Ahh, come on guys!
You go up to altitude and stall the airplane. The reduced air pressure against the nose gear allows the spring and gravity to force the gear forward. If you still have a gear unsafe/in transit light, declare your emergency and land as described. This is common practice, though not publish, for some aircraft (AeroCommander 112, for example). |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Military Aviation | 11 | July 8th 03 03:30 AM |
