"W. D. Allen Sr." wrote:
Does anyone know anything about the C-130 that made arrested landings and launches from a Navy aircraft carrier back in the 1960s? WDA end What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. How about a scenario like this? C130 has a very heavy cargo load and minimal fuel. As soon as it takes off, it does an aerial refueling and flies to the carrier. I don't know the numbers but I imagine takeoff weight is lower than max airborne? Jay |
William Hughes wrote:
What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. I don't think it's been tried on a carrier, but the system you describe exists. It's called the Low Altitude Parachute Extraction System (LAPES). Problem is, it isn't accurate enough for a carrier. One or two hundred feet short or long, or a few degrees off-axis on land is no big deal, but on a carrier it's the difference between a successful delivery and a massive hole in the transom, a bunch of wrecked deckload aircraft, or a lost cargo. Wouldn't the flight deck be cleared of aircraft? The 1960s picture shows a cleared deck on Forrestal. How fast does the cargo slow down from the parachutes that pull it from the plane? What if a special surface was put on the bottom of the delivery containers to help it slow down quicker? Imagine big keds sneaker soles? :-) It's be easier to just rig the cargo for airdrop and splashdown, then retrieve it with the carrier's helos. This, of course, limits the cargo to the lifting capacity of the helo, which invalidates the entire reason for using a C-130 in the first place. Might as well just stick to the COD. Well wasn't the main reason for trying out the C130 more because of range limitations not payload? Also, if the C130 payload is not a couple of very large items too heavy for a helo but instead many smaller items that could be recovered in multiple helo lifts? Jay |
I got it how about a normally arrested landing... only the cargo is
attached to the hook. The 130 bolters the cargo stays on deck. Boy talk about a POWER DUMP. KenG JJ wrote: William Hughes wrote: What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. I don't think it's been tried on a carrier, but the system you describe exists. It's called the Low Altitude Parachute Extraction System (LAPES). Problem is, it isn't accurate enough for a carrier. One or two hundred feet short or long, or a few degrees off-axis on land is no big deal, but on a carrier it's the difference between a successful delivery and a massive hole in the transom, a bunch of wrecked deckload aircraft, or a lost cargo. Wouldn't the flight deck be cleared of aircraft? The 1960s picture shows a cleared deck on Forrestal. How fast does the cargo slow down from the parachutes that pull it from the plane? What if a special surface was put on the bottom of the delivery containers to help it slow down quicker? Imagine big keds sneaker soles? :-) It's be easier to just rig the cargo for airdrop and splashdown, then retrieve it with the carrier's helos. This, of course, limits the cargo to the lifting capacity of the helo, which invalidates the entire reason for using a C-130 in the first place. Might as well just stick to the COD. Well wasn't the main reason for trying out the C130 more because of range limitations not payload? Also, if the C130 payload is not a couple of very large items too heavy for a helo but instead many smaller items that could be recovered in multiple helo lifts? Jay |
![]() "JJ" wrote in message ... "W. D. Allen Sr." wrote: Does anyone know anything about the C-130 that made arrested landings and launches from a Navy aircraft carrier back in the 1960s? WDA end What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. Don't forget that besides the ten foot fall the dropped cargo is moving forward at the same speed as the C-130. You'll need a big net to catch it before it zooms off the end of the deck. The plane could stop because it could use its brakes and reverse thrust. How about a scenario like this? C130 has a very heavy cargo load and minimal fuel. As soon as it takes off, it does an aerial refueling and flies to the carrier. I don't know the numbers but I imagine takeoff weight is lower than max airborne? Jay |
"John Keeney" wrote in message
... | | "JJ" wrote in message | ... | "W. D. Allen Sr." wrote: | Does anyone know anything about the C-130 that made arrested landings and | launches from a Navy aircraft carrier back in the 1960s? | WDA | end | | What would happen if the C130 just flew in low to the deck and the | cargo was ejected out the back? Could most airdropped stuff take a 10 | foot freefall? How about 20 feet? How about the carrier deck? | Probably no dents right? I can imagine it "depends" on what is being | delivered. | | Don't forget that besides the ten foot fall the dropped cargo is | moving forward at the same speed as the C-130. You'll need a | big net to catch it before it zooms off the end of the deck. | The plane could stop because it could use its brakes and reverse | thrust. | | How about a scenario like this? | | C130 has a very heavy cargo load and minimal fuel. As soon as it | takes off, it does an aerial refueling and flies to the carrier. I | don't know the numbers but I imagine takeoff weight is lower than max | airborne? | | Jay | | In addition to all that, the damage done by the pallet to the non-skid surface would be extensive. I recall when Kitty Hawk visited Perth recently it received a $100K resurface, before heading out again. -- Cheers Dave Kearton |
"Dave Kearton" wrote:
In addition to all that, the damage done by the pallet to the non-skid surface would be extensive. What if there was a special material on the bottom of the pallet that not only helped cushion the landing, slow down the cargo and keep it from sliding around when coming to a stop but also wore or ablated to minimize wear or damage to anti-skid coatings. I recall when Kitty Hawk visited Perth recently it received a $100K resurface, before heading out again. I would imagine the downtime is a much bigger issue than $100k material/labor cost. Jay |
"John Keeney" wrote:
Don't forget that besides the ten foot fall the dropped cargo is moving forward at the same speed as the C-130. You'll need a big net to catch it before it zooms off the end of the deck. The plane could stop because it could use its brakes and reverse thrust. Yes, I had not fully considered this aspect - with higher altitude parachute drops the cargo loses most of the aircraft imparted forward velocity by the time it lands. I took a look at some LAPES links http://www.parachutehistory.com/military/lapes.html http://www.edwards.af.mil/moments/do.../94-05-03.html I wonder how slowly a laden C130 could fly yet still generate enough force from the parachutes to pull out the cargo and ensure predictable placement. How about a C17? Jay |
![]() "JJ" wrote in message ... "W. D. Allen Sr." wrote: Does anyone know anything about the C-130 that made arrested landings and launches from a Navy aircraft carrier back in the 1960s? WDA end What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. How would you pick up return cargo and passengers using such a technique? |
In message , Jeroen Wenting
writes "JJ" wrote in message ... "W. D. Allen Sr." wrote: Does anyone know anything about the C-130 that made arrested landings and launches from a Navy aircraft carrier back in the 1960s? WDA end What would happen if the C130 just flew in low to the deck and the cargo was ejected out the back? Could most airdropped stuff take a 10 foot freefall? How about 20 feet? How about the carrier deck? Probably no dents right? I can imagine it "depends" on what is being delivered. How would you pick up return cargo and passengers using such a technique? A modification of this technique might do it: http://tinyurl.com/3rnj5 Winding the cable in to recover the cargo would be interesting. I'm not sure if the term 'snatch pilot' would be one to use on the west side of the pond, though. -- Peter Ying tong iddle-i po! |
Navy reassigns squadron leader aboard carrier | Otis Willie | Naval Aviation | 6 | November 2nd 04 04:03 AM |
Four Navy avaitors on San Diego-based carrier listed as missing | Otis Willie | Naval Aviation | 0 | August 11th 04 05:03 AM |
Navy commander pilot passes 1,000th ‘trap’ aircraft carrier | Otis Willie | Naval Aviation | 0 | July 16th 04 12:25 AM |
Next Generation Aircraft Carrier Contract Awarded | Otis Willie | Naval Aviation | 6 | May 23rd 04 02:53 PM |
If there is a drive for a "Euro navy," will Germany build a carrier? | David E. Powell | Naval Aviation | 2 | March 6th 04 05:25 PM |
