"Ernesto Sanchez" wrote in message ...
"Scott Correa" wrote in message ... jerry lopez wrote: wondering if anyone has read the new sport pilot rules about experimental a/c that shows if it would be possible to govern a rv7 with a mazda wankel engine to get past the sport pilot rule under the experimental rules for sport pilot. Look at: http://www.rotaryaviation.com/ http://conversionconcepts.com/index.html http://eaa154.dhs.org/perry/other_13B/index.shtml http://home.earthlink.net/~rotaryeng/ACRE.html Jerry actually brings up a good point. Many of these homebuilt kits look inviting and affordable except that they cater to the sport pilot ruling. Getting answers from the companies on how to make them faster with better loads has been a struggle. No one wants to go past the magic numbers. They seem to be afraid that if you make it faster, and sell it, the next owner may not have the correct license to fly it. Every time I inquire about what it will take to have better preformance, the sales reps. stop at the sport pilot numbers. Either they all use the same engineer, or there afraid to answer the question. Lou |
![]() Lou, you missed the point of the original question. He wanted to stuff a detuned 12-A into an RV7 to make it fit the sport pilot regs. Why detune anything, it is a bad idea. You can comply with sport pilot regs for speed by simply placing the redline that corresponds with the max speed for the regs on the airspeed indicator. As an experimental a/p that is your decision to make. If you placard the airplane to comply with the rule, you are prevented from operating the airplane any faster even if you have GOBS of throttle available. If anyone asks, say you have flat rated the engine to allow for high altitude/ hot day operation. Done. But speed isn't the only number of concern, Stall speed must be below the max allowable in the regs also. That is probably tougher. Scott. |
![]() "Scott Correa" wrote in message ... Lou, you missed the point of the original question. He wanted to stuff a detuned 12-A into an RV7 to make it fit the sport pilot regs. Why detune anything, it is a bad idea. You can comply with sport pilot regs for speed by simply placing the redline that corresponds with the max speed for the regs on the airspeed indicator. As an experimental a/p that is your decision to make. If you placard the airplane to comply with the rule, you are prevented from operating the airplane any faster even if you have GOBS of throttle available. Don't bank on it. WOT is what they are after. Any restriction must not be easily over-ridden, especially from the cockpit. -- Jim in NC |
Are you saying that you have to unbolt and take the throttle stop out 'before' take off???? Where there's a will there's a way -----Big John On Thu, 1 Jan 2004 02:19:17 -0800, "Morgans" wrote: "Scott Correa" wrote in message ... Lou, you missed the point of the original question. He wanted to stuff a detuned 12-A into an RV7 to make it fit the sport pilot regs. Why detune anything, it is a bad idea. You can comply with sport pilot regs for speed by simply placing the redline that corresponds with the max speed for the regs on the airspeed indicator. As an experimental a/p that is your decision to make. If you placard the airplane to comply with the rule, you are prevented from operating the airplane any faster even if you have GOBS of throttle available. Don't bank on it. WOT is what they are after. Any restriction must not be easily over-ridden, especially from the cockpit. |
![]() "Big John" wrote in message ... Jim Are you saying that you have to unbolt and take the throttle stop out 'before' take off???? Where there's a will there's a way -----Big John "Zactly! Really, what will be enforced, and how it will be enforced, since we don't have the rule in hand to work at getting around! Or something like that? ,g -- Jim in NC |
dr
"Morgans" wrote in message ... "Big John" wrote in message ... Jim Are you saying that you have to unbolt and take the throttle stop out 'before' take off???? Where there's a will there's a way -----Big John "Zactly! Really, what will be enforced, and how it will be enforced, since we don't have the rule in hand to work at getting around! Or something like that? ,g |
Harley motor in a homebuilt? | David Hill | Home Built | 33 | September 25th 03 10:18 PM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
Sizing motor capacitors | Ron Finet | Home Built | 2 | September 5th 03 01:58 AM |
Single-rotor Mazda engines.... any flying our there? | Pete | Home Built | 1 | July 18th 03 01:50 PM |
Exhaust for VW motor | Andre | Home Built | 0 | July 14th 03 03:14 PM |
