On Wed, 12 Jan 2005 01:34:34 GMT, Dave in San diego
postulated : You had to go and do it - bring up old painful memories. The ARC-27 was my second least favorite piece of tron gear to replace. The ARN-21 TACAN ranked first, primarily because of its generally more difficult location in the a/c. Can you believe they still had those boat anchors around into the 80s? I worked on FJ-3M, F9F, F11F, AD-6, and A4D. The A4D was the worst for me with that damned "biscuit" which housed it all. The ARC-27 was my bread and butter gear. Easy to diagnose problems. Using the bicycle pump always attracted the attention of the other shops. The only gear I never really understood was the APX-6 transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. |
transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. This cries out for further explanation. From context, I assume the idea was to prevent the bad guys from reverse engineering the IFF and figuring out a method to interrogate it. But was the self destruct mechanism *really* a live .45 calibre shell? |
Greasy Rider wrote in
: On Wed, 12 Jan 2005 01:34:34 GMT, Dave in San diego postulated : You had to go and do it - bring up old painful memories. The ARC-27 was my second least favorite piece of tron gear to replace. The ARN-21 TACAN ranked first, primarily because of its generally more difficult location in the a/c. Can you believe they still had those boat anchors around into the 80s? I worked on FJ-3M, F9F, F11F, AD-6, and A4D. The A4D was the worst for me with that damned "biscuit" which housed it all. The ARC-27 was my bread and butter gear. Easy to diagnose problems. Using the bicycle pump always attracted the attention of the other shops. The only gear I never really understood was the APX-6 transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. Oh, the APX-6 was actually one of the easiest pieces I got to work with. I saw it in "A" School, and briefly in the fleet before they transitioned to the APX-72. The 72 was another item requiring the bicycle pump. Speaking of that, when I was in Brunswick, we were having problems with the 27s in some visiting EA-3s. Would work OK on the ground, and on climb-out but would fail at altitude. When we went to AIMD and asked what pressure they were pumped up to, the techs replied, "We never pump them up, Stoofs don't go that high." Needless to say, after the **** flowed downhill, ALL gear requiring pressurization was properly serviced from then on. Dave in San Diego |
"STOOFs" were the S2Fs.
"Dave in San diego" wrote in message . .. Greasy Rider wrote in : On Wed, 12 Jan 2005 01:34:34 GMT, Dave in San diego postulated : You had to go and do it - bring up old painful memories. The ARC-27 was my second least favorite piece of tron gear to replace. The ARN-21 TACAN ranked first, primarily because of its generally more difficult location in the a/c. Can you believe they still had those boat anchors around into the 80s? I worked on FJ-3M, F9F, F11F, AD-6, and A4D. The A4D was the worst for me with that damned "biscuit" which housed it all. The ARC-27 was my bread and butter gear. Easy to diagnose problems. Using the bicycle pump always attracted the attention of the other shops. The only gear I never really understood was the APX-6 transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. Oh, the APX-6 was actually one of the easiest pieces I got to work with. I saw it in "A" School, and briefly in the fleet before they transitioned to the APX-72. The 72 was another item requiring the bicycle pump. Speaking of that, when I was in Brunswick, we were having problems with the 27s in some visiting EA-3s. Would work OK on the ground, and on climb-out but would fail at altitude. When we went to AIMD and asked what pressure they were pumped up to, the techs replied, "We never pump them up, Stoofs don't go that high." Needless to say, after the **** flowed downhill, ALL gear requiring pressurization was properly serviced from then on. Dave in San Diego |
housed it all. The ARC-27 was my bread and butter gear. Easy to diagnose problems. Using the bicycle pump always attracted the attention of the other shops. The only gear I never really understood was the APX-6 transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. Ah ha, the old ASQ-17. It was used on the A4D, F-8U, and believe the F-11. Leanne |
On Tue, 11 Jan 2005 23:19:46 -0500, "Leanne"
postulated : Ah ha, the old ASQ-17. It was used on the A4D, F-8U, and believe the F-11. I hated the damned thing so much I forgot the designation but then it's been almost 50 years and I'm entitled! |
Repaired many an ARC-27 @ Whiting Field in the '70s.
Tough radio. Jim |
Good ole' ARC-27 you could always tell where in the shop the ARC-27
bench was or had been. From all of the holes in the ceiling where the scribe ended up after forgetting to unkey the transmitter while tuning the final PA stages capacitor plates. B+ of 1500 volts'll do that to ya. Greasy Rider wrote: On Wed, 12 Jan 2005 01:34:34 GMT, Dave in San diego postulated : You had to go and do it - bring up old painful memories. The ARC-27 was my second least favorite piece of tron gear to replace. The ARN-21 TACAN ranked first, primarily because of its generally more difficult location in the a/c. Can you believe they still had those boat anchors around into the 80s? I worked on FJ-3M, F9F, F11F, AD-6, and A4D. The A4D was the worst for me with that damned "biscuit" which housed it all. The ARC-27 was my bread and butter gear. Easy to diagnose problems. Using the bicycle pump always attracted the attention of the other shops. The only gear I never really understood was the APX-6 transponder. I always kept a wary eye on that live round .45 shell aimed at the Top Secret cavitron. |
YUP! Had that happen many times. every once in a while - one of them would
loosen fall onto the bench. |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
