Throttle movement
Old December 9th 04, 12:33 AM
Orval Fairbairn
Max Richter wrote:
Hallo,
i know that French;Italian and Japanese airplanes prior and in WW2 had
an opostite throttlemovement than British;American and German airplanes.
I mean that to increase power you had to pull the Throttle backwards and
not forward.
Now i asumed that after WW2 with the availability of surplus British and
American planes to the mentioned countrys this habit was not longer
followed.
Now i read that the French got T28 in the early sixties and modified
them to the COIN-configeration and the reversal of the
throttlequadrantmovement was one of the mentioned modifikations.
Now my question: have Mirages or Rafales or any other airplanes this
oddity also.
Or became it extinct in the world.
Thank You
Max
If not, it should have become extinct!
Old December 9th 04, 02:49 AM
Jake Donovan
I have a few hours in FENECs, the French T28 and unless they were modified
back to US configurations, the throttles where the same as the old B's and
C's I flew.
A Rafele I flew at Empire had a "normal" throttle configuration.
Just my observation of these 2 aircraft. I can not comment if either one
was modified previously.
Jake
"Orval Fairbairn" wrote in message
news
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Thank You
Max
Old December 11th 04, 09:37 PM
Orval Fairbairn
In article
Orval Fairbairn wrote:
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Thank You
Max
Upon reflection, I have flown a friend's EADS Epsilon, which has the
"proper" throttle movement (push for thrust), so it appears that even
the French can make some progress!
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Throttle friction lock slipping - How do I stop this? Ron Home Built 2 January 24th 04 12:55 AM
Shakespeare Throttle Friction Lock Larry Smith Home Built 3 November 8th 03 03:01 PM
Rotax 912 Full Throttle Springs Mark Callahan Home Built 0 July 5th 03 01:31 PM
