Hi,
Recently I was in a 737-700 during my trip. I noticed that the landing speed was quite high. Anyone know what the normal landing speed is for this aircraft? Also, I noticed that there was another way to slow down the aircraft after touching down. Was it reverse thrust of the engines? I am confused because reverse thrust would cause engine overheating (that is, there would be no air flowing through the engine but pushed out by the reverse pitch of the blades). Louis |
Three ways to slow a jetliner, wheel brakes, reverse thrust, and
ground spoilers on top of the wing. The "blades" do not change pitch, the exhaust out the rear of the engine is turned around by deflectors. Bob Moore ATP B-727 B-707 Actually you forgot the fourth and fifth way... 4: Drag, 5: Obstacles. Capt. Dan L10-A-Lemon, Diesel-9 |
![]() Three ways to slow a jetliner, wheel brakes, reverse thrust, and ground spoilers on top of the wing. I'd always assumed the ground spoilers were to kill lift, thus making the brakes much more effective. Do they make a sizeable direct contribution as well? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote
I'd always assumed the ground spoilers were to kill lift, thus making the brakes much more effective. Do they make a sizeable direct contribution as well? Well... I've certainly been able to steer Boeing Jetliners even at taxi speeds by using the spoilers. Bob Moore |
thrust, and ground spoilers on top of the wing. Braking parachute Runway end catching net I wonder how Flight 1420 went off the runway end? Did they deploy the braking chute? |
![]() "louis" wrote in message om... Hi, Also, I noticed that there was another way to slow down the aircraft after touching down. Was it reverse thrust of the engines? I am confused because reverse thrust would cause engine overheating (that is, there would be no air flowing through the engine but pushed out by the reverse pitch of the blades). ROFL - this is a troll, right :-) Regards Andrew -- Inweb Networks. Quality internet and telecoms services Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk E1 call share. 0800, 0845 and 0870 numbers - best rates. Resellers welcome |
On 4 Mar 2004 07:34:35 -0800 louis
wrote in news:rec.aviation.misc Recently I was in a 737-700 during my trip. I noticed that the landing speed was quite high. Anyone know what the normal landing speed is for this aircraft? 110 - 150 knots air speed, depending on weight an flap setting. The ground speed may seem high with no wind. Also, I noticed that there was another way to slow down the aircraft after touching down. Was it reverse thrust of the engines? I am confused because reverse thrust would cause engine overheating (that is, there would be no air flowing through the engine but pushed out by the reverse pitch of the blades) The CFM56 core air flow is not affected during fan air flow deflection and reversal. Older models with JT8 engines reversed all the air using bucket deflectors, without overheating. Compressor and fan blade pitch can't be adjusted on jet engines, only stator blade angle of attack. -- _/_/_/ -=jh=- |
