This is a long-shot, but easy to try...
A "loose" connection. Maybe in the tray connector or headphone/speaker wiring or somewhere in the antenna coax run. New radio may may not be mating completely with tray connector. With engine off (and radio on of course), tune in a ATIS or AWOS or whatever you can find that is transmitting. Then, shake, pound, wiggle the tray, antenna, coax, all wiring (including headphone/speaker wiring). Sid Knox Velocity N199RS Starduster N666SK KR2 N24TC W7QJQ "Eugene Wendland" wrote in message ... I just installed a Michel TKM MX 11r which is a direct slide-in replacement for my Narco 120 Comm. Because I have an intercom, I had to add a resistor to the circuit board. Having done this, I installed the radio in the old Narco tray and tested the radio: Findings: 1/ Comm works great with just power on. 2/ With engine (lycoming O-320 with new mag leads) on at low r.p.m.s, the received audio has interference (very garbled). 3/ Once the r.p.m's increase to about 1500 and beyond, the recieved transmissions seem great. Because TKM is closed, I haven't called the tech rep about this, but could anyone tell me what's happening? Everything else about the Comm seems to be working well. My transmissions to the tower are 5 squared. My Narco didn't do this, so I'm assuming there's something wrong with the radio. Thanks Eugene Wendland |
Problem Solved!
I tried to isolate the problem by disconnecting the magneto p-leads, then the alternator. After disconnecting, I would fire up the engine to check the radio and it still would be very garbled at low engine r.p.m. and then clear itself up at higher r.p.m. While sitting in the cockpit, I noticed that my antenna, which is connected to my new TKM MX11 radio,was vibrating back and forth. As I increased R.P.M's, the antenna would stop vibrating and the garbled sound at low r.p.m. disappeared. My antenna is a stainless steel whip model that sits in front of the windshield on the cowling. See attached link to view: http://home.cogeco.ca/~pl2/p3.html I quickly switched to my other comm antenna and now have no problems. There's probably a ground fault at the antenna base - I haven't had a chance to sort it out. I don't know why this didn't manifest itself with the old Narco 120. BTW, the TKM MX-11 radio works great. As a slide in replacement, it's easier than removing the old tray and installing a new tray for a ICOM A200 or a Bendix/King KY76A. It should be noted however that, barring the antenna problem, the MX-11 needed some work before it would work. It seems that if you run your radio through an intercom, which I do, you have to add a capacitor to the radio's computer board, which I did. This took a little less that an hour, but after I did this the radio worked right away. However having said that, apparently, if you run the radio through an audio panel, you don't have to make this tiny modification. Strange. In my opinion, I still saved hours of grief with this installation versus a new tray, etc. Blue Skies Eugene Wendland |
Narco DME | zatatime | Aviation Marketplace | 1 | February 28th 05 12:07 PM |
Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | Aviation Marketplace | 0 | January 23rd 04 02:44 AM |
Narco 120 replacement/TKM 11x of ICOM A200 | Jerry Springer | Home Built | 0 | January 23rd 04 02:43 AM |
Magneto/comm interference on TKM MX-R Narco 120 replacement | Eugene Wendland | Home Built | 5 | January 13th 04 02:17 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
