Jim:
Tarver has no clue. You are correct. He just like to dance around the obvious. Bill A&P IA On Mon, 17 Nov 2003 08:28:17 -0600, "James M. Knox" wrote: "Tarver Engineering" wrote in news:5YCdnQMkPtw0dyqiRVn- : But it can be flown by the renter, or his pilot (including a flight instructor *the renter provides*, as long as it is in annual and otherwise airworthy. No 100 hour inspection is required. Nope, go read your own FAA opinion again. Okay... been there, done that. Care to try to be more specific? Note that I specifically referred to a flight instructor PROVIDED BY THE RENTER. Be very careful when you simply see a sentence about use of the aircraft "for hire or compenation, including flight instruction." If you look more carefully you will see that they are talking about the FBO providing both the plane and flight instructor. That indeed DOES require a 100 hour inspection. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Home Inspection Listings | Patrick Glenn | Home Built | 4 | April 26th 04 11:52 AM |
51st Fighter Wing betters rating to ‘excellent’ with inspection | Otis Willie | Military Aviation | 0 | February 20th 04 11:29 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
