The demise of the Sea Harrier
Old April 24th 04, 10:47 AM
Guy Alcala
Prowlus wrote:
Guy Alcala wrote in message ...
Which is why, post Falklands, they bought Sea King AEW.2s (and now AEW.7s).
A Harrier GR.9 has equal low altitude capability as the SHAR FRS.1 -- the
latter's radar was unusable when looking down over land or rough sea and/or
at low level, the GR.9 lacks one. OTOH, if such a go-it-alone war such as
the Falklands were to happen, you can bet that the ASRAAM would be cleared
for GR.9 use in very little time.
Didn't they axe that idea of ASRAAMS on the GR.9 instead giving the
missles to the long suffering F.3 Tornados instead so that they could
use them as a way of "self defence" just incase they find themselves
caught up with real fighters whille performing their SEAD mission?
Yes they did. Now re-read the following:
They decided that the GR.9 will not now be equipped or cleared for ASRAAM, just like the GR.1/3 wasn't equipped or cleared
forAIM-9s until the Falklands, when it was re-wired and cleared for them inside of 2 weeks from the word go. It's amazing
how quickly you can accomplish something in wartime, given serious enough need. Do I think they will ever do this? Only if
Argentina is stupid again.
Guy
Old April 24th 04, 10:55 AM
Guy Alcala
Woody Beal wrote:
On 4/23/04 13:04, in article
et, "Frijoles"
Similarly configured, the STOVL JSF has better legs than the E/F Hornet --
the jet that will fill the lion's share of the duty on "conventional
carriers." It will also have a lower RCS, and similar or better weapons
system.
Does this mean we shouldn't have big deck CVs -- nope. It just means there
will be more platforms available to put tacair at sea.
Comparing apples to apples though, it will have less range than the A or C
models which can carry more payload and will be more capable. Better to
scrap the STOVL and buy more A's and C's instead--especially now that the
airframe is 2500-3000 lbs overweight.
How are you going to put an F-35A/C on an LHD? And how are the other countries
with navies who are planning to buy it (the Brits, Italians, etc.) going to put
an F-35A/C on their STOVL carriers? How are you going to operate F-35A/Cs from
FOLS/FARPS? The weight problems are clearly there now, but then that's par for
the course for just about every a/c; we'll have to see if they can pare it down.
There was a good article in AvLeak recently on what steps were being taken to
prune the weight. I forget all the details, but apparently one area where they
think they're going to be able to save a fair amount of weight is on the
(production vice development) engine, with the usual knock-on effects elsewhere.
Guy
Old April 24th 04, 11:35 AM
Frijoles
Nice try. Applying your rationale Woody, we should also ___can the Navy
variant. Just think about what kind of performance we could get from the
'C' without the weight penalties for cat and trap...
"Woody Beal" wrote in message
et, "Frijoles"
Hornet --
system.
there
--Woody
"Pechs1" wrote in message
Guy- So what the hell is left to call a FLEET AIR ARM????????
Joint Force Harrier, until the JSF enters service. And all the helos.
BRBR
When they got rid of the conventional CVs, they lost their true ability
at
sea
control. The JSF, altho whizbang, will not perform like a CV based
A/C...in
terms of legs, capability, etc..Like the aluminum surface ships that
got
beat
up in the Falklands, it looks good on paper, it is cheaper but it won't
do
complete job.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye
Phlyer
Old April 24th 04, 11:39 AM
Frijoles
What is "...more capable?"
et, "Frijoles"
Hornet --
system.
there
--Woody
BRBR
at
sea
A/C...in
got
beat
do
complete job.
P. C. Chisholm
CDR, USN(ret.)
Phlyer
Old April 24th 04, 12:44 PM
Thomas Schoene
Pechs1 wrote:
Like the
aluminum surface ships that got beat up in the Falklands, it looks
good on paper, it is cheaper but it won't do the complete job.
Pechs, I'd have thought you'd been around long enough to know better.
Please name one ship lost in the Falklands due to aluminum construction.
Can't be done, because there are none. The Type 42s (Sheffield, Coventry)
had steel construction. The Type 21s (Ardent, et al) had aluminum
superstructures but were lost to catastrophic damage -- 500- and 1000-lb
bombs detonating well inside the ship don't care much about construction
materials.
Tom Schoene Replace "invalid" with "net" to e-mail
"Our country, right or wrong. When right, to be kept right, when
wrong to be put right." - Senator Carl Schurz, 1872
Old April 24th 04, 01:15 PM
David Nicholls
It is of note that the weather conditions during the Falklands war were such
that it was (on occasions) outside the operating limits of launch/recovery
of fast jets on conventional CV's (re the previous 54,000 ton Ark Royal).
At no time did the Hermes and Invincible stop Sea Harrier ops.
David Nicholls
RN rtd.
BRBR
When they got rid of the conventional CVs, they lost their true ability at
sea
A/C...in
terms of legs, capability, etc..Like the aluminum surface ships that got
beat
up in the Falklands, it looks good on paper, it is cheaper but it won't do
complete job.
P. C. Chisholm
CDR, USN(ret.)
Phlyer
Old April 24th 04, 02:18 PM
Pechs1
icepack- Similarly configured, the STOVL JSF has better legs than the E/F
Hornet - BRBR
Yep, but not better than the CV based JSF...
The conventional CVs will not have a pack of STOVL JSFs onboard.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
  #28
Old April 24th 04, 02:20 PM
Pechs1
Woody- Better to
scrap the STOVL and buy more A's and C's instead- BRBR
Agree or build for export for those countries that can't afford a CV...and the
USMC, of course..
The cost of s CV ain't in the hull, but in the onboard systems. A small deck
CVEN that is capable costs almost the same as a big deck CVN, w/o the aircraft
capability of the CVN...
P. C. Chisholm
CDR, USN(ret.)
  #29
Old April 24th 04, 02:23 PM
Pechs1
Icepick- Nice try. Applying your rationale Woody, we should also ___can the
Navy
'C' without the weight penalties for cat and trap... BRBR
Nice tryx2..the weight and payload penalties for short takeoff/vertical landing
far outweigh those for a cat and trap.
P. C. Chisholm
CDR, USN(ret.)
Malaysian MiG-29s got trounced by RN Sea Harrier F/A2s in Exercise Flying Fish KDR Military Aviation 29 October 7th 03 06:30 PM
Malaysian MiG-29s got trounced by RN Sea Harrier F/A2s in Exercise Flying Fish KDR Naval Aviation 20 September 16th 03 09:01 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
Harrier thrust vectoring in air-to-air combat? Alexandre Le-Kouby Military Aviation 11 September 3rd 03 01:47 AM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 03:17 PM
