Dudley,
It used to be standard procedure at a major U.S. Airline which shall go un-named (AA) to do just that on every approach. Pilots scoffed at it at first, and then swore by it after they'd done it a few times. QFE vs. QNH. That airline doesnąt do it any more. --Woody On 1/26/04 10:15 AM, in article . net, "Dudley Henriques" wrote: I've been back channeling for two days now with friends who are ex-Thunderbirds and professional pilots in other professions. Most of us are puzzled by the report although not at all puzzled by the results of Stricklin's mistake! There's something about this report some of us don't quite get, and it concerns the zero set on the altimeters. The TB fly a zero set altimeter for a show. It's not only basic for low altitude acro work, but it's specified in the regulations for the Thunderbird mission and procedures. (the old regulation anyway. haven't seen the revised one yet) My guys however, were on the T38 team, and the TB regulation for practice might have been changed since then. However, none of us believe that Stricklin took off with the altimeter set for the elevation at Mountain Home, which is 2996 feet ASL. That leaves only one scenario; that the present Viper team must be using a MSL base at Nellis for practice because of the mountains at Indian Springs. If this is true, then we still can't figure out why Stricklin would reverse on the roof of his maneuver with a target altitude of 1600 feet which is basically what happened. It just doesn't make sense to us. If the team is using a MSL base at Nellis, and Stricklin was using that base in his mind when he reversed; the elevation at Nellis is 2000 feet. That would have put his reverse at 4500 feet for the Viper instead of the 1600 plus he used. 1600 is way low for the Viper even for a zero set altimeter reference It's very puzzling!!! Also, there's been a lot of talk about not being able to zero altimeters at some high elevation airports. This is puzzling also. The Kollsman range, which is also the basic baro range in the Viper's CADC which drives the Viper's altimeter in both ELECT and PNEU backup, is aprox 22.00 inches on the low side and 32.00 inches on the high side. (I had to check this out with some buddies of mine, as I'd forgotten the range in the Kollsman myself!! :-) This gives you, even figuring the 1 inch per thousand rule, an elevation reset capability to a zero reset before takeoff of 10, 000 feet. This basically allows a zero reset anywhere in the U.S. at least, allowing for a standard atmosphere. I don't think I'm missing anything here, but I might have.....getting older you know!! :-) I just can't remember a zero set being any problem for me during my tenure as a demonstration pilot. The Thunderbird's are locked up tighter than a drum right now, and answers from the present team are not easy to get; so the bottom line so far for us old timers trying to figure this out is that the team indeed does use a MSL reference at Nellis because of the mountains, but resets to a zero altimeter set before takeoff at the show site. If this is the case, it's understandable to me how Chris Stricklin could have made the mistake he did. I'll tell you up front. I can sympathize with Chris Stricklin, or anyone else for that matter who has to work low altitude acro this way. If there's one thing that will kill you doing low work it's non-standardization. If the Birds have to use a MSL calculation for their roof target altitudes at Nellis for a vertical plane maneuver because of the mountains, then revert to a zero set when doing a show; that in my opinion is bad news! It's only a matter of time when things like this catch up to you when doing low work in high performance airplanes. Chris Stricklin is a damn good pilot. He's also a damn lucky pilot! What happened to Stricklin has happened to a lot of very good pilots who do low work. If all this reporting is true, he was simply bitten by non standardization! I understand the situation's being looked at closely by the Air Force. That's one good thing anyway, although I don't see how they're going to change anything unless they can take the mountains at Nellis out of the Thunderbird equation. Frankly, the whole damn thing is puzzling to us; us being myself and a few ex-Thunderbirds. I know I'll probably pick up the straight scoop sooner or later through my grapevine, but for right now, this report, and putting it together for a clear picture of what happened to Stricklin is one large puzzle in progress. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
"Doug \"Woody\" and Erin Beal" wrote
It used to be standard procedure at a major U.S. Airline which shall go un-named (AA) to do just that on every approach. Pilots scoffed at it at first, and then swore by it after they'd done it a few times. QFE vs. QNH. That airline doesnąt do it any more. As I recall, the pilot flying had QNH and the pilot not flying set QFE. If it wasn't AA, then it was another one of the majors. I did some training of a supplemental aircarrier's flightcrews at the AA training center at DFW and seem to remember it that way. Bob Moore PanAm (retired) |
Robert Moore wrote in message .7...
"Doug \"Woody\" and Erin Beal" wrote It used to be standard procedure at a major U.S. Airline which shall go un-named (AA) to do just that on every approach. Pilots scoffed at it at first, and then swore by it after they'd done it a few times. QFE vs. QNH. That airline doesnąt do it any more. As I recall, the pilot flying had QNH and the pilot not flying set QFE. If it wasn't AA, then it was another one of the majors. I did some training of a supplemental aircarrier's flightcrews at the AA training center at DFW and seem to remember it that way. Bob Moore PanAm (retired) I believe this is the incident you are referring to: http://www.ntsb.gov/publictn/1996/aar9605.pdf |
On 1/28/04 4:54 PM, in article
, "Robert Moore" wrote: "Doug \"Woody\" and Erin Beal" wrote It used to be standard procedure at a major U.S. Airline which shall go un-named (AA) to do just that on every approach. Pilots scoffed at it at first, and then swore by it after they'd done it a few times. QFE vs. QNH. That airline doesnąt do it any more. As I recall, the pilot flying had QNH and the pilot not flying set QFE. If it wasn't AA, then it was another one of the majors. I did some training of a supplemental aircarrier's flightcrews at the AA training center at DFW and seem to remember it that way. Bob Moore PanAm (retired) Thanks for the details, Bob. A lot of the left-seaters I fly with talk about how great the procedure was, but I've never bothered to press for additional info. --Woody |
![]() "Doug "Woody" and Erin Beal" wrote in message ... Dudley, It used to be standard procedure at a major U.S. Airline which shall go un-named (AA) to do just that on every approach. Pilots scoffed at it at first, and then swore by it after they'd done it a few times. QFE vs. QNH. That airline doesnąt do it any more. --Woody Hi Woody; I've been breifed yesterday that the TB are indeed using an MSL setting for their shows and not the AGL as I had thought. As for the AA situation on approach; was this before radar altimeters? :-)) Dudley |
Thunderbirds and Altimeters | Dudley Henriques | Military Aviation | 17 | February 1st 04 06:00 PM |
