it difficult to instantly recognize which aircraft came first in production, or tell which are contemporaries of each other. The F4U and F4D aren't even remotely of the same era, for example, but you can't tell that from their designations. OTOH, you can tell that the F-14, -15, and -16 came in that order and probably realize that they are rough contemporaries. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
![]() "Nice Again" wrote in message ... That's one of the points, you can tell the mfg. Doh! So what? With that system you wind up with multiple designations for virtually identical aircraft. A Corsair could be an F4U, an FG, or an F3A. Boeing, Douglas and Vega all built Flying Fortresses, but under the USAAF system they were all B-17s. |
Grumman FAAV? | Charles Gray | Military Aviation | 1 | July 19th 04 06:55 AM |
Most aircraft types flown by 1 pilot? | Chad Irby | Military Aviation | 10 | January 7th 04 03:47 AM |
