![]() "zatatime" wrote in message ... On Sun, 27 Jun 2004 00:30:12 GMT, Bob Moore wrote: zatatime wrote Because FM band is a "Line of Sight" communications band. That's true, but aviation band transmissions are Amplitude Modulation (AM). Aviation transmissions are line-of-sight because of the frequency, not the modulation type. Bob Moore Can you explain? 122.6 (for example) is an FM frequency, how does ATC transmit on the AM band? z Frequency and modulation type are totally unrelated. There is no such thing as "an FM frequency." VHF aviation transceivers transmit and receive Amplitude Modulated (AM) signals. VHF communication is typically but not always line of sight. Signal propagation is frequency dependent not modulation type dependent (with exceptions here and there). |
On Sun, 27 Jun 2004 16:30:11 GMT, "Dave Stadt"
wrote: "zatatime" wrote in message .. . On Sun, 27 Jun 2004 00:30:12 GMT, Bob Moore wrote: zatatime wrote Because FM band is a "Line of Sight" communications band. That's true, but aviation band transmissions are Amplitude Modulation (AM). Aviation transmissions are line-of-sight because of the frequency, not the modulation type. Bob Moore Can you explain? 122.6 (for example) is an FM frequency, how does ATC transmit on the AM band? z Frequency and modulation type are totally unrelated. There is no such thing as "an FM frequency." VHF aviation transceivers transmit and receive Amplitude Modulated (AM) signals. VHF communication is typically but not always line of sight. Signal propagation is frequency dependent not modulation type dependent (with exceptions here and there). Thanks. I always thought VORs/Comm were FM and NDBs were AM. Need to learn more about the VHF band. Appreciate the post, what you say makes sense (mostly, but because of my need to learn, not because I think you aren't right). z |
September issue of Airman available | Otis Willie | Military Aviation | 0 | September 2nd 04 04:39 AM |
Bogus Issue | jls | Home Built | 2 | August 15th 04 04:47 AM |
October issue of Airman available | Otis Willie | Military Aviation | 0 | October 7th 03 10:39 PM |
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! | Bill Mulcahy | General Aviation | 3 | October 1st 03 05:39 AM |
September issue of Afterburner now on line | Otis Willie | Military Aviation | 0 | September 9th 03 09:13 PM |
