Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Would you cycle the gear?
Old April 3rd 04, 02:24 PM
Richard Kaplan
"Roy Smith" wrote in message
Indeed it would have been. In fact, we did that, it being one of the
items on the checklist in the POH.
In that case, then I agree with what you did. The only likely situation
where the emergency gear extension would have left you without 3 wheels down
and locked would have been if there were a mechanical obstruction, and as
you pointed out it is possible that cycling the gear could have made the
situation worse in this case.
Richard Kaplan, CFII
www.flyimc.com
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Landing gear door operation Elliot Wilen Military Aviation 11 July 8th 03 03:30 AM
