Why not use the F-22 to replace the F/A-18 and F-14?
Old February 28th 04, 06:11 PM
running with scissors
"Tarver Engineering" wrote in message ...
"John R Weiss" wrote in message
news:AFp%b.402349$I06.4378804@attbi_s01...
"Tarver Engineering" wrote...
What is "an unmapped part of the A-320's flight control system"
supposed
to mean?!?
Airbus hadn't programmed their A-320 to do what the operator commanded.
Hmmm... I suspect that when the pilot added go-around power, he commanded
airplane to provide maximum lift/minimum sink while the engines spooled
up.
In what wy do you believe that stalling the wing is within the flight
envelope?
how did it stall ?
  #213
Old February 28th 04, 06:20 PM
John Miller
running with scissors wrote:
every ****ing aircraft goes past the end of a runway. its called takeoff
Heh. The high-performance types often don't cross the far-end threshold
during takeoff. I remember one time 10,000 feet over Sherman field,
looking straight down at the midpoint...
John Miller
Email address: domain, n4vu.com; username, jsm
I have ways of making money that you know nothing of.
-John D. Rockefeller
  #214
Old February 28th 04, 07:54 PM
Kevin Brooks
"Doug "Woody" and Erin Beal" wrote in message
On 2/28/04 4:09 AM, in article
"Guy Alcala" wrote:
SNIP
The USMC's AV-8Bs did this to
very good effect in 1991, for instance.
Using a helicopter airfield with a 6,000 foot runway in very poor
repair,
about
half of which was usable. They also operated from poor condition
forward
airfields in Iraq this past year, with fuel, weapons and
sparesapparently
brought
in mostly by truck.
Guy
Guy, it's obvious you know how to build an airfield.
The AV-8B's worked from forward airfields because they could. It was a
way
to use the assets we already have in a way that reduced crowding at
existing
airfields and slightly reduced tanker requirements.
And improved the response time and sortie generation rates, just as a FARP
alows an attack helo to generate more sorties due to reduced transit time
back and forth to the unit operating location.
It was a "nice to have" not a requirement. The war would have gone just
fine had they been F-16's or F/A-18's operating from fixed runways or
aircraft carriers.
The groundpounder who wants responsive CAS available *immediately*
throughout an operation would differ with you as to whether having an asset
capable of hitting a FARP and returning quickly to station is just "nice to
have".
Which is why the V/STOL F-35 is unnecessary.
Logic fault. You are claiming that because it was allegedly not required in
this instance, it will never be required. Kind of hard to support that kind
of argument. Given a scenario like Afghanistan, where the CAS assets had to
transit great distances to and from the required area of operations, the
ability to get STOVL assets into the A/O early in the campaign could be a
big advantage, and reduces the load on the other assets (like those F-15E's
and F-16's transiting out of the Gulf area). If it is unnecessary, why is
the USAF now joining the STOVL bandwagon--merely to make nice with their
USMC brethren? I doubt that. Is STVL the way to go for all TACAIR? Of course
not. But eliminating it just reduces your own versatility, and that would
not be a wise move in the current environment of uncertainty (as regards
where/when/how we'll have to fight).
Brooks
--Woody
  #216
Old February 28th 04, 10:06 PM
Pooh Bear
khobar wrote:
Pooh Bear wrote in message
JL Grasso wrote:
On Fri, 27 Feb 2004 10:43:07 -0800, "Tarver Engineering"
The A-320 which crashed into the trees in France was performing a
fly-by demonstration, by a line pilot, not an Airbus test or demo
pilot. The profile was to fly by at 500 feet.
The pilot was making a scheduled revenue flight with passengers and
came up
with the low slow fly by all on his own.
Actually, it was a charter flight. And not to split hairs, but the
low/slow fly-by was discussed by airline officials and both captains in
a
prior briefing that day. The accident was officially caused by descent
below obstacle height combined with a delayed application of TOGA power
to
exit the fly-by.
The F.O. was also declared mentally ill for demurring from the above
'explanation'.
You are aware that the DFDR presented in court to substantiate the official
story was NOT the DFDR from the crashed aircraft, yes?
Certainly didn't look like the same one from the pictures I saw.
There is certainly something altogether 'odd' about this incident.
Graham
  #217
Old February 28th 04, 10:07 PM
Pooh Bear
came up
a
to
exit the fly-by.
'explanation'.
... based on Assiline's assertion which he based on the appearance of the
box. IIRC correctly, he said that the one that he saw shortly after the
crash had vertical stripes on the housing, whereas the one in court had
diagonal stripes.
Pretty conclusive, yes?
Yes actually. I've seen footage of the DFDR being recovered and no way is it the
same one presented in court.
Graham
  #218
Old February 28th 04, 10:08 PM
Pooh Bear
JL Grasso wrote:
On Sat, 28 Feb 2004 02:45:53 +0000, Pooh Bear
The pilot was making a scheduled revenue flight with passengers and came up
low/slow fly-by was discussed by airline officials and both captains in a
below obstacle height combined with a delayed application of TOGA power to
exit the fly-by.
'explanation'.
Cite?
Crikey ! I thought it was common knowledge ?
Graham
  #219
Old February 28th 04, 10:46 PM
Phil Miller
On Sat, 28 Feb 2004 17:40:35 -0500, JL Grasso
On Sat, 28 Feb 2004 22:07:53 +0000, Pooh Bear
came up
a
to
exit the fly-by.
'explanation'.
diagonal stripes.
Surely there are some good still images from this footage available,
right? Can you provide a cite, or is this more 'common knowledge'?
Jerry
Try this Jerry:
http://www.airdisaster.com/investiga...96/af296.shtml
Whether it proves anything or not I'll leave to the reader.
Phil
Pfft...english! Who needs that? I'm never going to England.
Homer J. Simpson
  #220
Old February 28th 04, 10:59 PM
Doug \Woody\ and Erin Beal
On 2/28/04 1:54 PM, in article , "Kevin
SNIP
have".
CAS is available immediately because it is capping nearby--not because it is
on some Harrier or STOVL F-35 that's on a mesh field getting fueled and
loaded. It is a function of proper planning, sufficient numbers of
aircraft, and a good DASC.
USMC brethren?
Precisely... With one important distinction they're more than likely hoping
to take their USMC brethren's place and to keep unit costs down by ensuring
that the STOVL version doesn't get axed.
Brooks
What I'm claiming is that STOVL is still risky technology that kills too
many pilots in peace time and offers too little benefit in war time for that
cost.
--Woody
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Naval Aviation 2 February 22nd 04 06:22 AM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 3rd 03 11:49 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
