Thanks Kyler! rsync worked perfectly.
Somehow the FAA forgot to send me the last batch of sectional DVDs and by the time I finally called about it they didn't have any remaining. I was told to wait for the next batch. It's here. This batch doesn't become effective until December 25, 2003, but because the previous batch has expired, I've changed the "current" link to point to the new batch. http://aviationtoolbox.org/raw_data/...onals/current/ I've gotten rid of the zip files. I didn't like having multiple versions of the data. I considered making a simple way to compress the files on the fly for HTTP transport, but I decided to try providing the files over a dedicated rsync server instead. So...if you're in a directory that has the last batch of sectionals and you want to update it, try something like this. rsync -Prvz --size-only rsync://aviationtoolbox.org/raw_data/FAA_sectionals/current/ . The "z" specifies compression and I found that it does a fairly good job with the TIFF files. If you trust me to get things right and you want to get rid of files that don't exist in the new batch you might want to use "--delete" also. Note that I have not yet created "chunks" using these new sectionals. I am still mulling over the most efficient way to do this. There are not a lot of new images, so I think I can make updates *much* quicker if I just re-crop and warp the new ones. I've also created a simple command line tool to generate an image of any region by stitching together the chunks. I want to make it available through HTTP and XML-RPC so I've switched to working on the Zope infrastructure for awhile. More on that soon. Enjoy. --kyler |
Giving thanks this Christmas, by Phill Coleman | Otis Willie | Naval Aviation | 0 | December 18th 04 05:52 AM |
Another Almost Annual Christmas Poem!!! | David Pincus | Home Built | 4 | December 28th 03 12:47 PM |
MERRY CHRISTMAS | JSH5176 | Military Aviation | 0 | December 13th 03 05:12 AM |
AVIATIONTOOLBOX: ConUS sectionals in under 2GB | Kyler Laird | General Aviation | 0 | December 5th 03 12:20 PM |
AVIATIONTOOLBOX: how I convert sectional maps to map chunks | Kyler Laird | General Aviation | 2 | December 4th 03 01:09 AM |
