"Guy Alcala" wrote...
When you come to a F-18 / F-35 STOVL loadout, there could be a LOT of F-18 tankers supporting 1+30 cycles for the F-35, or the cycle times will be reduced to 1+15 or less. Don't see why. The F-35B will have considerably more internal fuel than an F-18A-D with similar weight, a single engine and no need for 3-5,000 lb. of recovery fuel reserve. Marine profile mission radius (KPP) is 450nm from a 550' STO (590nm for the USAF F-35A mission profile; 600nm for the USN F-35C mission profile), with a VL bringback of .2 x 1k JDAMs and a pair of AIM-120s, plus reserve fuel. What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? What will the fuel burn be for a typical approach and vertical landing for the F-35? Why will there be a significantly lesser fuel reserve requirement? Will the bingo fuel requirement be less for a STOVL airplane than a CTOL airplane? The F/A-18 hasn't met fuel specs yet, to my knowledge. The A/B/C/D never met the original requirements, and the C/D specs were "adjusted" so much from the original requirements that it is almost impossible to make an apple-apple comparison. So far, I believe the combination of cost and performance requirements for the F-35 are hopelessly optimistic... |
"John R Weiss" wrote:
What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? What will the fuel burn be for a typical approach and vertical landing for the F-35? There is some scant info from RN 801 Squadron in their Falklands ops on INVINCIBLE. ISTR that Sharkey Ward insisted they use their fuel on CAP and not in the pattern, with some *really* low fuel loads at land-on, and not much burned during their approach and translation maneuver. Most 801 flights were 2 ship CAPs. Is there a USN "best practice" for fuel load at the trap ? Five minutes of fuel at a given SFC, or something like that ? ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
"John S. Shinal" wrote:
There is some scant info from RN 801 Squadron in their Falklands ops on INVINCIBLE. ISTR that Sharkey Ward insisted they use their fuel on CAP and not in the pattern, with some *really* low fuel loads at land-on, and not much burned during their approach and translation maneuver. Most 801 flights were 2 ship CAPs. Policies during actual wartime may differ significantly from "peacetime" practice. Actually saving the ships from incoming missiles tends to make a single airplane a reasonable trade... Is there a USN "best practice" for fuel load at the trap ? Five minutes of fuel at a given SFC, or something like that ? That has evolved through the years, based on experience, changing tactics, and risk-averse trends on the part of the upper echelons... In my 81-83 A-6 cruise on Midway, our daytime minimum was 3.5-4.0 (3500-4000 lb at landing), and 4.0-5.0 at night. By the time I got to Kitty Hawk in 87, it was 5.0-5.5 day and max trap (6.0-7.5, depending on airframe and loadout) at night. Nimitz 88-89 was essentially max trap all the time... I don't know what the current state of affairs is... Unless the ship is working "blue water" (no divert field available), min landing fuel is usually the fuel required for divert. In "blue water" ops, numbers similar to those I cited above come into play. Generally, 2 looks at the ball (maybe 3 at night) plus min landing fuel for the airplane (e.g., 2.0 for the A-6). |
On 3/4/04 10:26, in article yMI1c.178613$uV3.756299@attbi_s51, "John R
Weiss" wrote: "John S. Shinal" wrote: There is some scant info from RN 801 Squadron in their Falklands ops on INVINCIBLE. ISTR that Sharkey Ward insisted they use their fuel on CAP and not in the pattern, with some *really* low fuel loads at land-on, and not much burned during their approach and translation maneuver. Most 801 flights were 2 ship CAPs. Policies during actual wartime may differ significantly from "peacetime" practice. Actually saving the ships from incoming missiles tends to make a single airplane a reasonable trade... Weapons bring back typically influences these policy decisions. Is there a USN "best practice" for fuel load at the trap ? Five minutes of fuel at a given SFC, or something like that ? That has evolved through the years, based on experience, changing tactics, and risk-averse trends on the part of the upper echelons... SNIP Case I "charlie" (day/VMC) is tank plus three passes (2.5 +.4 + .4 + .4) or 3.7. Case II/III (night/IMC) "charlie" is night tank plus two passes (3.0 + .8 + ..8) or 4.6. All this is from memory (i.e. I know the numbers [3.7/4.6] are correct, but the calculation method may be slightly off without refreshing my knowledge). Other carrier guys feel free to jump in and correct me. --Woody |
John R Weiss wrote:
"Guy Alcala" wrote... When you come to a F-18 / F-35 STOVL loadout, there could be a LOT of F-18 tankers supporting 1+30 cycles for the F-35, or the cycle times will be reduced to 1+15 or less. Don't see why. The F-35B will have considerably more internal fuel than an F-18A-D with similar weight, a single engine and no need for 3-5,000 lb. of recovery fuel reserve. Marine profile mission radius (KPP) is 450nm from a 550' STO (590nm for the USAF F-35A mission profile; 600nm for the USN F-35C mission profile), with a VL bringback of .2 x 1k JDAMs and a pair of AIM-120s, plus reserve fuel. What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? Actual thrust numbers, SFC, BPR, pressure ratio etc. are all still unavailable for the F135 and 136; basic layout (turbine and compressor stages) is about all that you can find. P&W & GE both just say "40,000 lb. thrust class." I've seen somewhere (but can't find it) that Rolls-Royce mentioned ca. 34,000 lb. dry, 56,000 lb. wet for the F136, but that may include the lift fan. The F136 is based on the F120 design, and IIRR that engine was variable-cycle. The use of the lift fan eliminates the Harrier problem of needing a very high bpr to generate sufficient lift for VTOL, screwing the SFC in throttled back cruise or at high CAS. As to the F-18A-D, off the top of my head F404-400s were rated at about 10,800 lb. mil (or maybe that was the internal fuel), 16,000 lb. A/B, with the -402 boosted to 17,600 lb. max. A/B. What will the fuel burn be for a typical approach and vertical landing for the F-35? Considering how low it was for the Harrier, with the F-35B being easier to control, it should be minimal. Harrier transition and landing takes a minute (or two at the outside), with max. fuel burn (wet) of 220 lb./minute for the -406, and presumably a bit more for the -408. The F-35B probably has between 50 and 100% more power in the hover, with a newer engine design and using an optimized lift fan plus a less-optimized core engine, so you can make your own estimates. Why will there be a significantly lesser fuel reserve requirement? Because there's no little need for multiple looks at the deck -- no bolters, no fouled decks. Enough fuel for one go-around seems to be about the max required, at least in wartime. Peacetime requirements will undoubtedly be greater, but still considerably less. Will the bingo fuel requirement be less for a STOVL airplane than a CTOL airplane? Are you referring to bingo fuel to the beach, or mission bingo? You have little need for the former. In Sherman Baldwin's book "Ironclaw," he describes the Midway trying to get a single F-18 back on board at night just prior to DS, while they were running at 30 knots or so, directly towards Iranian territorial waters. IIRR they tanked the guy a couple of times, and spent an hour getting him aboard. Just about the time they were going to have to bingo him because they had to change course to stay out of Iranian waters, they got him aboard. None of that would have been necessary if he'd been flying a STOVL a/c. The Midway could have been cruising along at any speed above steerage way, and he would have recovered on the first pass. For mission bingo, it has been less for Harriers. As John Shinal alluded to, during the Falklands war, the CO of 801 Squadron told his pilots that if they landed back on board with more than 800 lb. of fuel from a CAP mission, he'd "put his boot up their arse." Average fuel at land on seems to have been under that, in the 600 lb. range, with several landings with 400 lb., and in at least one case, when the visibility was perhaps 50 feet in fog and the pilot in question made one missed approach and then had the carrier shine a spotlight straight up, descending vertically next to it and landing on without ever seeing the deck or the island (or they him), 200 lb. Flight ops had already been shut down prior to his recovery. Over Bosnia, USN F-18s were originally operating with 5,000 lb. landing reserves, subsequently cut to 3,500 lb. to increase weapons bringback. Even being really generous, it's hard to see why an F-35B would need more than 2,000 lb. landing reserve. Night landings, even Case III, just aren't the same white-knuckle affair that they are when you have to trap. The F/A-18 hasn't met fuel specs yet, to my knowledge. The A/B/C/D never met the original requirements, and the C/D specs were "adjusted" so much from the original requirements that it is almost impossible to make an apple-apple comparison. The F-18E/F supposedly meets the original F-18A spec. The threshold radius for the F-35B is greater than that. So far, I believe the combination of cost and performance requirements for the F-35 are hopelessly optimistic... Aren't they all? But they are paying a lot more attention to cost ceilings on the program than they've done in the past; that is indeed one of the prime drivers. We'll just have to see how the performance falls out. Guy |
![]() "Guy Alcala" wrote in message . .. John R Weiss wrote: "Guy Alcala" wrote... When you come to a F-18 / F-35 STOVL loadout, there could be a LOT of F-18 tankers supporting 1+30 cycles for the F-35, or the cycle times will be reduced to 1+15 or less. Don't see why. The F-35B will have considerably more internal fuel than an F-18A-D with similar weight, a single engine and no need for 3-5,000 lb. of recovery fuel reserve. Marine profile mission radius (KPP) is 450nm from a 550' STO (590nm for the USAF F-35A mission profile; 600nm for the USN F-35C mission profile), with a VL bringback of .2 x 1k JDAMs and a pair of AIM-120s, plus reserve fuel. What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? Fuel burn for F35 in landing configuration is said to be close to double that of the AV-8. Actual thrust numbers, SFC, BPR, pressure ratio etc. are all still unavailable for the F135 and 136; basic layout (turbine and compressor stages) is about all that you can find. P&W & GE both just say "40,000 lb. thrust class." I've seen somewhere (but can't find it) that Rolls-Royce mentioned ca. 34,000 lb. dry, 56,000 lb. wet for the F136, but that may include the lift fan. The F136 is based on the F120 design, and IIRR that engine was variable-cycle. The use of the lift fan eliminates the Harrier problem of needing a very high bpr to generate sufficient lift for VTOL, screwing the SFC in throttled back cruise or at high CAS. As to the F-18A-D, off the top of my head F404-400s were rated at about 10,800 lb. mil (or maybe that was the internal fuel), 16,000 lb. A/B, with the -402 boosted to 17,600 lb. max. A/B. What will the fuel burn be for a typical approach and vertical landing for the F-35? Considering how low it was for the Harrier, with the F-35B being easier to control, it should be minimal. Harrier transition and landing takes a minute (or two at the outside), with max. fuel burn (wet) of 220 lb./minute for the -406, and presumably a bit more for the -408. The F-35B probably has between 50 and 100% more power in the hover, with a newer engine design and using an optimized lift fan plus a less-optimized core engine, so you can make your own estimates. Why will there be a significantly lesser fuel reserve requirement? Boarding rates are very high -- Unless somebody takes their own waveoff, "foul deck" usually means the jet is held in the hover abeam the intended landing spot until the spot is cleared. Because there's no little need for multiple looks at the deck -- no bolters, no fouled decks. Enough fuel for one go-around seems to be about the max required, at least in wartime. Peacetime requirements will undoubtedly be greater, but still considerably less. Will the bingo fuel requirement be less for a STOVL airplane than a CTOL airplane? Are you referring to bingo fuel to the beach, or mission bingo? You have little need for the former. In Sherman Baldwin's book "Ironclaw," he describes the Midway trying to get a single F-18 back on board at night just prior to DS, while they were running at 30 knots or so, directly towards Iranian territorial waters. IIRR they tanked the guy a couple of times, and spent an hour getting him aboard. Just about the time they were going to have to bingo him because they had to change course to stay out of Iranian waters, they got him aboard. None of that would have been necessary if he'd been flying a STOVL a/c. The Midway could have been cruising along at any speed above steerage way, and he would have recovered on the first pass. For mission bingo, it has been less for Harriers. As John Shinal alluded to, during the Falklands war, the CO of 801 Squadron told his pilots that if they landed back on board with more than 800 lb. of fuel from a CAP mission, he'd "put his boot up their arse." Average fuel at land on seems to have been under that, in the 600 lb. range, with several landings with 400 lb., and in at least one case, when the visibility was perhaps 50 feet in fog and the pilot in question made one missed approach and then had the carrier shine a spotlight straight up, descending vertically next to it and landing on without ever seeing the deck or the island (or they him), 200 lb. Flight ops had already been shut down prior to his recovery. Over Bosnia, USN F-18s were originally operating with 5,000 lb. landing reserves, subsequently cut to 3,500 lb. to increase weapons bringback. Even being really generous, it's hard to see why an F-35B would need more than 2,000 lb. landing reserve. Night landings, even Case III, just aren't the same white-knuckle affair that they are when you have to trap. I disagree with that last sentence Guy. Because Harriers use NVGs for shipboard takeoffs and landings, STOVL Night Case I is dramatically easier -- when conditions are conducive to NVG ops. Night Case III around any ship is a white knuckler regardless of what you're flying. It is no different in the AV-8 -- in addition to all that wonderful glideslope and course control, you get to manually control a progressive deceleration to a hover. It is THE most difficult thing to do in the Harrier -- bar nothing. The F35 should change that due to automated systems that shift some of the cockpit tasking to the machine. The F/A-18 hasn't met fuel specs yet, to my knowledge. The A/B/C/D never met the original requirements, and the C/D specs were "adjusted" so much from the original requirements that it is almost impossible to make an apple-apple comparison. The F-18E/F supposedly meets the original F-18A spec. The threshold radius for the F-35B is greater than that. So far, I believe the combination of cost and performance requirements for the F-35 are hopelessly optimistic... Aren't they all? But they are paying a lot more attention to cost ceilings on the program than they've done in the past; that is indeed one of the prime drivers. We'll just have to see how the performance falls out. Guy |
Frijoles wrote:
"Guy Alcala" wrote in message . .. John R Weiss wrote: What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? Fuel burn for F35 in landing configuration is said to be close to double that of the AV-8. About what I expected, given the difference in thrust and a/c weight. Internal fuel is roughly double as well. snip Over Bosnia, USN F-18s were originally operating with 5,000 lb. landing reserves, subsequently cut to 3,500 lb. to increase weapons bringback. Even being really generous, it's hard to see why an F-35B would need more than 2,000 lb. landing reserve. Night landings, even Case III, just aren't the same white-knuckle affair that they are when you have to trap. I disagree with that last sentence Guy. Because Harriers use NVGs for shipboard takeoffs and landings, STOVL Night Case I is dramatically easier -- when conditions are conducive to NVG ops. I take it the Marines finally cleared them for use in takeoffs and landings? ISTR reading that the Marines were prohibited from using NVGs during takeoff/landing initially, owing to the need to remove them in a hurry if an ejection was required (due to the moment arm on the head). IIRR the Brits got around this by designing some contraption that yanked the NVGs off the helmet when the ejection sequence started, while the USMC were limited (at the time) to unclipping them manually and tossing them on the floor out of the way. Did the USMC buy the same/similar device as the RAF? Night Case III around any ship is a white knuckler regardless of what you're flying. Poor choice of words on my part. I agree that it still can be tense, but the nagging worry that "I might not be able to get back on board at all" doesn't seem to be there, from the pilot accounts I've read. If they can see the ship, pilot attitude seems to be that they will land on (possibly with some damage, but it beats taking a swim in the dark). It is no different in the AV-8 -- in addition to all that wonderful glideslope and course control, you get to manually control a progressive deceleration to a hover. It is THE most difficult thing to do in the Harrier -- bar nothing. Along that line, here's an account of a Case III night landing during Exercise Alloy Express off Norway in January 1982, by Sharkey Ward, CO of 801 Sq. during the Falklands (and prior to that Sea Harrier project officer in the MoD, and then CO of the IFTU squadron and the HQ squadron), from his book "Sea Harrier over the Falklands": "[He'd been asked by the Air Boss to fly in conditions that had long since caused the Nimitz to shut down flight ops, early in the SHAR's career while the operational limits were still being expanded] . . . 'The problem, Sir,' heavy emphasis on the 'Sir' even though Dusty and I were on first-name terms when off duty, 'is as follows: the deck is pitching 7 degrees and our theoretical Boscombe Down limit is 2 degrees; the ship is rolling like a pig; she is heaving up and down about 30 feet; the cloud base is reported to be 200 feet but looks worse to me; tops are reported to be in excess of 38,000 feet with no gaps; and last but not least we are talking about night flying! We have never operated before with such a combination of out of limit factors, and I don't wish to push our luck without good reason.' There would be no 'enemy' aircraft launching from shore to attack the fleet that night (the land-based RAF team who were playing at being 'orange forces' or Russians would never dream of taking off in such weather just to play with the navy) - so why bash your head against a brick wall if you don't need to. Night flying was fine when there was something to do. But sitting in a cramped cockpit on your tod, looking at a set of flight instruments and a blank radar screen for an hour and a half in thick clag with no one to play with, seemed pointless' . . . . "As Dusty -- or 'Wings', as all Commanders (Air) are habitually known, continued to insist on 801 Squadron flying in spite of the conditions, I gave in ungracefully and agreed that I and only I would fly. It was definitely too dicey for some of the more junior pilots, and although Ian Mortimer could easily handle it, one jet airborne on such a ****ty night was less risky than two. . . .. [skip takeoff and cruise] "I returned an hour and a half later to carry out the land-on in atrocious conditions. There was no horizon at all. The rain on the windscreen caused a distracting deformation of the ship's usually welcoming lights, and I could feel the heavy buffeting from the gale force winds. Invincible was rolling, weaving, pitching and heaving and, as she was my only source of visual reference, this made the land-on task more onerous. At least it was a bit of a challenge and added spice to what had otherwise been a totally boring flight! Swearing under my breath at Wings and the world, I stabilised the aircraft over the deck amidships as best I could. The superstructure of the ship's island was only a matter of feet to the right and, as the ship rolled heavily to port, the huge wall of grey metal seemed to approach ominously close to the wing tip. Maintaining a steady hover was more like flying in formation on an unwilling leader, so eventually I took pot luck, selected a firm rate of descent and waited for the heavier than usual touchdown as the deck came up to meet me. A jarring thud and I was there." And here's what would be a waveoff and into the drink from fuel exhaustion (if no tanker was available) in a CTOL a/c, same source: "It was a lovely night but black as the ace of spades, with no horizon. Although I had plenty of fuel to allow for a second approach, my weight on this first approach was marginal . . . . [Note, they were just past Ascension Island on their way south to the Falklands, and it was very hot. On his first approach the a/c wouldn't maintain height in the hover despite full throttle and water injection, so he went around and made a second approach] My fuel was fine, but not really enough to take it round a further time. I turned in towards the glide slope from downwind and was in good voice contact with the Air Direction Officer, Tony Walker. On my first approach I had switched off my radar when close to the ship and was now relying on ranges to go to the deck being given by my controller. My Number Two that night was Alan Curtis, and I could see his aircraft coming down behind a third aircraft. I suggested feeding in behind Alan. "As can very easily happen, a slight misunderstanding then occurred. In the ship, Tony assumed, with good reason, that I had elected to feed myself in visually for approach and touchdown. In the air, I was of the same mind but was expecting some ranges to go to be passed to me (judging the distance to a deck by night is not easy when the deck lights are the only references you have . . . Tony must have presumed that my radar was still on line and so he switched frequency to talk to the next a/c coming down the slope. This left me on the same frequency as Alan, who was now approaching the hover ahead of me. Robin Kent was in Flyco talking Alan down, so I couldn't get a word in edgewise. "Not having a clue how far it was to the ship, I did realise that I was high on the prescribed glideslope, adjusted for that, and felt a little uneasy. Suddenly I realized that I could see the spray being kicked up from the surface by Alan's jet, and I then knew I was too close and too fast. I was still doing 130 knots with 60 deg. of nozzle and, as Alan's a/c suddenly loomed large before me I had to take evasive and corrective action. I jinked left to miss Alan's jet and slammed the nozzles to the full braking stop position. My fuel state was about 700 lb. -- not enough to go round again if there were any more ****-ups! "I cruised on past the ship decelerating as I went and ended up in the hover very wide and very high and with no visual references at all. It was a black night with no horizon, the ship was back over my right shoulder and the velocity vector symbol in my HUD had disappeared from view. I was completely in limbo, not knowing whether I was going up or down, fighting harder than ever before to control the a/c and expecting to crash at any moment. For what seemed about 30 seconds I was in serious trouble and on the point of ejecting from the a/c. But then the ship cottoned on to the fact that something was wrong and took action. "Brian Prendergast acted before speaking. He switched on the flight-deck floodlighting, then called 'You're high!' At last I could see the ship and gain some perspective. Robin Kent then transmitted: 'You are very high.' In the a/c I immediately felt more comfortable. I kept my eyes on the floodlit deck by craning my head around to the right and throttled back to bring the jet down to a realistic hover height. Now I had to get back to the deck from my position ahead of the ship, and used a little braking stop nozzle to start me moving backards. Nothing seemed to happen. I was making no progress and fuel was running low. I selected full braking stop and, as I started to move backwards alongside the ship, I suddenly got heavy rudder tramping. The rudder peddles were trying to thrash left and right against my feet. That meant I was doing about 40 knots backwards! It was a most unnerving experience and I couldn't really understand what was going on. Soon, however, I was in a position to return the nozzles to the hover stop, stabilize alongside and carry out a normal deck landing. I then found out that there was a wind over deck of more than 10 knots from the stern. No one had passed this critical information to me, which is why I had found it so difficult reversing to the correct hover position. "After a safe touchdown and whilst still in the cockpit, unstrapping, I was cursing Wings and the world in general. I was definitely going to have someone's guts for garters, blah, blah, blah! But by the time I had cooled off walking down the flight-deck my sense of humour had returned. I said nothing to Wings beyond pleasantries, amd told Tony that none of it was his fault. Then I went down to the bar, where the ever-present and understanding Senior Pilot [Squadron XO in the USN. Robin Kent] listened to my story over a couple of pints." Note, the SHAR pilots didn't have NVGs at the time, and by all accounts I've read the first gen. Harriers were much more of a handfull in the hover and transition than the second generation Harrier IIs. The F35 should change that due to automated systems that shift some of the cockpit tasking to the machine. I expect that will be the case. I assume they plan to use the FLIR for approach and landing? Guy |
![]() "Guy Alcala" wrote in message . .. Frijoles wrote: "Guy Alcala" wrote in message . .. John R Weiss wrote: What are the comparative thrust and specific fuel consumptions of the 2 airplanes' powerplants? Fuel burn for F35 in landing configuration is said to be close to double that of the AV-8. About what I expected, given the difference in thrust and a/c weight. Internal fuel is roughly double as well. snip Over Bosnia, USN F-18s were originally operating with 5,000 lb. landing reserves, subsequently cut to 3,500 lb. to increase weapons bringback. Even being really generous, it's hard to see why an F-35B would need more than 2,000 lb. landing reserve. Night landings, even Case III, just aren't the same white-knuckle affair that they are when you have to trap. I disagree with that last sentence Guy. Because Harriers use NVGs for shipboard takeoffs and landings, STOVL Night Case I is dramatically easier -- when conditions are conducive to NVG ops. I take it the Marines finally cleared them for use in takeoffs and landings? Around the ship, since late 1998. Forgot when they became routine for shore ops. ISTR reading that the Marines were prohibited from using NVGs during takeoff/landing initially, owing to the need to remove them in a hurry if an ejection was required (due to the moment arm on the head). IIRR the Brits got around this by designing some contraption that yanked the NVGs off the helmet when the ejection sequence started, while the USMC were limited (at the time) to unclipping them manually and tossing them on the floor out of the way. Did the USMC buy the same/similar device as the RAF? No, they did not buy those devices, nor anything similar. Night Case III around any ship is a white knuckler regardless of what you're flying. Poor choice of words on my part. I agree that it still can be tense, but the nagging worry that "I might not be able to get back on board at all" doesn't seem to be there, from the pilot accounts I've read. If they can see the ship, pilot attitude seems to be that they will land on (possibly with some damage, but it beats taking a swim in the dark). That may be a matter of opinion. If you can get to the hover abeam the ship, you're golden. Getting to that hover is the trick -- i.e.managing the transition from wing-borne to engine-borne flight over water at night in IMC or in VMC with no peripheral cues is a handful for even the most experienced players. It is no different in the AV-8 -- in addition to all that wonderful glideslope and course control, you get to manually control a progressive deceleration to a hover. It is THE most difficult thing to do in the Harrier -- bar nothing. Along that line, here's an account of a Case III night landing during Exercise Alloy Express off Norway in January 1982, by Sharkey Ward, CO of 801 Sq. during the Falklands (and prior to that Sea Harrier project officer in the MoD, and then CO of the IFTU squadron and the HQ squadron), from his book "Sea Harrier over the Falklands": "[He'd been asked by the Air Boss to fly in conditions that had long since caused the Nimitz to shut down flight ops, early in the SHAR's career while the operational limits were still being expanded] . . . 'The problem, Sir,' heavy emphasis on the 'Sir' even though Dusty and I were on first-name terms when off duty, 'is as follows: the deck is pitching 7 degrees and our theoretical Boscombe Down limit is 2 degrees; the ship is rolling like a pig; she is heaving up and down about 30 feet; the cloud base is reported to be 200 feet but looks worse to me; tops are reported to be in excess of 38,000 feet with no gaps; and last but not least we are talking about night flying! We have never operated before with such a combination of out of limit factors, and I don't wish to push our luck without good reason.' There would be no 'enemy' aircraft launching from shore to attack the fleet that night (the land-based RAF team who were playing at being 'orange forces' or Russians would never dream of taking off in such weather just to play with the navy) - so why bash your head against a brick wall if you don't need to. Night flying was fine when there was something to do. But sitting in a cramped cockpit on your tod, looking at a set of flight instruments and a blank radar screen for an hour and a half in thick clag with no one to play with, seemed pointless' . . . . "As Dusty -- or 'Wings', as all Commanders (Air) are habitually known, continued to insist on 801 Squadron flying in spite of the conditions, I gave in ungracefully and agreed that I and only I would fly. It was definitely too dicey for some of the more junior pilots, and although Ian Mortimer could easily handle it, one jet airborne on such a ****ty night was less risky than two. . . . [skip takeoff and cruise] "I returned an hour and a half later to carry out the land-on in atrocious conditions. There was no horizon at all. The rain on the windscreen caused a distracting deformation of the ship's usually welcoming lights, and I could feel the heavy buffeting from the gale force winds. Invincible was rolling, weaving, pitching and heaving and, as she was my only source of visual reference, this made the land-on task more onerous. At least it was a bit of a challenge and added spice to what had otherwise been a totally boring flight! Swearing under my breath at Wings and the world, I stabilised the aircraft over the deck amidships as best I could. The superstructure of the ship's island was only a matter of feet to the right and, as the ship rolled heavily to port, the huge wall of grey metal seemed to approach ominously close to the wing tip. Maintaining a steady hover was more like flying in formation on an unwilling leader, so eventually I took pot luck, selected a firm rate of descent and waited for the heavier than usual touchdown as the deck came up to meet me. A jarring thud and I was there." And here's what would be a waveoff and into the drink from fuel exhaustion (if no tanker was available) in a CTOL a/c, same source: "It was a lovely night but black as the ace of spades, with no horizon. Although I had plenty of fuel to allow for a second approach, my weight on this first approach was marginal . . . . [Note, they were just past Ascension Island on their way south to the Falklands, and it was very hot. On his first approach the a/c wouldn't maintain height in the hover despite full throttle and water injection, so he went around and made a second approach] My fuel was fine, but not really enough to take it round a further time. I turned in towards the glide slope from downwind and was in good voice contact with the Air Direction Officer, Tony Walker. On my first approach I had switched off my radar when close to the ship and was now relying on ranges to go to the deck being given by my controller. My Number Two that night was Alan Curtis, and I could see his aircraft coming down behind a third aircraft. I suggested feeding in behind Alan. "As can very easily happen, a slight misunderstanding then occurred. In the ship, Tony assumed, with good reason, that I had elected to feed myself in visually for approach and touchdown. In the air, I was of the same mind but was expecting some ranges to go to be passed to me (judging the distance to a deck by night is not easy when the deck lights are the only references you have .. . . Tony must have presumed that my radar was still on line and so he switched frequency to talk to the next a/c coming down the slope. This left me on the same frequency as Alan, who was now approaching the hover ahead of me. Robin Kent was in Flyco talking Alan down, so I couldn't get a word in edgewise. "Not having a clue how far it was to the ship, I did realise that I was high on the prescribed glideslope, adjusted for that, and felt a little uneasy. Suddenly I realized that I could see the spray being kicked up from the surface by Alan's jet, and I then knew I was too close and too fast. I was still doing 130 knots with 60 deg. of nozzle and, as Alan's a/c suddenly loomed large before me I had to take evasive and corrective action. I jinked left to miss Alan's jet and slammed the nozzles to the full braking stop position. My fuel state was about 700 lb. -- not enough to go round again if there were any more ****-ups! "I cruised on past the ship decelerating as I went and ended up in the hover very wide and very high and with no visual references at all. It was a black night with no horizon, the ship was back over my right shoulder and the velocity vector symbol in my HUD had disappeared from view. I was completely in limbo, not knowing whether I was going up or down, fighting harder than ever before to control the a/c and expecting to crash at any moment. For what seemed about 30 seconds I was in serious trouble and on the point of ejecting from the a/c. But then the ship cottoned on to the fact that something was wrong and took action. "Brian Prendergast acted before speaking. He switched on the flight-deck floodlighting, then called 'You're high!' At last I could see the ship and gain some perspective. Robin Kent then transmitted: 'You are very high.' In the a/c I immediately felt more comfortable. I kept my eyes on the floodlit deck by craning my head around to the right and throttled back to bring the jet down to a realistic hover height. Now I had to get back to the deck from my position ahead of the ship, and used a little braking stop nozzle to start me moving backards. Nothing seemed to happen. I was making no progress and fuel was running low. I selected full braking stop and, as I started to move backwards alongside the ship, I suddenly got heavy rudder tramping. The rudder peddles were trying to thrash left and right against my feet. That meant I was doing about 40 knots backwards! It was a most unnerving experience and I couldn't really understand what was going on. Soon, however, I was in a position to return the nozzles to the hover stop, stabilize alongside and carry out a normal deck landing. I then found out that there was a wind over deck of more than 10 knots from the stern. No one had passed this critical information to me, which is why I had found it so difficult reversing to the correct hover position. "After a safe touchdown and whilst still in the cockpit, unstrapping, I was cursing Wings and the world in general. I was definitely going to have someone's guts for garters, blah, blah, blah! But by the time I had cooled off walking down the flight-deck my sense of humour had returned. I said nothing to Wings beyond pleasantries, amd told Tony that none of it was his fault. Then I went down to the bar, where the ever-present and understanding Senior Pilot [Squadron XO in the USN. Robin Kent] listened to my story over a couple of pints." Note, the SHAR pilots didn't have NVGs at the time, and by all accounts I've read the first gen. Harriers were much more of a handfull in the hover and transition than the second generation Harrier IIs. IMO, the handling differences between the two jets are sometimes mischaracterized. Both aircraft are very honest. Workloads in the hover are very similar, except the first Harriers have neutral static stability in yaw below about 60kts -- a not-so-insignificant difference for transition flight. The first Harriers also have a much "lighter" control feel. Due to the stronger stability augmentation on the H II, it is slightly more forgiving of inattention to sideslip generation in transition flight, and protects the less experienced pilot as he (or she) ventures near the edges of the envelope. However, due to the different wing and its associated high-lift devices, at higher winds over the deck and while using the aft-most spots on the ship, you have to pay more attention to roll excursions. The F35 should change that due to automated systems that shift some of the cockpit tasking to the machine. I expect that will be the case. I assume they plan to use the FLIR for approach and landing? Don't know, but pilots usually find a way to use whatever works best. Guy |
Frijoles wrote:
"Guy Alcala" wrote in message . .. Frijoles wrote: snip Poor choice of words on my part. I agree that it still can be tense, but the nagging worry that "I might not be able to get back on board at all" doesn't seem to be there, from the pilot accounts I've read. If they can see the ship, pilot attitude seems to be that they will land on (possibly with some damage, but it beats taking a swim in the dark). That may be a matter of opinion. If you can get to the hover abeam the ship, you're golden. Getting to that hover is the trick -- i.e.managing the transition from wing-borne to engine-borne flight over water at night in IMC or in VMC with no peripheral cues is a handful for even the most experienced players. Okay, thanks for the clarification. snip accounts of two night landings Note, the SHAR pilots didn't have NVGs at the time, and by all accounts I've read the first gen. Harriers were much more of a handfull in the hover and transition than the second generation Harrier IIs. IMO, the handling differences between the two jets are sometimes mischaracterized. Both aircraft are very honest. Workloads in the hover are very similar, except the first Harriers have neutral static stability in yaw below about 60kts -- a not-so-insignificant difference for transition flight. The first Harriers also have a much "lighter" control feel. I've seen it described as being more of a sportscar feel vs. a sedan, i.e. more responsive, and some experienced pilots preferred it. Due to the stronger stability augmentation on the H II, it is slightly more forgiving of inattention to sideslip generation in transition flight, and protects the less experienced pilot as he (or she) ventures near the edges of the envelope. This would be the area where yaw-induced intake momentum drag rears its ugly head, especially in the first generation a/c? However, due to the different wing and its associated high-lift devices, at higher winds over the deck and while using the aft-most spots on the ship, you have to pay more attention to roll excursions. I suspect FBW will take care of that sort of thing in the F-35B. Of course, development to get the software to that point can be prolonged, as the MV-22 has been demonstrating. They seem to have gotten the uncommanded roll in the hover half over the deck and half not, and on the deck behind a helo, tamed at last. Any idea how the throttle logic is being implemented? AvLeak had an article a couple of years ago on the different approaches being pursued by Boeing and LockMart. IIRR one of them was planning for the throttle to control RoD directly in the hover, as opposed to controlling thrust directly. So, with the throttle in a hover position (with the computer providing whatever thrust is needed to achieve that), pulling the throttle back x amount would command say 3 fps RoD, y amount 5 fps, pushing it forward from neutral z amount would command 2 fps ascent, etc. ISTR the other company was planning to use it to control hover height, but my memory of the article is very hazy. Guy |
![]() Lotsa snip IMO, the handling differences between the two jets are sometimes mischaracterized. Both aircraft are very honest. Workloads in the hover are very similar, except the first Harriers have neutral static stability in yaw below about 60kts -- a not-so-insignificant difference for transition flight. The first Harriers also have a much "lighter" control feel. I've seen it described as being more of a sportscar feel vs. a sedan, i.e. more responsive, and some experienced pilots preferred it. I've not heard that characterization but its a good one. However, in spite of the heavier stick forces, in conventional flight the H II is generally a much more maneuverable aircraft. Due to the stronger stability augmentation on the H II, it is slightly more forgiving of inattention to sideslip generation in transition flight, and protects the less experienced pilot as he (or she) ventures near the edges of the envelope. This would be the area where yaw-induced intake momentum drag rears its ugly head, especially in the first generation a/c? Intake momentum drag is a factor, but usually pilot action (overly aggressive roll inputs) or inaction (don't center the vane) are usually the biggest contributors to sideslip issues. Biggest change for most jet guys is learning to use their feet for something other than brakes and nosewheel steering. Particularly important factor in the first jet since the static margin in yaw is less than the H II. However, due to the different wing and its associated high-lift devices, at higher winds over the deck and while using the aft-most spots on the ship, you have to pay more attention to roll excursions. I suspect FBW will take care of that sort of thing in the F-35B. Of course, development to get the software to that point can be prolonged, as the MV-22 has been demonstrating. They seem to have gotten the uncommanded roll in the hover half over the deck and half not, and on the deck behind a helo, tamed at last. Any idea how the throttle logic is being implemented? AvLeak had an article a couple of years ago on the different approaches being pursued by Boeing and LockMart. IIRR one of them was planning for the throttle to control RoD directly in the hover, as opposed to controlling thrust directly. So, with the throttle in a hover position (with the computer providing whatever thrust is needed to achieve that), pulling the throttle back x amount would command say 3 fps RoD, y amount 5 fps, pushing it forward from neutral z amount would command 2 fps ascent, etc. Not sure what LM uses. I thought the Boeing arrangement was TOO automated, but that was based on very limited exposure in the sim. I know both went through many iterations. ISTR the other company was planning to use it to control hover height, but my memory of the article is very hazy. Guy |
Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 07:58 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
