Mea Culpa! They are zinc not tin plated.
-- Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs or Always looking for articles for the Experimenter "Ron Natalie" wrote in message m... "Bob Olds" wrote in message m... I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum. \I think you'll find that they come in: Stainless steel Copper, tin plated copper, and zinc plated copper. and Aluminum. The stainless ones are not that commonly used by homebuilders. They require a lot of pressure to crimp and only used on stainless cables. Most people use the copper-alloy/plated ones as appropriate for the cable \ |
![]() "Cy Galley" wrote in message news:LhWGb.465476$Dw6.1374811@attbi_s02... Mea Culpa! They are zinc not tin plated. -- No you are right, for stainless cables they are tin plated. It's actually not the tin plating that makes the difference here. They use a different copper alloy in the tin plated version that's compatible with stainless (so says National Telephone, the owners of the Nicopress brand). |
On Thu, 25 Dec 2003 16:34:57 -0500, in rec.aviation.homebuilt you
wrote: "Drew Dalgleish" wrote in message ... At the local farm supply they're selling aluminum nico sleeves. Has anyone had any experience using these ? This is not surprising. The press type swaging for support/guy wires and wire fencing long before people thought about using them in airplanes and boats. I'd be careful that these are the ones designed for steel aircraft cable rather than fence wire before risking my life on them. The nicos were being sold beside the stainless and galvanized aircraft cable. I'm not planning on risking my life to them but using them on the check cables and drift cutters on the skis I'm building. Drew |
![]() "Ron Natalie" wrote in message m... "Cy Galley" wrote in message news:LhWGb.465476$Dw6.1374811@attbi_s02... Mea Culpa! They are zinc not tin plated. -- No you are right, for stainless cables they are tin plated. It's actually not the tin plating that makes the difference here. They use a different copper alloy in the tin plated version that's compatible with stainless (so says National Telephone, the owners of the Nicopress brand). My thanks to all for the informative discussion. I am fabricating restraint cables from the shoulder harness mounting back to the tailwheel. I had hoped to get the pieces at Home Depot Aircraft Supplies, but ran into the aluminum fittings. I'll wait until I can get to the Real Aircraft Store. Rich S. |
nicos | Drew Dalgleish | Home Built | 1 | December 25th 03 09:34 PM |
