Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Georeferencing Maps [was GPS and airspace]
Old July 1st 04, 04:44 AM
John Clonts
"John Clonts" wrote in message
om...
Kyler,
This is the input I got from J.G. on the OziUsers list, regarding the
above:
begin quote
I took a look at the goetiff tags for the two images and I think I
see the problem. The full image is specifying a key:
ProjNatOriginLongGeoKey (Double,1): -100
While the smaller image does not even have that key. Somehow, the
smaller image is using the tag:
ProjFalseOriginLongGeoKey (Double,1): -100.583333
These can't both be right. I'd say the full image is the right one,
since it loads fine in not just Ozi, but other programs too, while
the smaller image does not work in other programs. I'm pretty
certain that the ProjNatOriginLongGeoKey is only supposed to be used
in cases where the prime meridian is not the familiar 0 degrees
longitude value. Technically, the math may work, to subvert the
function of that tag and then specify the ProjFalseOriginLongGeoKey
as 0.0, but it's highly irregular. Listgeo is able to deal with it,
by translating the natorigin key to it's equivalent falseorigin key,
but programs generating geotiff files should not rely on geotiff
readers to do this.
All that said, you can fix these keys. If you redirect the output of
the listgeo program to a file, you can edit that file with any
ordinary text editor and reinstall it into the geotiff file, using
the geotifcp program, which is part of the zip file I referred to
previously.
J.G.
end quote
Hello Kyler,
FYI, I patched the tags in my test file (from
https://aviationtoolbox.org/Members/...ul_Y=-676347.0)
with geotifcp per J.G.'s instructions, and Oziexplorer is happy with that
image now. Do you know if changing your generation code would be
appropriate, and/or cause other problems with other software?
Cheers,
John
Old July 1st 04, 04:08 PM
Kyler Laird
"John Clonts" writes:
It's appropriate and I want to do it. If it causes any problems, I'll
work through them. I want these things to be correct.
Yesterday I distilled the code to a few lines that demonstrate the
problem and sent a report to the GDAL developer mailing list.
http://remotesensing.org/mailman/listinfo/gdal-dev/
It hasn't appeared in the archives yet.
I welcome more reports to the list. My trivial example is below.
Thank you.
--kyler
#!/usr/bin/env python
import gdal
a = gdal.Open('a.tif')
b = gdal.GetDriverByName('GTiff').Create(
'b.tif',
a.RasterXSize, a.RasterYSize,
3, gdal.GDT_Byte,
[ 'TILED=YES' ]
b.SetProjection(a.GetProjection())
b.SetGeoTransform(a.GetGeoTransform())
Old July 2nd 04, 06:53 AM
John Clonts
"Kyler Laird" wrote in message
https://aviationtoolbox.org/Members/...le=50&image_fo
rmat=GeoTIFF&lr_Y=-753147.0&lr_X=318457.0&ul_X=216057.0&ul_Y=-676347.0)
Hello Kyler,
Well, I haven't seen your inquiry show up there yet-- nor at the nntp site
news.gmane.org/gmane.comp.gis.gdal.devel.
But in the mean time I did some digging, and determined a fix that seems to
work for it, in gdal-1.2.1\frmts\gtiff\gt_wkt_srs.cpp, line 1419:
else if( EQUAL(pszProjection,SRS_PT_LAMBERT_CONFORMAL_CONIC _2SP) )
GTIFKeySet(psGTIF, GTModelTypeGeoKey, TYPE_SHORT, 1,
ModelTypeProjected);
GTIFKeySet(psGTIF, ProjectedCSTypeGeoKey, TYPE_SHORT, 1,
KvUserDefined );
GTIFKeySet(psGTIF, ProjectionGeoKey, TYPE_SHORT, 1,
KvUserDefined );
GTIFKeySet(psGTIF, ProjCoordTransGeoKey, TYPE_SHORT, 1,
CT_LambertConfConic_2SP );
GTIFKeySet(psGTIF, ProjFalseOriginLatGeoKey, TYPE_DOUBLE, 1,
poSRS-GetProjParm( SRS_PP_LATITUDE_OF_ORIGIN, 0.0 ) );
/* jcc 7/2/04 changed from ProjFalseOriginLongGeoKey */
GTIFKeySet(psGTIF, ProjNatOriginLongGeoKey, TYPE_DOUBLE, 1, //
line 1419
poSRS-GetProjParm( SRS_PP_CENTRAL_MERIDIAN, 0.0 ) );
GTIFKeySet(psGTIF, ProjStdParallel1GeoKey, TYPE_DOUBLE, 1,
poSRS-GetProjParm( SRS_PP_STANDARD_PARALLEL_1, 0.0 ) );
I tried to post to the nntp server on the devel list but it did not accept
my posting... perhaps you have better connections into that group.
I will post my new pymod\_gdal.dll and bin\gdal12.dll on
alt.binaries.pictures.aviation if you would like to test them...
Cheers,
John
Old July 2nd 04, 04:08 PM
Kyler Laird
I had considered doing that too. I hesitated because I just don't know
enough about it. If it works for you, however, I'm happy to do it.
Please try the GeoTIFFs now. Do they work the way you expect?
If not, please take a look at the TIFFs in these directories.
http://aviationtoolbox.org/munge/data/masked/
http://aviationtoolbox.org/munge/data/warped/
I'm regenerating the whole set with the modified GDAL.
Thank you!
--kyler
Old July 3rd 04, 12:57 AM
John Clonts
Well, you probably know more about it than I do-- I hope it doesn't screw
somebody else up I notice that Frank W the main GDAL guy is on vacation
until next week
It works the same as before, and I see that it still has the "FalseOrigin"
instead of the "NatOrigin" key. (I.e. from
https://aviationtoolbox.org/Members/...s/map_explorer).
Ok, but these are 200Mb files?
Thank you!
Thank you!
John
Old July 4th 04, 02:08 PM
Kyler Laird
I've completely regenerated all of the images from the base (FAA) set
using the modifified GDAL. Please verify that the GeoTIFFs are now as
they need to be.
I now see tags such as this.
ProjNatOriginLongGeoKey (Double,1): -100.583333
Thank you.
--kyler
Old July 5th 04, 04:59 PM
John Clonts
they need to be.
Thank you.
--kyler\
Seems to work perfectly for me now...
Thank you!!
John
